Question about Samsung SCX 4521F All-In-One Laser Printer
Received fax messages are not printing - Samsung SCX 4521F All-In-One Laser Printer
  • 20 Answers
Firstly check for any error messages on the LCD screen - check all of the cables are plugged in, check for any tiny bits of paper that are inside the printer that might be getting it caught up, then turn it off - leave it for about 5 minutes to just clear our any cached memory that it has and then turn it back on.
Also you could try increasing the memory size (should be avalible through the menu) that usually helps.
Brentwood IT
Posted on Sep 25, 2009
How can I get a FAX Confirmation printed out on the HPJ4680?
If you require printed confirmation that your faxes weresuccessfully sent, follow these instructions to enable fax confirmation beforesending any faxes. The default fax confirmation setting is Off. This meansthat a confirmation report is not printed for each fax sent or received. Aconfirmation message indicating whether a fax was successfully sent appearsbriefly on the control-panel display after each transaction. NOTE: You can include an image of the first page of the faxon the Fax Sent Confirmation report if you choose On Fax Send or Send &Receive, and if you scan the fax to send from memory To enable fax confirmation
1.Press the (Setup) button.
2.Press right arrow to select Print Report, and then press OK.
3.Press right arrow to select Fax Confirmation, and then press OK.
4.Press right arrow to select one of the following, and then press OK. Off Does not print a fax confirmation report when yousend and receive faxes successfully. This is the default setting. On Fax Send Prints a fax confirmation report for every faxyou send.
OnFax Receive Prints a fax confirmation report for every fax you receive.
Send& Receive Prints a fax confirmation report for every fax you send andreceive
Jan 10, 2011 | Office Equipment & Supplies
HP 6310 All-in-One. How do I get a fax confirmation?
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 3.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
On Fax Send Prints a fax confirmation report for every fax you send.
Fax
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and
receive.
Oct 27, 2010 | HP Officejet 6310 All-In-One InkJet...
Error 322 - see printer message
The fixing assembly (The hot rollers) of the printer is faulty. This need to be replaced by a service technician.
Faxes are received in memory because they cannot be printed.
Nov 11, 2009 | Canon FAX-L350 Plain Paper Laser
Canon L100 fax receives messages but doesn't print them
Try to clear the fax, with Menu and #, then clear, and select all. Then from begining enter all parameters ( name, number, reports,... ) it should help.
Aug 10, 2009 | Canon FAX-L1000 Plain Paper Laser
I want to send a fax message using Brother 2820 fax machine, but I don't want the receiver to see my phone number when he receives the fax message print out. Is there any way I can do this?
The FAX machine will print the Tel number that has been programmed in your machine. It does not print on the basis of the caller ID received. So i think if you remove the number programmed in your fax machine
May 23, 2009 | Brother IntelliFax-2820 Laser Fax
Cannot get messages out of memory
We switch our off, wait 10 seconds, switch on & fax is printed. We don't think we have lost any faxes this way but be aware it might happen.
Jan 29, 2009 | OKIFAX 4580 Plain Paper LED Fax
Reg. printing of memory received messages
Yes, after refilling the cartridge, fax in memory automatically print out with charms. :) thanks for your help.
Aug 18, 2008 | Office Equipment & Supplies
Error message says "memorry full" will not let us fax or scan for Konica Minolta 290MF
The FAX machine received some FAXes while it was without paper. Make sure the FAX has paper and try printing the stored faxes or check in the fax menu if they can be cleared without printing.
Another problem may be that the FAX received not faxes but voice messages, retrieve and delete the messages and the error should be gone.
May 05, 2008 | Office Equipment & Supplies
Unable to receive fax
unable to send fax through power line carrier communication. only some part of the document received
Apr 28, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Can't print faxes due to error messages
Please check rear door area for paper, can you use manual feed slot? Power off machine with all jams removed and paper loaded, then power on, can you tell us exact error message/lights that are shown in this state?
Oct 15, 2007 | Brother IntelliFax-2820 Laser Fax
Samsung SCX 4521F All-In-One Laser Printer Logo
107 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
