Question about Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX
My poulan pro 42cc will not start i get sparks from spark plug,but when i put the plug back in i get nothing
    President:
  • 2,220 Answers
If you have spark and compression it must not be getting fuel.
Put a little mix directly into the carburetor and try to start it. If it pops and doesn't continue to run look at your fuel lines. I think you have a cracked hose. HTH
Lou
Posted on Sep 25, 2009
What is the spark gap for 221 pro 40cc
The gap for all Poulan chainsaws, regardless of the spark plug used, is .025.
Jun 12, 2014 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Where is the spark plug on a poulan pro 42cc
remove the top cover i think 4 screws the plug is under there
Sep 03, 2012 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have a poulon pro 42cc saw that wont start. dont think its getting gas cuz i tried to flood it with the primer but no gas on the spark plug.
The primer will not flood it, all the primer does on these saws is pushes fuel through the carb. If this is a new saw, it needs a carb adjustment, a very common problem on poulan products these days. It's covered by the warranty at any of their service dealers (you can locate one on poulan's website).
How old is the gas you are using? If the mixture is more than 30 days old, make a new mix and try again.
Check for spark. Pull the boot off of the plug. Hold the boot near something metal and pull the starter. If you see a spark, you are good. If you don't, you may have a problem with the coil.
Aug 26, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have a 18 in poulan pro that want run. has new plug, air filter,gas filter
Check if is any "spark" at the spark plug.If not change the "coil" =spark plug cable and coil all are together.
Nov 09, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Stopped running after 20 min., repeatedly tried to restart. Have not been able to start it since
This could be caused by several things but most likely it is a cracked fuel line. The lines of these get brittle and break from vibration over time. First I would make sure I have spark by pulling the spark plug and put the plug boot back on the spark plug. Then with you foot holding the saw firmly in place, ground the spark plug on the metal portion of the engine block away from the spark plug hole. Pull the cord and see if the spark plug is firing across the tip. If so, I would look very closely for a broken fuel line.
I hope this helps you isolate the problem.
Jun 21, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
No spark from spark plug
New Saw? Warranty time
Electronic ignition? Replace entire module. Pinched wire to metal case part for ignition switch. Permanently shorted ignition switch--replace.
Jun 27, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan PP4218AUX will not start
I have a 42 cc 14"bar will not start. poulan chain saw.
Feb 18, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX Logo
310 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
