Home | PDAs | Quorum Elert
PDAs
Problem for PDAs
Generic problem for all PDAs
Quorum Elert
By Douglas14 on Dec 16, 2007
I have the Quorum Elert Alarm product but no instructions on how to arm or dis-arm it. Can you help?
Same Problem
May 04, 2009
-   I do not have the instruction, can anyone help....THANKS -   gary_pdgtt
Sep 12, 2008
-   Help, no owners manual-   labass251
Mar 06, 2008
-   I ALSO RECENTLY CAME ACROSS MY QUORUM ELERT AND HAVE LOST THE INSTRUCTIONS, HELP-   TACUSHKA
Feb 17, 2008
-   i have the same problem-   ciroo66
Feb 16, 2008
-   I also came across the device in my garage. No instructions... if anyone has instructions it would be greatly appreciated.-   MrDazzling
Best Solution
posted on Feb 03, 2008
Helpful)
fixytrixy
Rank: Apprentice
Rating: 91%, 46 votes
Hang on...I might have a line on the manual. I'll post when I get it.
Comments:
Feb 17, 2008
QUORUM ELERT Operating Instructions
BATTERY INSTALLATION
1. Remove the battery compartment door by first removing the single screw beside it.
2. Insert the 3 supplied “AAA” Duracell batteries.
WARNING: Incorrect installation can permanently damage the electronic components. Be certain to align positive-to-positive, negative-to-negative.
3. Press the (F) Function key. One beep will be heard.
4. If the beep is not heard,
5. Remove the batteries; press the (F) key for 10 seconds.
6. Replace the batteries properly.
7. Replace the battery compartment door and gently tighten the screw to secure.
SETTING YOUR PERSONAL CODE
This alarm is pre-set with the disarm code of 1-1-1. To set your own personal code, follow these steps. Select three digits from 1 to 6 that you will not forget.
1. Press the (F) Function key.
2. Enter the pre-set code of 1-1-1, the red LED will illuminate.
3. Enter your three-digit code; the red LED will turn off.
To change your personal code, follow the above procedure.
ARMING THE ALARM
1.  Press the (F) Function key, then the Lock key. Ensure that the red LED illuminates. There is a 10 second delay period during which the alarm will beep and the red LED will flash. After this, the alarm is armed.
2. After 1 minute the alarm will go into the “Conserve” mode to reduce battery drain while continuing to monitor motion.
DISARMING THE ALARM
The alarm is pre-set with a 3 second delay to allow you to enter your personal code without setting of the alarm.
To disarm, simply press your three digit personal code.
ADJUSTING THE TIME DELAY
To change the pre-set 3-second delay, simply press (F) Function key, then the Time key. Select your choice of a 3, 10 or 20 second delay by pressing the number 1, 2 or 3 respectively.
SENSITIVITY ADJUSTMENT
You can increase or decrease the alarm’s sensitivity to movement through adjustment of the slide control located on the lower left side of the ELERT.
ATTACHING THEALARM
The portable ELERT has been designed to be fastened in a number of ways to protect any number of items.
1. Use the supplied mounting clip to screw to doors or objects.
2. With the supplied Velcro tape, you can easily affix and remove from virtually any surface such as computers or the frame of a metal door.
3. With the supplied nylon strap, you can secure around objects such as bicycles, skis, golf clubs or luggage.
PANIC ALARM
In the event of a crisis or emergency, an immediate alarm can be sounded by simultaneously pressing the (F) and (Lock) together. Alarm will sound for 30 seconds, if armed will re-arm itself.
LOW BATTERYINDICATOR
Illumination of the yellow LED indicates a “low battery” energy level. Replace with high quality Duracell batteries as soon as possible.
Low battery levels will not be detected in the “conserve” mode or when “off.” Therefore alarm should be re-set monthly to watch for a “low battery” indication.
NOTE
1. This alarm is not considered weatherproof.
2. Operating temperature range is –20°C to + 50°C (-4°F to + 122°F)
WARNING
This alarm is intended only to aid in the detection of movement of an object and is not infallible, According to experts, a loud noise is often the best defense against either an intruder or a thief.
PAGE
PAGE  1
Was this helpful?
Yes
No
19 people thought this was helpful
Solution #2
posted on Jan 13, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
got the directions justt have to scan them.
Solution #3
posted on Apr 18, 2009
Not Rated)
boyadams
Rank: Apprentice
Rating: 0%, 0 votes
Found my Elert bought in 1995 with lost instruction manual. This was helpful! Thanks a lot!
Was this helpful?
Yes
No
Solution #4
posted on Feb 06, 2009
Not Rated)
Galaxie1
Rank: Apprentice
Rating: 0%, 0 votes
Thanks was just looking for instructions for many different Quorumproducts - because I got a hole box from my past away friend.
Sweden - thanks
Was this helpful?
Yes
No
Popular Solutions for PDAs
Questions and Unsolved Problems for PDAs
Answer
I want a product similar to Palm m505 to store data only.
Answer
i'm trying to use voip call in my blackberry curve 8310 ?
Answer
how to transfer data from PV-S1600 data to Outlook 2007
Answer
Am having problems with my g1 the usb port is connected to computer but it does not show in... (More)
Answer
touchscreen not working
9 Other Users Have The Same Problem - Continued
Comment by wstrong, posted on Jan 20, 2008
Also have the same unit, found at the bottom of a drawer in clean-up today .. no instructions either. If you get the instructions scanned, i'd appreciate them posted to wstrong@mountaincable.net also. Thanks in advance..
Found the same product in the bottom of a drawer also.. god knows how long it's been there.. if you've got the instructions scanned, pls email to wstrong@mountaincable.net also .. thanks in advance.
Comment by Pyro60, posted on Jan 13, 2008
hi I have just found a elert in the botton of a draw and wonder how to make it work, mine is without batterys and must have been here a long while. please mail info to andycbooth@blueyonder.co.uk
many thanks
Andy
Comment by Guest, posted on Dec 29, 2007
lost instructions help
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For PDAs:
Top PDA Experts
Rank: Guru Guru
Solutions: 554
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more PDA Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
