Question about HP Photosmart 3210 All-In-One InkJet Printer
Hp 3210 is leaking magenta - HP Photosmart 3210 All-In-One InkJet Printer
    Guru:
  • 389 Answers
Resetting the printer. After the Ink Service Module has been replaced, trigger level 1, 2a, 2b, or 3 will still be displayed when the printer is turned on. Reset the printer to remove the trigger level messages.
CAUTION: Do not reset the printer if the Ink Service Module is not replaced. The spittoon may overflow. Follow the instructions below to reset the printer.
  • Turn on the printer
  • Press and hold down the Cancel button
  • While holding down the Cancel button, press and hold down the Resume button
  • Hold the Cancel and Resume buttons down for 8 seconds and then release both buttons. The Right Print Cartridge LED and the Resume LED will go off and the printer will return to a Ready state.
  • When the printer returns to the Ready state, it indicates the printer was successfully reset.
    OK I had the hp error code 0xc18a0001 problem and here is the conversation I had with the tech...
    James Cowan: HP error code 0xc18a0001
    Earnest: I will assist you in this regard. I understand that a error code with 0xc18a0001 with "Ink System failure" is displayed on the front panel of the All-In-One printer. Am I correct?
    James Cowan: Correct
    Earnest: May I have the model number of All-In-One you are using?
    James Cowan: c6250
    Earnest: Please let me know the room temperature in which printer is replaced
    James Cowan: 67 degrees F
    Earnest:: OK. Please perform the below steps on the front panel of the printer to resolve the issue
    James Cowan: OK
    Earnest:: Press and hold the "left arrow" key. Press the "Setup" key and release both keys, display should say "Enter Special Key Combo". Press and release the "OK" button
    Earnest: Please ignore the above steps
    James Cowan: OK yes nothing seemed to do anything
    Earnest: Please perform the below steps on the front panel of the printer. Press and Hold the "Print Photos" & "Red Eye Removal" buttons. Release both buttons. Display should say"Enter Special Key Combo". Press and release in sequence"Red Eye Removal", "Print Photos", "Red Eye Removal"
    Earnest: Display should say "Support" and display the FW rev (something like R0616R)
    James Cowan: COxxFN0723BR
    Earnest: OK. Press and release the right arrow button until the display says "System Configuration Menu"
    James Cowan: OK
    Earnest: Press and release the "OK" button
    James Cowan: OK and it says hardware failure status
    Earnest: Display should say "Hardware failure status: Clear. Press OK to clear". Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue". Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. Please do not try to print at this stage
    James Cowan: OK
    Earnest: Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. Let me know once you are done with the above steps
    James Cowan: OK its unplugged
    Earnest: Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer. Turn the unit on. The printer may display message "Use POWER button to shutdown the printer" followed by "Press OK to continue". Press OK
    James Cowan: OK
    Earnest: Let me know the message displaying on the front panel of the printer
    James Cowan: printer preparation occuring - do not interrupt
    Earnest: OK
    James Cowan: OK its done
    Earnest: Let us print a self test page from the printer now
    James Cowan: OK deal
    Earnest: 1) Load letter, A4, or legal unused plain, white paper into the input tray
    2) Make sure that the printer is on and loaded with unused plain, white paper
    3) Press Setup. The Setup menu appears
    4) Press the down arrow button to select Tools and then press OK
    5) Press the down arrow button to select Self-test Report , and press OK. The self-test report prints
    James Cowan: OK printing
    Earnest: OK, please check whether all the colors pritned perfectly on the test page
    James Cowan: Perfect
    Earnest: Great... Cheers!!!
    James Cowan: Thank you very much
    Earnest: Now you can continue using the printer.
    Posted on Sep 25, 2009
    My hp priter is printing pink lines in the edges of my paper
    Your magenta toner cartridge or magenta print cartridge is leaking ...you should replace it (magenta is the red one).
    Mar 23, 2014 | HP LaserJet Office Equipment & Supplies
    Hp 3210 not printing magenta and leaving large quantities of magenta ink in printer blobs on right side of paper
    defective cartridge; make sure you buy ANY cartridge from a REPUTABLE, not cheap, cartridge company.
    Dec 24, 2012 | HP Photosmart 3210 Printer
    My HP Photosmart 3210 Printer does not Print Red.
    WELL IT'S 5 DEC 2012, THIS HP 3210 QUIT MAGENTA'S.
    WENT TO TOOLS TO CHECK LEVELS, NO YELLOW, GOT NEW CARTRIDGE, TEST SHOWED NO MAGENTA'S. REMOVED RIGHT SIDE COVER (GENTLY) AND REMOVED ALL TEN CABLES AND REINSERTED CAREFULLY. TESTED AGAIN, AND HAD LINES ONLY ON BOTH LIGHT AND DARK MAGENTA'S,
    RAN CLEAN HEADS, SIX TIMES AND ALIGN PRINTER ONCE.
    PICTURE GOT BETTER AND BETTER FINAL TEST DIAGNOSTIC PAGE PERFECT ALL SOLIDS. GOOD LUCK KEEP GOING
    Jun 08, 2012 | HP Photosmart 3210 Printer
    Hp 3210 is leaking ink
    Remove the black ink cartridge and put a piece of tape on it to prevent it from leaking all over your clothes. Find the receipt for the cartridge and return it to where you purchased it from. More then likely your going to have to clean out your entire printer to get rid of the ink that has leaked into it. You have a faulty ink cartridge. Hopefully you purchased a name brand cartridge and can return it. If you need assistance with instructions on how to clean out your printer, please advise.
    Apr 30, 2012 | HP Photosmart 3210 All-In-One InkJet...
    Cartridge Leaked
    Yes it is. Just change the magenta and it will be normal.
    Feb 03, 2010 | HP Color LaserJet 2600n Printer
    HP Photosmart 3210xi - some colors (magentas) will not print
    Remove the magenta cartridge, and try cleaning the head with alcohol, maybe with a small paint brush or an acid brush. It sounds like ink has dried and plugged up that head.
    Jun 04, 2017 | HP Photosmart 3210 All-In-One InkJet...
    I have a HP Photosmart 3210 All-in-One Inkjet Printer that is leaking Magenta. How do I fix this?
    Clean the thing up and put in a different ink cartridge.  You got a defective ink jet cartridge.
    Oct 25, 2009 | Office Equipment & Supplies
    Magenta cartridge in hp4600 leaking
    it is usually the cartridge that is the problem. the 4600 is famous or infamous for this problem.
    Sep 01, 2009 | HP LaserJet 4600 Printer
    Ink
    did you do a clean and recalibrate?
    Jun 21, 2008 | HP Photosmart 3210 All-In-One InkJet...
    Ink refill
    Get a tissue paper smudle the cartridge head on th tissue in a straight line this will give you an idea where their holes are they are the ones directly above that color or that order usually Left to right starts with yellow cyan magenta in a traingle formation it should be in line with the line you produce when you smudge it on the tissue directly above each line is its hole on top of the cartridge..
    May 28, 2008 | HP Photosmart 3210 Printer
    HP Photosmart 3210 All-In-One InkJet Printer Logo
    825 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
