Question about E-Machines etower 633id PC Desktop
When contacting the net, my username and password are verified, but a pop up box indicates error 691 and asks me to re-write them again - but where do I write them. I suspect my pasword has expired because the computer failed recently
    Problem Solver:
  • 7 Answers
Sounds like you have a bad connection. what that is, is that your page is timing out. make sure all your cables are pluged in securely and one more thing to help is a program called "CCleaner" it cleans registry errors and cleans your internet cache. cache build up realy slows down your web browsing.
Posted on Sep 25, 2009
I would like to change my password
Change an Internet Password
Use a bookmark, a known URL, or a search engine to find the password-protected website you are looking for.
Input your username (also called an online ID or user ID).
Look for a link that says "Forgot your password?" or something like "reset password," "reset passcode" or "password help." Click that link.
The website may require you to fill out fields with information about yourself and your account, in order to verify your identity.
If it does, submit the required information.
The website will then allow you to input a new password.
Type a password that conforms to the website's password requirements (for example, the page may indicate that the password has to contain both letters and numerals or that it has to contain a certain number of characters).
You probably will be asked to confirm that password by retyping it in a second field.
Change Administrator password using DOS Command
Use dos comand
The administrator account on a Windows machine is the main, root user name that gives full access to the machine.
Administrators should change this password frequently to avoid unauthorized access to the domain or desktop machine.
This can be done in the Windows Control Panel, or use the "net user" command in the Windows DOS prompt.
Log in to the machine using the administrator username and password.
You can also use an account that has administrator privileges on the domain or desktop computer.
Click the Windows "Start" button and select "Run" or "Start Search" (depending on your version of Windows).
In the text box displayed, enter "cmd" and press the "OK" button.
This opens the command prompt window.
Type "net user administrator <new password>" into the command prompt.
Replace "<new password>" with the password you want to set.
Enter the password again for confirmation.
Once you enter it again, the administrator password has been changed.
Test the new password by rebooting the machine and logging in with the new administrator password.
Dec 09, 2013 | Computers & Internet
Tip
How to Fix Juno Webmail Error 691: Invalid Username and Password
When using the Juno webmail services, you might get the connection failure issues, as the member ID or the password you have entered is wrong. This problem is also known as the Error 691: Username and password incorrect. At such time, you need to input the password all in lower case letters. If the password isn't working, check that the Caps Lock key isn't active. If you forgot the password, ask the solution of experts just by dialing the Juno customer phone number. As many factors can cause error 691: invalid Member ID or Password, so follow the listed guidance to diagnose the cause of the error and solve them out instantly.
1.Check the Member ID and Password
Make sure that you're entering the correct Juno user ID and password. Also, ensure that you have entered the password into lowercase letters. If your password isn't accomplishing, make sure that the Caps Lock key hasn't yet been activated. If, however, you forgot the password, then you can change it under the supervision of experts.
2.Ensure that Juno Webmail Account has Correct Configuration
If your Juno webmail account was created correctly, the new account information should appear at the end of the confirmation screen. Additionally, if you have logged into the account successfully as earlier, it must be correct.
3. Check that you haven't set the password in Juno software
Do you have the program to configure to remember your Password automatically? In most cases, the password present into the Juno program may be changed. It can happen, if, for instance, you have pressed a key accidentally on the keyboard. If you're sure that your account password is correct, remove the currently set password from the software and re-enter it. This step would solve the error if the password were changed accidentally.
4. Make sure that the access number is correct
To make a successful login to the Juno webmail account, it's necessary to make sure that the access number of your area is valid. When choosing the access number, it may be the area code or placed in the general geographic region rather than local numbers. You may experience extra telephone charges if you select access numbers that aren't covered by the local calling plan.
Note: - You're only responsible for several telephone charges associated with accessing the services. Juno will not refund you for such costs, such as toll charges or long distance.
5. Check Juno webmail version
Do you have the new edition of Juno webmail program? If you're unsure about the Juno version, you can seek the help of IT professionals or go to the Juno official site to know the step-by-step direction to check the version.
6.Test the encryption settings
If you're running the Windows 98, 2000, ME, or XP:
    •Double-click on the 'Computer' icon on the desktop, followed by the 'Dial-Up Networking' icon.
    •Click on the Juno icon to select it. Choose 'Properties' option from the 'File' menu.
    •Choose the 'w Server Types' tab and make sure the 'Require encrypted password' option is not checked. Click 'OK,' and then 'OK' again. If you're still facing issues with the Juno webmail account, call on the Juno support number and seek the technical assistance to solve out all problems instantly and efficiently.
How to Fix Juno Webmail Error 691 Invalid Username and Password
on Apr 13, 2017 | Miscellaneous
Nod32 eset 4
Go to eset.com and click download button, then click take me to my download. Choose your operating system either 32 or 64bit. I recommend to download ESET Smart Security 4 then click download button. It will ask you a username and password use this:
Username:EAV-41889171
nod32key:b4423pt762
Username:EAV-41889176
nod32key:4kbvp6fsx5
After downloading, install the antivirus and use again the username and password if asking for a username and password. After installing, it is must update the antivirus defination by clicking the update and update virus defination. If already expired for about 1 or 3 months after installing. Open the eset smart security by double clicking the eset icon on the left side below near on the system date and time. When appearing on the screen press F5 then uncheck the three box that has been checked. Click ok and visit the website nod327.net and copy the username and password. Click update and click username on eset antivirus and paste the username and password you have copied on the nod327.net then press F5 again and check those you have uncheck then click ok. Update again the antivirus defination and your antivirus will extend again for 1 or 3 months expiration. Have a nice day.
Feb 26, 2011 | Computers & Internet
Cannot connect Outlook 2007 to Yahoo server
I had in like situation some times and once I couldn't solve it and luckily for me could find out a good solution to my mind, which determined my troubles quite easily and moreover I hope that this utility will help in this condition too - pst password recovery.
Apr 21, 2010 | Microsoft Computers & Internet
Need to find my password
1. Access the Linksys webpage
*To access the linksys gui
a. connect your linksys to the computer via RJ45 (ethernet cable)
b. Open internet explorer and on the address bar type 192.168.1.1
c. A pop-up will ask for a username and password
c.1 username and password is both admin
c.2 username admin and password blank
c.3 username blank and password admin
d. If none work reset the modem at the back of it there is a reset button "warning if you reset the modem it will be reset to factory setting and you need to setup your router again"
e. disable your computer firewall
2. Contact you ISP for assistance setting the Linksys
Nov 16, 2009 | Linksys Wireless-G Broadband Router
Error card: 691 re username and password etc.
Call ur service provider and get the correect username/password or get it reset.
Feb 03, 2009 | WiFlyer - Portable, shareable WiFi base...
Why does the network password box keep popping up?
if you tick the box Remember my password, it should not pop up again. if it does. the password is wrong, or the username is not formatted correctly.
i often see the username as "servername\username" instead of "domain\username".
check that .
Jan 17, 2009 | Computers & Internet
Error #0x800CCC0D can't contact pop-server-hawaii.rr.com
search for proper mail server adderss on the net. then try creating account.
Sep 27, 2008 | Computers & Internet
Tipps pls?
The error you refer here are due to Bad Username/Password.
Please type 192.168.1.1 in your web browser, a pop-up window will show which require User Name and Password. Type both as admin (Please use only the lowercase letter). You will then be carried out to your Modem Configuration Page. In the Left Pan select first Reboot. From the right Pan select the lower button i.e. Restore Default setting. Your Modem will be rebooted. After booting the Modem (When all the lights are ON), again type 192.168.1.1 and use the process as above to acess the Modem Configuration Page. Now select the WAN from the left pan. Press the Edit button in the row for PPPoE settings. Don't change any setting shown by default and press the next button. At the end you will get a text box to type your User Name and Password. Use your Broadband User Name and Password here (Not the Portal ID & Password). click next and then save. Now again just reboot your Modem by using the upper button in the Reboot page. You can use your broadband now.
Note: If you are unable to open the Modem Acess Page by typing 192.168.1.1, ask the BSNL person to change your Modem.
Hope this will solve your problem.
For any clarification, do contact me.
Jul 21, 2008 | Computers & Internet
E-Machines etower 633id PC Desktop Logo
47 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
