Question about Black & Decker TCM830
Water flows out the back of the unit instead of flowing into the bottom.
  • 832 Answers
In other word, it is leaking. Then, you can open the cover or casing, and trace the leak. Then, you can fixed
it.
Posted on Sep 25, 2009
This unit flows continuously thru the drain line that returns to the waste drain is this normal
What's causing this refrigerator problem? [Archive] - Straight ...
boards.straightdope.com > ... > Main > General Questions
Mar 16, 2012 - 32 posts - ‎16 authors
The drain line should come out of the unit some where and empty into a .... water generally goes down the back wall of the fridge and through a ...
How To Repair A Freezer Dripping Water Into Refrigerator ...
removeandreplace.com/.../freezer-drain-frozen-water-dripping-into-refri...
May 27, 2015 - The freezer drain hole and drain line in the bottom of my freezer keeps icing up. ... is to simply run hot water through the drain line to allow water to flow. ..... Divert Water Dripping Outside From Air Conditioner Window Unit June 30, 2015 ..... How To Fix A Toilet That Is Constantly Running - DIY Toilet Repair ...
Refrigerator Troubleshooting & Repairs ' HomeTips
www.hometips.com/repair-fix/refrigerator.html
May 22, 2015 - Refrigerator Runs Too Much ... If your refrigerator runs without stopping, it may be too low on refrigerant to ... 4Make sure the drain line isn't plugged. ... Instead, the unit may have dirty condenser coils, a door that doesn't seal tightly .... on the tubing and, eventually, restricts airflow through the refrigerator.
Dec 29, 2015 | Refrigerators
No hot water flow through faucets
At the back of the water heater there will be a series of valves. One on the bottom, sometimes one on the top and then one in a line that connects the top to the bottom lines. Make sure the middle valve is closed and the top and bottom valves are open. If there is not a valve on the top that can be manually opened and closed then there is a check valve installed. This check valve will allow the hot water out of the tank but will prevent the back flow of cold water during the winterization bypass. If the valve on top is closed it will not allow hot water out. If the middle valve is opened it will allow the cold water to mix with hot water and defeat the purpose having a water heater. Close the middle open the top and bottom. If there is not one on top then the check valve is probably clogged or has failed and need to be cleaned or replaced.
Mar 08, 2014 | Open Range 2013 Residential R398RLS
After water to house was shut off, my Noritz tankless water heater is on but won't produce hot water. On the unit, the light indicating that the burner is on stays off now.
you probably had debris get into the filter or flow sensor when the water was turned back on. I'd recommend checking the filter first and if that doesn't work, call Noritz Tech support to help you with the flow sensor.
the filter is a black plug located on the cold water line (labeled cold on the bottom of the unit). It points torwards the left.
Apr 14, 2010 | Noritz 7.1 Gpm Natural Ng Gas Tankless Hot...
My water dispenser flows very slowly. The unit is
Check for clogged output valve. Second the filter candles require an annual change as they also get clogged from filtering water.
Thanks for using fixya
proton
Aug 14, 2009 | Refrigerators
Water from the in the door water dispenser trickles out instead of flowing out
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. If it comes out good here Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws.
A strainer before the inlet valve can also get stopped up restricting flow.
Jul 01, 2009 | Refrigerators
Water flows out the hot tap in the back instead of flowing inside
You need a repairman the back are tricky to remove but you have something broken back there. You water valves are functioning properly but the route for the water is non-existent due to some sort of brake.
Mar 18, 2009 | Kenmore Elite HE4 Electric Dryer
I have a General Humidifier Model 1042-L that is leaking water out of the bottom pan. How do I fix this?
Check the bottom of the drain tube (tube connected to the bottom center of the bottom tray). Does water freely flow out the bottom end of the tube when the humdifier water feed is on?
If there is no flow from the tube and water is leaking from the bottom tray when the humidifier water feed is on then the tube or bottom tray may be clogged with hardwater minerals or other material.
Also, if the humidifier has not been used in a long while it's possible a spider has take up residence by spinning a web in the bottom tray or tube. Tell the spider to find a new home.
Another possible reason is the tray is cracked. You may order the tray from multiple sources on the web. Simply shop for model and price.
And lastly, is the unit installed properly, parallel to the ground? If tilted, water flowing through the unit may catch the sides and flow out where it should not.
Jan 16, 2009 | General Filters 1042-LH Humidifier
Bucket fills up instead of water flowing out hose
There must be a blockage in the hose causing the water to back up and flow into the bucket. Try pushing a flexble peice of wire through the hose to unblock it.
Oct 17, 2008 | LG LHD45EL Dehumidifier
Condensation causing water collection
Hi there!
Make sure the unit is level and not tilted forwards.Tilt back if anything.
There should be a drain hole at the back, but it may be clogged, or there may be an obstruction causing the water to build up.
In times of high humidity, water will condense on the cooling coils, and drip off. This is usually carted away by means of a tray flowing to an outside pipe.
One design uses a flinger to catch any water and throw it onto the evaporator coils - thus improving efficiency, but if there is anything touching the coils, like a feather etc, it will flow down that and leak.
Tip it back as the first action, then investigate if it doesn't drain.
Jul 06, 2008 | Samsung AW0503B Air Conditioner
Water flow through humidifier
I installed this humidifier (and had a lot of trouble installing it!) and was surprised by the flow of water. Mine leaks out of the bottom of the unit so I haven't actually used it yet. I'll try to figure out why it's leaking this weekend. I thought there would be less water flowing through the pad. I suspect that the weight of the unit is causing it to not be plumb so some water is dripping off of the pad and past the drain tray.
Nov 30, 2007 | Honeywell HE360A1027 Whole House...
Black & Decker TCM830 Logo
133 people viewed this question
Top Black & Decker Coffee Makers & Espresso Machines Experts
eyecam
Lyle Siemens
Lyle Siemens
Are you a Black & Decker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
