Question about Kitchen Ranges
My Westinghouse Freestyle 808 oven is not heating
My Westinghouse Freestyle 808 oven is not heating up. The fan seems to be working.
  • 833 Answers
SOURCE: electric westinghouse freestyle oven not
This might be a couple of things:
  • Check circuit breakers...there are two that control the oven in tandem. Is one blown open? Turn both off and then on.
  • Check all wiring to the unit. You may have an open wire anywhere in the line including at the terminals in the oven. Make sure breakers are off to do this and all below.
  • Remove the element and check for resistance. There should be some. Also check the element terminals and the plug in the oven for corrosion while you're at it.
  • None of those: the thermostat or over temp sensor might be bad. Find these by looking at the wiring diagram on the back of the stove and tracing out the wiring.
  • Electronics package. Replace if none of the above.
Posted on Jun 16, 2008
SOURCE: Westinghouse 808 freestyle
try holding the time (first button from left) and button beside together then the + or -
hope it works good luck.
Posted on Oct 07, 2008
SOURCE: I have a Westinghouse Freestyle
remove burner see if a hole is melted on glowing ignitor end repair with s/s welding if ok replace ignitor hsi assy w/o old 1 may appear ok but resistance values are out gas valve wont open if still dont work replace valve thermal hsi single should replace both these item anyway.this is assistance advice only do at own risk it worked for me madog cheers.
Posted on Oct 29, 2008
SOURCE: steps required to replace 2200watt
Symptoms= Oven light ok, thermostat light ok, oven not heating at all or to a low heat. May also have tripped the circuit breaker on the switchboard
Probably the element
Switch off power to the oven at switchboard
Open the oven door just a little and pull the door up to remove it.
Lift the panel at the oven back wall over the fan.
See the coiled element, you may already see a defect in the surface of the element.
Remove the screw at the base of the coil
With a small sharp screwdriver flip out the clip on each side of the element at the top
Feed the element out of the holes
Note that the green wire is attached to the frame of the element and the red wire to the core of the element.
The other side of the element may have two white wires
Disconnect all these wires, maybe using a pliers.
You can check this element with a simply multimeter, buy a new element and refit opposite to removal
Posted on Oct 03, 2010
SOURCE: Westinghouse Freestyle 662 Oven Fan &
its the element
Posted on Sep 02, 2011
How to adjust flame on Westinghouse freestyle gas oven
The flame is regulated by the thermostat you don't say if it's too high or too low. Suggest you buy an oven thermometer available for a few dollars at most homeware shops, compare the temperatures then you will see if the thermostat is working or not.
Apr 22, 2014 | Cooktops
Hi there, I've got a westinghouse freestyle 521 glass stove top and fan forced oven. Just recently when in use the oven stopped working, although the light and fan remained on. Is there anything like a...
Sorry to read about your problem, I hope this helps you out.
sorry their is no simple fuse for what you are writing about, you may just have defective heat elements.or open thermal switches. and they are not easy to check
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Dec 30, 2010 | Ovens
I need to replace the element on my westinghouse freestyle 808 oven . where can i order one how do i change the element? thanx
pull the unit out of the housing and rest on a suitable work bench. turn off the power and remove the rear cover you will see the grill element, ring element and the bottom element. depending on whcih one has blown they are relatively straight forward to replace.
as for where to purchase one depends on what country and area you live in. best to search for someone local on line
Aug 19, 2010 | Ovens
Need an instruction manual for Westinghouse freestyle 745 wall oven, preferably in PDF, having trouble setting the clock. Can you help please?
instructions-manuals.com/search.php?...WESTINGHOUSE%20FREESTYLE...FREESTYLE%20920%20DISHWASHER
safemanuals.com/index_upload.php
www.manualsnguides.com/search.php?...WESTINGHOUSE%20FREESTYLE......
You can copy and paste any of the above links in your internet address bar under a new tab to bring you to your manual
Nov 12, 2009 | Ovens
My westinghouse freestyle frost free 650 litre is
The fridge need to be devrosted open up freezer door take back of and look if all ice gone from freezing rods restart if same prob it looks like fan not going or heating element not workingon
Nov 08, 2009 | Westinghouse Refrigerators
What wire goes where for my Westinghouse Freestyle elements?
oven wiring has the same conventions as house wiring.
green = earth, outside coating
brown or white = one of core ends
black = the other end
Jul 13, 2008 | Ovens
I have a Westinghouse Freestyle 472 gas oven that wont light. The igniter seems to start glowing, the fan runs and the grill works but no gas seems to flow.
May 14, 2008 | Kitchen Ranges
Mar 06, 2008 | Kitchen Ranges
Kitchen Ranges Logo
151 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
