Question about liftmaster Chamberlain Garage Door Opener Transmitter 300MC
Cannot get any remote to operate the door opener. I've checked this w/ another remote which does work when used to operate another door. It appears I'm not able to reprogam the remote that came w/ the door opener (1/2 HP Chamberlain 1996 mfg'd date) per the directions on the power unit. This was initially noticed when the factory remote in the car rear view mirror was not working. Any thoughts
  • 3 Answers
Typically the remote codes are stored on the controller board (called logic board). if the wall switch for your opener still works, but you are unable to reprogram the existing remotes that came with the unit (assuming of course you checked batteries in the remotes) then it is likely that the logic board has died. Given that the opener is 13 years old, this is not unexpected. New openers have a host of new features including advanced security, so it might be a good time to invest in a new one.
Posted on Sep 25, 2009
What is wrong with my hummer H3 locks. Neither the keyless remote nor the lock button from the door can open all the passenger doors. When I press the Keyless remote or the door lock button, it open the...
Check the relays in the fuse box. It appears that the solenoids for locking the doors are working correctly. However it appears that the lock solenoid is not working properly.
Jan 30, 2015 | 2007 Hummer H3
2008 HHR Remote Starter not working
Is this an issue with all 2008 HHR remotes??? Highly doubtful , probably the vehicles keyless entry system . Taking the vehicle to a qualified repair shop an having the keyless entry system checked for DTC'S - diagnostic trouble code's . Do you know what a DTC is ?
The keyless entry system is a vehicle entry device. The keyless entry system is used in conjunction with the body control module (BCM) to remotely activate certain vehicle features. Keyless entry will lock/unlock the doors, or release the rear compartment lid when a corresponding button on the keyless entry transmitter is pressed. This is accomplished by the transmitter sending a radio frequency to the remote control door lock receiver (RCDLR). The RCDLR interprets the signal and activates the requested function via a serial data message to the BCM. A low transmitter or vehicle battery or radio frequency (RF) interference from aftermarket devices, such as 2-way radios, power inverters, computers, etc., may cause a system malfunction. High RF traffic areas may also cause interference that could lead to a malfunction. Keyless entry allows you to operate the following components:
• Door locks
• Liftgate lock
• Remote rear doors (Panel only)
• Vehicle locator/panic alarm
• Illuminated entry lamps
• Remote vehicle start
The keyless entry system has the following components:
• Keyless entry transmitters
• Keyless entry antenna
• 2 Way Advanced Remote Start RCDLR
• BCM
Guessing will not fix this .
Jan 12, 2018 | 2006 Chevrolet HHR
How to make my philips DVP3747 region free
Here is a hack that I've found to work on many Philips machines.
Turn on Player
Using Remote Control open the Disk Tray (and leave open)
Using Remote Control Press SetUp
Using Remote Control Scroll To Preference using Left / Right Arrow keys (Just Highlight it do NOT select it)
Using Remote Control Press 1 3 8 9 3 1
Region Menu Screen Should Appear
Using Remote Control Select Desired Region Using Up / Down Arrow Keys (0 [Zero] For Region Free)
Hope this helps.
Jun 18, 2011 | Televison & Video
Intermittent remote trouble
Your wall control is hard wired and doesn't use the receiver portion of the logic board. The remotes do. Your receiver is going bad.
Jan 12, 2010 | Sears Craftsman LiftMaster Chamberlain...
Driver door unable to lock or open using the remote - 2002 Galant
If you can unlock it with the key,and not the remote, then it sounds like the lock actuator is not working in that door.In order to check it, the door panel has to come off.
Jan 26, 2009 | 1991 Mitsubishi Galant
Programing garage door opener remote
ok crystal,calm down this is an easy one! first locate the smart button on your openers , next you will press and hold down the smart button until you see an indicator light above it shut off, while your holding that button the light will be solid ,Now your ready to program your remotes ,first programm one side by taking each of your four remotes and pressing the smart button on machine then pressing the button on the remote you want to program,by doing that you will notice the lightbulbs on your machine shut off and go back on , This is an indicator that your machine has accepted the code , now do it with the other three remotes , after you,ve programmed all four ,go over to the other machine and repeat the process but this time you have to choose another button on your remotes since you,ve programmed all four remotes to the same button on each remote ,just choose the bottom button on your remotes this time to keep them seperated , hope this helps you and it is as easy as 1-2-3 your owners manual will describe exactly the same ,i know because i,ve installed over 27,000 machines working as an installer for sears, please leave a nice feedback rating if i was able to help you, good luck,Sincerely Glenn Mayer
Mar 12, 2008 | Sears Craftsman LiftMaster Chamberlain...
liftmaster Chamberlain Garage Door Opener Transmitter 300MC Logo
454 people viewed this question
Top liftmaster Electrical Supplies Experts
Mike
Gil Shultz
ray gallant
Are you a liftmaster Electrical Supply Expert? Answer questions, earn points and help others
