Question about Nokia 5310 Cellular Phone
I cant access my memory card in my computer.., it stops for a while and a ''THE DISK IN DRIVE G IS NOT FORMATTED. DO YOU WANT TO FORMAT IT NOW'' appears. can you please help me..,
  • epyon_7ye Sep 25, 2009
    if i would reformat it., will all the data/s on the memorY be lost?
  • 438 Answers
Pls do format it.....u r prob ll be fixed....
Posted on Sep 25, 2009
  • ranjit kumar Sep 26, 2009
    yeah ofcourse...all ur data will be lost.....
I want to format my transcend from mac how can i do it
Transcend produces different kinds of memory modules, including Random Access Memory, or RAM, chips for computer systems, USB flash drives and a variety of flash memory card formats, such as SD.
Transcend's flash memory devices are usually preformatted with either FAT32 or NTFS. Macintosh systems primarily use the HFS+ file system format.
You can format a Transcend flash memory card to the FAT format using the Disk Utility program on a Macintosh.
Insert the Transcend flash card into a card reader connected to the Mac.
Some Macintosh computers have SD card readers built in.
Open the Disk Utility program in the Utilities folder.
Click the flash card in the left column of the window.
Click the "Erase" tab.
Click "MS-DOS (FAT)" in the "Format" drop-down list.
Enter a name for the flash card in the "Name" box.
Click "Erase" to format the flash memory card to FAT.
Hope this helps
Oct 28, 2012 | Transcend ts250gsj25m storejet 25 mobile...
My micro sd card is only making pip sound and i cant see in my computer. i know im suppose to format the SD card after i insert in my computer. i m using windows 7 and cant found sd in my computer please...
Go to Control Panel ' Adminitrative Tools ' Computer Management
In Computer Management find Disk Management, if the card is being recognized at all, then it will show up as a removable disk. Right click on the disk and you can format it.
Jim
May 01, 2011 | Kingston 4GB Secure Digital High Capacity...
ERROR IOCTL CALL..CAN'T FORMAT MY 2GB MICROMAX FLASH MEMORY..
i have 500gb removable hard disk i cant access it and i cant format it it shows IOCTL error help help
yhabtea@yahoo.com
Apr 05, 2011 | Electronics - Others
Not formate
You can format your memory through Disk Management.
You can access it through:
1. Right Click on My Computer
2. Click Manage
3. Under Storage Click Disk Management from the Left Panel.
4. Right Click the drive of your removable storage then click Format.
Thanks & Regards,
(-_-)
Mar 22, 2011 | SanDisk 2GB microSD Memory Card
I cant open my files in the computer through my phone memory card?
if it asked you you need to format than thats because your fone had installed automaticly some files to the usb drive, and the only way is to format.
if the error is only cant acces, than try to access it from dos prompt...or try to putt the drive letter in the task bar in my computer...
May 11, 2010 | SanDisk 2GB microSD Memory Card
I CANT FORMAT MY MEMORY CARD....I DONT KNOW HOW TO FIX IT.
  1. Open control panel.
  2. Open administrative tools.
  3. Open Computer management.
  4. In the left column click disk management.
  5. This populate all the disk present
  6. Locate your memory card
  7. Then you can delete the partition entire and build new one
  8. You can format with Fat Or FAT32 file system
  9. Do not perform quick format.
Another options are available to format via cmd
To do that
At the run Menu type:CMD
then a command promt window will open
Type format x: /fs:fat32
Note that x is volume label (memory card drive label may d, e or f)
ok
try this
Feb 25, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
I have got a 2gb scan disk memory card i cant access it or format
Hello Friend,
Here is a method to try:
  1. Backup all data from your hard drive to another hard drive or CDs or DVDs.
  2. Turn off your computer.
  3. Insert the USB drive to a USB port.
  4. Turn on your computer.
  5. Hit the F8 key when prompted to get to your system bios. Some computers required the Delete key or F2 instead of F8. There should be a note on the screen that specifies the key.
  6. Navigate your bios (usually using your cursor keys) to boot from CD drive first. Save and exit.
  7. Insert your operating system disc aka Operating System Restore disc. Your computer should restart. If not, restart it yourself.
  8. Follow the instructions for installing your operating system. When the option to select which drives to format comes, you should be able to see your USB disk in the list.
  9. Format the disk with FAT32 for Win98 or previous. Format with NTFS for anything after e.g. NT, 2000, XP etc.
  10. Depending on your options, you may be able to opt out of the operating system install at this point. If it was running well beforehand and you can, leave your other drives alone and quit the re-installation.
  11. Reset the computer to boot from the disc drive the operating system is on instead of the CD drive as before. You should have your working flash drive detecting and usable now in windows.
  12. If you didn't get the option to opt out of the re-installation, continue to follow the instructions onscreen and complete the re-installation, formatting whatever drives are required. Note: Do not try to install your operating system onto your USB disk drive. Also be cautious when formatting to keep in mind all data could be lost.
Best Regards,
Oct 29, 2009 | Electronics - Others
Cant format a sandisk 4 gb hc card why?
try formating in the following steps
1. right click on my computer then manage
2. click on disk management
3. right click on the flash drive then format
if the problem still occurs then there is some problem in the memory ic.
Oct 28, 2009 | SanDisk 4GB microSD High Capacity Memory...
PNY SD 2GB card suddenly stopped working
In the menu of your camera you should be able to format your card. Make sure the little tab on your card is not in the protect position.
Aug 23, 2009 | PNY 4GB Secure Digital High Capacity...
Cannot access and Format SanDisk 512MB memory Stick PRO Duo
Hi sir
  1. 1 Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  2. 2 Open up 'My Computer'. You should see it under the list of available drives.
  3. 3 Check its contents first to make sure that you have the right drive.
  4. 4 In 'My Computer', right-click on the drive and choose 'Format'.
  5. 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  6. 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Jun 26, 2009 | SanDisk Memory Media
Nokia 5310 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
