Question about Sony Cyber-shot DSC-T500 Digital Camera
Camera keeps reporting "reinsert memory card" when memory card is correctly inserted
hichama9
  • 65 Answers
SOURCE: have a DSC-S930 camera inserted my memory stick
Hello Mate,
you may double check how you inserted the memory stick, it may be in wrong position.
other than that, you can insert this memory stick into your computer and see if you can open it from there. and you can also format it from your computer and then test it again with your camera.
Best Regards,
Posted on Oct 31, 2009
drifterK
  • 4924 Answers
SOURCE: screen says reinsert the memory stick but memory
get the card out ..be sure it is no locked...and it is inserted in the proper way ..if it still says the same after this ..verify the card into a card reader to see if it is ok ..cause if it is damaged the camera will not see it .....If you just replaced this card and it is new ..be sure you format it in Fat 32 before using (can be done in computer or in the camera ) ..also be sure that the camera is supporting the size of the card if it is a new one and never used before in this camera ..
Posted on Feb 27, 2010
  • 411 Answers
SOURCE: reinsert memory stick
contacts of the memory stick clean it
Posted on Mar 01, 2010
  • 102366 Answers
SOURCE: How do I reinsert my memory card
Assuming that your Cyber-shot is a DSC-W80, press the HOME button to bring up the menu. Select Manage Memory (memory stick icon). Select Memory Tool, then Memory Stick Too, then Format.
Posted on Jun 08, 2010
SOURCE: Error message: Reinsert the Memory Stick"
The problem is with the memory card. It probably just shorted internally and is no longer useful. The amount of memory is not the problem, as I used a 4GB card for a long time and my card finally went bad. You will just have to get another memory card and MAYBE find someone to be able to retrieve your data.
Posted on Jul 05, 2010
Camera keeps telling me to reinsert the memory card. I've tried to new cards. When I put the memory card I was replacing because it is full, it goes back into the camera just fine.
As a last resort you could copy the full card to a computer and then delete the pictures on the card and use that again.
Here is the error list from the camera manual.
This is all I can suggest from here.
"Reinsert the Memory Stick Error"
Insert the "Memory Stick Duo" correctly.
The inserted "Memory Stick Duo"cannot be used in your camera
(See below).
The "Memory Stick Duo" is damaged.
The terminal section of the "Memory Stick Duo" is dirty
Compatible cards.
Memory Stick Duo (without MagicGate)
Memory Stick Duo (with MagicGate) *1 *2
MagicGate Memory Stick Duo *1
Memory Stick PRO Duo *1 *2
NOT compatible
Memory Stick (without MagicGate)
Memory Stick (with MagicGate)
Memory Stick PRO
Some Memory Stick Duo have a write protect switch on the back.
You cannot record, edit or delete images if you
slide the write-protect switch to LOCK with a
fine-tipped object
*1
"Memory Stick Duo", "MagicGate Memory
Stick Duo" and "Memory Stick PRO Duo" are
equipped with MagicGate functions.
MagicGate is copyright protection technology
that uses encryption technology. Data
recording/playback th
at requires MagicGate
functions cannot be performed with this
camera.
*2
Supports high-speed data transfer using a
parallel interface.
Oct 12, 2014 | Sony Cybershot S650 Digital Camera
I bought a camera which is dsc-w650 has problem when i insert the memory it displays that the image database error can not resolve, so how do i solve the problem pls help me
Where did you check the memory card? in the computer? that is not the right place. Every card, old or new, you use in a camera for the first time should be formatted in the camera. First you must be 100% sure it is the correct card. Not every memory stick Sony has, can be used in every camera. So check the manual, what Duo, Pro or other memory card should go into your camera. Check if you have the correct card. Then if the card was used before, check if no pictures are on the card (external memory card reader) and save the pictures to the computer. Then format the card. If you can't format the card in the camera, try to format it in the external memory card reader. Use FAT32. Then reinsert the card in the camera and again try to format the card. If nothing goes, try another (correct) card to make sure nothing is wrong with the camera.
Mar 09, 2014 | Sony Cyber-Shot DSC-W560 Digital Camera
Sony Cyber-shot DSC-W370 says reinsert memory card. We have reinsert the card correctly but it continues to say that. Is the camera beyond repair?
you'll make sure that you camera is not the problem is when you insert other memory card that is working on other cameras. if that doesn't work at all try to look for any foreign object that block memory card insertion contacts or you can buy a contact cleaner spray for electronic parts and spray it on the memory card holder part of the camera.
May 28, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
How to fix "reinsert memory
Welcome to FixYa.
There 3 possible causes why do you received an error message " reinsert memory card"
Cause
1 The inserted Memory Stick media is not supported for use with the camera.
2 The terminals on the Memory Stick media are dirty.
3 The Memory Stick media is damaged
Resolution
1 Ensure you are using the supported type and capacity of Memory Stick media for use with the camera
2 Use a clean pencil eraser and lightly rub the Memory Stick terminals to remove any oxidation or dirt build-up
3 Use different Memory Stick media
I hope this steps wil help you to resolve your isuues.
Thank you for using FixYa.
Apr 04, 2011 | Sony Cybershot DSCW310 Digital Camera
I inserted kinston 4gb card in my digital camera , while in the unlocked position of switch.But camera shows "memory card error" "card locked"
  • There is a write-protection tab on the mini sd card HOLDER. Every time you insert this into your PC or card holder, this tab slides to the write protect position. Either keep resetting, inserting & reinserting until it doesn't slide or tape it down.
  • There is nothing wrong with the mini sd card. Simply locate the write protection key and push it.
  • The mini sd card has some error: Go for a low level formatting.
  • The card has virus: Remove the virus. The link for the steps is present in the related link at the bottom of the article.
  • Read more: http://wiki.answers.com/Q/How_do_you_remove_write_protection_from_a_mini_SD_card#ixzz1Fvsnj1XE
    Mar 07, 2011 | Kingston 4GB Secure Digital High Capacity...
    Hi: My Sony camera keeps telling me to reinsert the Memory Stick which I do but keep getting the message. What is solution? Thanks!
    Dear Friend,
    Try Following...you will be Solved..
    • Insert your MMC in to a GOOD card reader and Check .. (any damage )
    • Insert in to CAM
    • If still same,Insert another MMC in to your Cam
    • Still same,Then Check your MMC jack(any Contacts damaged)
    • Then you have to Manual Repair your CAM
    YOu are Done..
    Is this Text Helped You .. Do Rate Me... YOu can Feel Free Contact me.. Thanks For Using FixYa
    Apr 01, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
    Camera will not turn on. Already replaced batteries.
    as per your camment you already replace the battry thats means no problem in battery Ok Firstly please follw the steps,remove memory card(if have),power resourses like AC power adaptor and batteries and wait some some just about 10 min,than reinsert the battrie and AC power adaptor,swith on the camera without memory card,if it is work and than insert ithe memory card otherwise reinsurt the memory card correctly and close the memory card door properly if the camera working fine other wise follw the third instuction that check the AC power supply,this is connect properly through input or not.connect the properly and turn on the camera and check issue is resolved
    If you not find the solution thats means your camera has been damaged,need the service of camera and second resion is if you insert the battry incorrectly ,some issue
    One more resion is images in memory card,firstly download ths images in system and formate the card.
    Thanks,
    Jan 16, 2010 | Sony Cyber-Shot DSC-F707 Digital Camera
    Says to reinsert memory card & card is in camera. Try another card & says memory stick formatting error
    i have the same problem..
    I have a Sony Cybershot DSC T70 and it keeps saying "Reinsert memory stick" whenever I turn on the camera or slide down the camera lid. Also, whenever I try to view the pictures on my laptop it shows "Please reinsert the memory stick" something along those lines. As I have been researching for the solution, I would have to format the memory card. However, I wouldn't want to lose the pictures as I just took many as from the holiday last week. The only problem is the memory card, I tried using another memory card and it works fine with the camera. There is nothing wrong with the camera.\r\nCan someone please help me how to solve the memory stick problem? It would be great. Ty.
    Oct 17, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
    Aug 09, 2009 | Sony Cybershot DSC-S950 Digital Camera
    Sony Cyber-shot DSC-T500 Digital Camera Logo
    22 people viewed this question
    Top Sony Cameras Experts
    james laughton
    james laughton
    Are you a Sony Camera Expert? Answer questions, earn points and help others
