Question about Coby MP-610 MP3 Player
I turn it on, and it freezes while loading, why is that?
    President:
  • 803 Answers
It is more than likely that your firmware for the player is corrupted. All you need to do is go to the coby official website and download the latest firmware for the player. then you need to connect the player to the computer and backup all files on your player. Then you are going to reload the firmware and it will load it back to factory settings and that should fix it.
Posted on Sep 27, 2009
Intermatic PF 1102 digital timer with freeze control; Timer will switch from off to on to auto, but when switching to "on' the pump will not turn on. There is a "click" that indicates to...
The freeze control is wired parallel with timer, so both controls can turn Load ON-OFF.
So Load turns ON when either the freeze-control or the timer turns ON.
When both are ON, then Load will be ON.
Freeze control can be ON and timer OFF and Load is ON
Freeze control can be OFF and timer ON and Load is ON.
Only when both Freeze control and timer are OFF, will Load be OFF.
If pump is not turning ON below 32 (or the protection set point), then freeze control thermostat is suspect.
But you need to check if pump turns ON when timer turns ON.
If pump operates with timer, then freeze control is main suspect, unless there is a loose wire.
Open box and check for loose and burned connections.
If pump does not operate with either timer or freeze control, then check for loose wires and also check your circuit breaker and check that pump is operable.
To find replacement freeze control, Google search: Intermatic freeze protection thermostat
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 03, 2011 | Intermatic 24 Hour Electronic Timer
I am not sure on how to wire the freeze protection wires to the time clock. i know they must go to the load side of the clock for the main pump but will this reverse the power back into controls and short...
Here's a 240V diagram with clock timer and freeze control:
Add a comment if explanation does not fit your exact timer:
See image full size:
http://waterheatertimer.org/images/Freeze-protection-500.jpg
Here's how freeze control works:
Freeze control is like regular timer, except it turns ON by thermostat instead of time-clock
Freeze control turns ON pump whenever thermostat kicks on.
Both clock-timer and freeze-control are wired to pump in 'parallel' so to speak.
Think of it as having two controls wired to same pump...
Both controls can turn pump ON-OFF.
If one turns ON, and other is OFF ... then pump is ON.
If both are ON, then pump is ON ... and electricity just flows around on extra wires.
If both are OFF, then pump is OFF.
Say it's below freezing all day.
Freeze control circuit is ON all day ... pump is ON all day
Clock timer turns ON > but circuit is already ON, so timer just opens more wires for electricity to flow around on.
When clock timer turns OFF > freeze circuit is still ON because it's below freezing ... pump is still ON.
240V wiring:
Power leads coming from circuit breaker go to terminals 1&3 on clock-timer
Same power leads connect to freeze-control-black and freeze-control-red.
Or connect freeze-control-black and freeze-control-red to terminals 1&3
This action puts power to clock and power to thermostat
Pump wires connect to terminals 2&4
Same pump wires also connect to freeze-control-blue and freeze-control-yellow.
Or connect freeze-control-blue and freeze-control-yellow to terminals 2&4
This action connects pump to both freeze-control and timer.
When either clock-timer or freeze-control turn ON, then pump turns ON.
Nov 15, 2010 | Intermatic Timer PF1222TB Multi Circuit...
My samsung genio touch wont turn on past the loading screen it just freezes how can i fix this?
my samsung genio touch wont turn on past the loading screen it just freezes how can i fix this please i really need ur help
Jul 17, 2010 | Samsung SGH-J600 Cellular Phone
PS2 games load, but freeze up within minutes.
If it is Freezing most Likely answer is your fan is broken/not working.
It would need to be replaced see if you can feel anyair blowing out of it
Dec 06, 2009 | Sony PlayStation 2 (PS2) Console
Game loads then freezes and psp turns off by itself
you have turn off the psp then take out battery then look at laser then move it to the right and put the game in then go to auto start if on turn off then go to ad hoc mode change channel to 6 reboot it
May 10, 2009 | Sony PlayStation Portable (PSP) Console
Freezing computer after loading security cd.
Start your computer in SAFE MODE and remove the norton.
To do that >> Turn off your computer >> turn on ...and before windows loading hit F8 and select SAFE MODE
Nov 05, 2008 | Acer TravelMate 2300 Notebook
My ps3 wont load games or it freezes when it turns on
PS3 is one of the most amazing gaming device but like other competitor gaming devices (Xbox and Wii) It also has some problems like Freezing up. You may check out the informative Article at ezinearticles Remedy for PS3 Freezing up
Aug 31, 2008 | Sony Playstation 3 (PS3) Console
Ac unit freezing up
Either the coil is clogged, the fan is slow, or the freon is low... A solved rating is great motivation to continue giving priceless advise........
Oct 03, 2007 | Samsung AW0603B Air Conditioner
Coby MP-610  MP3 Player Logo
184 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
