Question about Drills
Hi, My hammer drill HILTI TE76-ATC has service red light on. How can I solve this problem? Thanks
    Sniper:
  • 61 Answers
Hi. It all depends on the age of it as there are 2 different types of electronics fitted to the TE76.
If you have an early model, the service light came on when the brushes were worn or it was in need of a service. Check your brushes 1st. then to reset the light, simply pull the trigger and hold it untill it resets.
If you have the newer type then you will need to reset the service light by attaching a data reader to the service light. this data reader plugs in to a PC, you will also need the HILTI ODA Software to go with it. Basicaly you need to send it back to hilti to have is serviced and reset. if your machine is less than 2 years old, this is FREE. just phone hilti and ask them to collect it. they will pick it up, service it and get it back to you in 3 working days. if you not sure how old your machine is simply phone Hilti and ask them, quoting the serial number. this is etched into the plastic on the left side of the machine underneath the white writing on the motor housing. Good Luck
Posted on Oct 11, 2009
Testimonial: "Thanks"
    Problem Solver:
  • 4 Answers
Test kit is available to run drill without electronics.
Posted on Oct 31, 2013
  • 80 Answers
Carbon brushes probably faded / need replacement
Posted on Oct 07, 2009
How do you remove a stuck bit in the chuck of a TE 17 Hilti hammer drill?
Hilti TE56 SDS max stuck chisel remove - YouTube
? 7:10
https://www.youtube.com/watch?v=rmpvYuEvbIk
Jun 22, 2017 - Uploaded by Power tools fix
Hello, In this video you will see how to remove stuck chisel in Hilti demolition hammer. Same can be made for ...
Hilti SFC 22 A chuck removal and Makita chuck replacement - YouTube
? 7:12
https://www.youtube.com/watch?v=gkjBs0f0upg
Sep 15, 2017 - Uploaded by Power tools fix
Hello, In this video you will see how I removed Hilti SFC 22 A cordlessdrill chuck. I replaced genuine Hilti ...
Hilti TE76 stuck chisel remove and repair - YouTube
? 12:53
https://www.youtube.com/watch?v=v3ckL1lQ-2E&vl=cs
Nov 26, 2017 - Uploaded by Power tools fix
Hello, In this video you will see how to remove stuck chisel for Hilti Te76 demolition hammer. Same can be ...
How to disassemble and find problem in for Hilti TE 7 C rotary hammer ...
? 17:45
https://www.youtube.com/watch?v=4yY97AAHPO4 Feb 7, 2017 - Uploaded by Power tools fix
In this video you will see how to find problem in Hilti rotary hammer drill TE 7 C -~-~~-~~~-~~-~- Please ...
remove stuck bit in the chuck of TE 17 Hilti Google Search
Jun 12, 2018 | Hilti Drills
How to reset service light on hilti te 76 atc??
Only factory service can reset certain faults.
Sep 17, 2012 | Drills
How to reset te76 atc module
Eto rabotaet. Spasibo!
Its working. Thanks!
Apr 07, 2012 | Hilti TE 70 Hammer Drill Performance...
Need a rotor for hilti te76-atc part #330427
In the states contact Hilti @ 1-800-879-8000
Aug 17, 2011 | Hilti Drills
How to reset Active Torque Control in the handle of Hilti model TE76P-ATC Rotary Hammer Drill
Active Torque Control (only TE 76-ATC / TE 76P-ATC)
The TE76-ATC / TE 76P-ATC is equipped with the Active
Torque Control system in addition to the mechanical
torque limiting clutch. This system offers additional protection
while drilling by rapid shutdown upon uncontrolled
rotation in the axis of the drill bit, e. g. when the
drill bit jams due to hitting rebar or when the insert tool
is tilted unintentionally.
When the ATC system has become activated, the tool
can be restarted by releasing the control switch and reengaging
it after the the motor has stopped rotating
("click"-sound signals readiness for use).
Always choose a working position in which the electric
tool is free to rotate in a counter-clockwise direction
(as seen by the operator). If this is not possible, the ATC
system cannot react.
Mar 01, 2011 | Hilti Drills
Te76 will run but will not hammer
THE TOOL IS LOW ON OIL. OR POSSILBE SEAL ISSUE, IT TAKES ITS OWN OIL, HAVE TO GET IT FROM HILTI!!! BE PREPARED YOU HAVE TO BUY A GALLON AT A TIME! IT HURTS!!! OR YOU CAN SEND IT TO HILTI AND YES THEY WILL BE MORE THAN HAPPY TO FIX IT FOR YOU OR GIVE YOU CREDIT TOWARD A NEW ONE, THATS HOW THEY WORK!
Aug 13, 2010 | Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13...
Red service light on ,have checked brushes and they are as new, won't operate at all
Sep 24, 2009 | Hilti Drills
Hilti 76 p atc
Hi . The solution offered by rowdy (pull the trigger and hold it until light goes out) will only work on older machines, the newer machines have more complex electronics that need reseting using an optical reader which plugs into a PC , you will also need the Hilti ODA Software. this is not available to the general public. you may have to send it back to hilti for service and reset. this is free if the machine is less than 2 years old.
Jul 02, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
Hilti Hammer Drill 76p atc wont spin, has flashing led
Sounds like it needs new brushes. Schematics can be found on hilti.com. tech support - rotary hammers/ combi. Look up model number. Some of the older stuff is obsolete. Should find info there.Please rate me
Apr 01, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
Problem with Hilti JackHammer TE76
Yes there is but it is somewhat confusing to navigate. It is Hilti.com. If you can give me some idea what parts you are looking for I have that breakdown at work and will help you. It is the TE76. Let me know and I will do what I can or you can call their toll free number in the US at 1-800-879-8000 and ask them for help also
Jan 25, 2009 | Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13...
Drills Logo
8,049 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
