Question about LG 24 in. LDS 5811 Built-in Dishwasher
Lg oe LG SHOW ON MY DISHWASHER OE
  • 725 Answers
Oe is a drain error not drain in 5min
The Drain Hose kinked or blocked. Wiring connection is OK? The drain outlet of sump is blocked. The Drain Pump/Motor or circuit is troubled.
Remove the cause of kink or block. Check the wiring connection. Measure the electric resistance of Drain Motor. (20-40 ) Replace the Drain Motor or repair the Circuit.
Posted on Sep 27, 2009
3 Suggested Answers
SOURCE: oe code on LG dishwasher following garbage disposal replacement
Well, there is the plastic block in the garbage disposal where the drain hose goes on (as not every disposal will be attached to a dishwasher). Punch this out with a screwdriver, fish the plastic plug out with your hand and reattach the hose. You are good to go.
Posted on Dec 01, 2008
  • 572 Answers
SOURCE: What does "OE" mean?
i believe its a drain problem
Posted on Feb 13, 2010
LG front loading washing machine Direct Drive 7 3.5KG Trouble shooting Error OE
go to lg.com, enter your model number and manual will show error codes and fixed for some including OE
Aug 29, 2015 | LG Washing Machines
Our dishwasher keeps stopping its cycle and saying 'OE' It is LG - LD/141ST1
the 'OE' code means clogged or kinked drain line. You will need to pull the dishwasher and disconnect the drain hose from both ends and flush out debris at the sink. Be sure the hose isn't kinked.
Sep 22, 2010 | LG Dishwashers
LG model # LDS5811st stops and displays OE. What does that stand for
Here is a tip that I wrote about the LG OE Code and the causes and fixes...
Here also is the complete list of LG Codes
heatman101
Aug 22, 2010 | LG 24 in. LDS 5811ST Stainless Steel...
Error Code OE
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
May 02, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
Oe code
1st) Blocked drain hose 2nd) Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction) 3rd)Failing drain motor.
Gool Luck!
Apr 01, 2009 | LG Dishwashers
Lg - LDS5811ST Dishwasher OE Error Code
hi
May 11, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
LD-14AW1 keeps coming up with OE error code
Good Luck!!!
Oct 28, 2006 | LG 24 in. LD-12BS6 Stainless Steel...
LG 24 in. LDS 5811 Built-in Dishwasher Logo
468 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
