Question about Fuji FinePix S602 Zoom Digital Camera
Battery cover is chipped Finepix S602 Zoom
I need information on where I can get a replacement for the Battery cover as one of the hold down clip has chipped off and the battery compartment wont close fully.I am located in Chennai India
5 Suggested Answers
jerryg50
  • 1667 Answers
SOURCE: I cannot format cards in my Fuji S602 zoom.
Make sure your card is compatible for your camera, and or it is not defective. I know that with some camera models the card must meet specific specs. Consult your camera dealer or call Fuji photo support to verify if your card is compatible.
If you have the adabtor for your card to be used directly on your computer, you can see if formating your card with the computer will help. This is not the proper fix, but it may work for you.
Jerry G.
Posted on Jan 23, 2010
  • 11967 Answers
SOURCE: my finepix s602 zoom lens is stuck out and when
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Mar 01, 2010
Testimonial: "i will try these thanks "
hmerchant110
  • 7191 Answers
SOURCE: can I get a manual
You can download and print the instruction manual for Fujifilm Finepix S602 Zoom free of cost in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Thanks for using FixYa.
Posted on May 12, 2011
  • 102366 Answers
SOURCE: Dear Experts, My Vista OS laptop
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Posted on Jun 22, 2011
Does Fujifilm FinePix S602 support 4 GB memory card
It should. If you want to take videos with this camers then make sure the SD memory card is a class 8 or higher.
Nov 02, 2012 | Fuji FinePix S602 Zoom Digital Camera
Can I get a manual for fujifilm finepix S602 Zoom, will I have to pay ?
May 12, 2011 | Fuji FinePix S602 Zoom Digital Camera
I want to download images from a Fuji Finepix S602 to a pc. I do not have a disc.
Hi.
You can download the software from Fuji's support page. Please click on this link.
Hope this helps.
Apr 12, 2011 | Fuji FinePix S602 Zoom Digital Camera
My s7000 batterries do not last very long i am wondering if something is draining them down
PRESS RELEASE
Release Date: 12 January 2004
Fujifilm today announced that a number of early FinePix S7000 Zoom digital cameras may experience battery power depletion when used with some CompactFlash™ memory cards.
This fault does not occur when the S7000 is used with either an xD-Picture Card™ or a Microdrive™, nor does it occur in any other Fujifilm products that offer a CompactFlash™ storage facility, such as the FinePix S2 Pro, S602, S602 Pro or M603.
Cameras with serial numbers above 34L60001 (inclusive) were produced after 15 December 2003 and therefore will definitely not experience this battery drain problem.
In the short term, the problem can be avoided by unloading then re-loading the batteries just after the camera is switched off. The camera's power supply will then perform normally.
Mar 03, 2011 | Fuji FinePix S7000 Digital Camera
Fuji s602
Replace it - these thing sdont get fixed
Jan 21, 2009 | Fuji FinePix S602 Zoom Digital Camera
Drivers
You shouldn't need a driver for xp and above as it will be detected as a generic card reader..(As per the manual information)
Having said that there is a driver available from the Fuji site..
http://www.fujifilm.co.uk/consumer/digital/digital-cameras/legacy-cameras/finepix-s602-zoom/support
I remember finding this confusing when I was looking for a driver for my S602
Jun 08, 2008 | Fuji FinePix S602 Zoom Digital Camera
Bent pins on my finepix s602 zoom
It depends on how much the pin/s are bent. Having said that, I recently aquired the S602 Zoom that has this problem. I contacted Fiji who said they could fix it for £97. I opted to give it a shot myself. I used a fine sharpened steel rod to lift the bent pin enough to slide a thin steel flat bar under the bent pin. (I made both of these tools myself with a grinding stone and scrap stuff I had lying about)Then I carefully raised the pin upright again. Finally I used a hollow, strong, thin steel tube (I used a dissasembled watch strap pin from an old watch) and holding it in needle nosed pliers I used it to straighten out the pin and re-set it in place. It worked fine for me but your situation my more complex/different.
May 10, 2008 | Fuji FinePix S602 Zoom Digital Camera
Battery compartment cover
They really want you to buy a new camera instead!
TAPE it shut!
Otherwise you can sometimes find equipment sold 'as-is' for parts on eBay or other internet sites.
Do a web-search for it.
Nov 01, 2007 | Fuji FinePix S602 Zoom Digital Camera
Fuji finepix s602 horizontal banding
OK I know I'm very late posting this, but should anyone else wonder, this is typical of a dead CCD, typically very expensive to fix. Sorry.
Apr 25, 2006 | Fuji FinePix S602 Zoom Digital Camera
Fuji FinePix S602 Zoom Digital Camera Logo
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
