Question about Refrigerators
We are getting water draining in our refrigerator
  • 4,059 Answers
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer
Posted on Sep 25, 2009
Water leaks from out of refrigerator.
Hello
Check the drain hole. It gets clogged with food particles:
Locate the drain tubes at the rear of the refrigerator
Push a pipe cleaner through the tubes.
Pour a mild solution of soapy water and ammonia down the drain to clean it.
Check the drain pan under the refrigerator, on the left side, by removing the front grill
If the soapy water hasn't drained into it, it is still clogged
Repeat the steps again until the water drains into the pan
Jun 04, 2015 | Refrigerators
Im getting water under the vegetable drawer inside my LG refrigerator..what can i do?
Hi boris_sal495,
There are two things that you can check if you are getting water under the vegetable drawer. Kindly refer on the details below:
Reminder:Before doing any checking or repair unplug the refrigerator from power and remember your safety.
1. Clear the Drain Tube - Your refrigerator has a drain that leads to the exterior drain pan beneath the refrigerator. Occasionally this drain can become clogged resulting in standing water inside your refrigerator. The drain is located either on the floor of the refrigerator, beneath the vegetable crisper, or in the wall behind a drain funnel.
Clear the drain by forcing a solution of water and bleach or water and baking soda into it with a basting syringe. If the solution will not flow through, slide a length of 1/4 inch or smaller flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog.
2. Leveling a Refrigerator - It is important for the refrigerator to be level.Check that the refrigerator is level from side to side.If it is not level, adjust one or more of the adjustable leveling feet until it is level. The feet are bolts that can be turned to raise or lower the refrigerator. If they cannot be adjusted with your fingers, use a crescent wrench or pliers.
If you have an ice-maker, it should also be checked for level after first leveling the refrigerator. An icemaker that is out of level will spill water into the ice bin or into the freezer. It can be repositioned by loosening the mounting screws, adjusting it for level and then tighten the screws.
Hope it helps.
Thank you for using Fixya.
May 03, 2011 | LG LRTBC1825T Top Freezer Refrigerator
I have an amana abb2522feb bottom freezer refrigerator and need to access the drain pipe. How do I access this? The problem seems to be the drain line is clogged because we get a pool of water about...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 10, 2010 | Amana ARB9059CS Bottom Freezer...
I have water under the crisper drawers in my fridge. The water at the bottom on the ?condenser does not seem to be draining what can I do? Thanks Mary
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Clear the bottom of the refrigerator so you can get at the drain. Then get a turkey baster and fill it with hot water. Insert it in the drain in the bottom and squeeze it cleaning the drain. Several applications will solve the problem, and do not forget the freezer side as well.
Good Luck,
Gilshultz
Dec 01, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
GE Profile with water leaking. Does not seem to be a slow leak. More like an intermittant "dump." Water on floor and refrigerator shelves. Thanks!
Look under the refrigerator and locate the defroster water drain pan. There should be a tube running down the back of the refrigerator which drains water into this pan.
If this tube or other parts of the defroster drain system gets blocked, water can get diverted before it reaches the drain pan.
Oct 16, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
It is leaking water and the bottom of the refrigerator has water
Is water leaking OUTSIDE your refrigerator or INSIDE at the bottom of your refrigerator ? If it is inside your refrigerator the most common reason is a clogged defrost drain tube - The water collects from a defrost cycle and drains through a hole on the ceiling of your refrigerator into a cup that drains it through the tube down to the defrost pan at the bottom of your refrigerator on the back and evaporated by the compressor heat. Sometimes this tube gets clogged and water does not drain from the cup and overflows inside your refrigerator against the backwall.
Aug 16, 2009 | Kenmore Refrigerators
Drains water into the refrigerator when it
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Mar 31, 2009 | Frigidaire FRT18S6AW Top Freezer...
Water leaking into the drain pan
if the pan on the compressor on plug unit get a rag and sock up the water i beleave you doors staying open to long
Mar 16, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool GD25DF auto defrost drain problem
There is a drain hole in the back of the freezer on the bottom. Get back there with some hot water. Most of the time it is just lime build up. Unless you know what feel back there. Another way is to move the freezer out and from the back side you can see the drain line. It just pulls right off
Feb 11, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water is leaking into my refrige
You have a drain in the back of the freezer and a drain on the back of the refrigerator. Check them both to see if the freezer drain is frozen or the refrigerator drain is clogged. Thaw out with a hair dryer and hot water if it is the freezer drain.
Oct 25, 2008 | Kenmore 22422 Top Load Washer
Refrigerators Logo
70 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
