Question about Samsung ML 1610 Laser Printer
My samsung 1610 priner gives cartridge error and doesnt print even after changing cartridges.
    Guru:
  • 389 Answers
Samsung ML-1610/1640/1641/1645. Removing of protection from leading-in.
First go распечатайте the page of the report with buttons of the printer. If in report Engine Version 1.00.50 and above, that necessary reprogram printer by applicable lace trim.
The Completion reprograms printer will индифицировать blinking orange indicator. For termination of the process necessary simply to disconnect him(it) from network and include once again.
If in report Engine Version BELOW 1.00.50, that executes the watching actions:
1. We Remove the back lid of the device ( two самореза and three защелки).
2. We Disconnect the connector "CRUM" (this procedure device is broken of from chip).
3. We Disconnect the connector "DEVE" and замыкаем the connector on charge форматтера джампером from winchester. (this procedure device is broken of from "гвоздя" - an identifier start картриджа).
4. We Find on charge MS memories 93С66 (a litle down central processor).
5. We Seal the jumper between 1 and 4 drumsticks of the microcircuit (sm.risunok).
6. We Collect the device.
7. After вышеупомянутых procedures device ceases to respond to chip and "gvozdi"-identifier.
Kartridzhi possible to fuel without problems. For unset of the counter of the lifelength it is enough to unplug the printer from network by breaker and include him(it) again. The Counters will be discarded. (The Note : are not scared speed work counter, after запайки of the jumper. The Printer will consider (about) 1 unsealled sheet = 1 % consuption of the toner).
8. After altering possible to use any cartridges serieses ML-1610,1615,2015 and Xerox 3117. The Key in printer no.
On drawing below - a type of the printer behind, explaining all necessary actions.
Samsung ML-1640/1641/1645. Removing of protection from leading-in.My samsung 1610 priner gives cartridge error and - b614426.jpg
Posted on Sep 25, 2009
My printing colour is not dark enough to be readable. I changed another new toner cartridge but the prints were still the same
Hi..
Not just the print cartridge but make sure that the "Print Head" is also working fine. ink clogging has not taken place on print head.... Print head is a hardware, on which cartridge is attached.
Hope this has helped you.. Thanks..
Sep 29, 2010 | Samsung ML 1610 Laser Printer
My samsung ml 1610 laser printer is working but in printing pages or not clear.. in toner drum are pour by some black dust at every print even though i clean it again it come.. but still my printer not...
The problem may be the toner cartridge itself. You may need to get a new toner and clean the printer, again. Once the printer is clean re-place the new toner cartridge.
Jan 06, 2010 | Samsung ML 1610 Laser Printer
Samsung ml1610 gives faint print. (even self print) is this because of drum or blade or toner powder?
Try checking out your toner cartridge on other printer or another toner cart on your printer if you get the print fine on your printer then your toner is troubling or else the mainboard of your printer is problem which is not allowing proper flow of toner on paper.
Sep 02, 2009 | Samsung ML 1610 Laser Printer
How do i change ink cartridge in samsung ml-1610 laser printer
its very simple just pull the front door it will be opened.then u will see the black cartridge handel .then slowly pull that handle the cartridge will be removed.in the same way insert the replacement cartridge.
Nov 29, 2008 | Samsung ML 1610 Laser Printer
On Line/Error Flashes then goes red
remove the cartridge and reisert it .and for your knowledge that when you insert the cartridge you will hear a click that means the cartridge is fitted properly.if you do not hear a click that means the cartridge is not installed properly.
Oct 29, 2008 | Samsung ML 1610 Laser Printer
Missing Toner Cartridge
Try first removing all paper from paper trays and then reinserting cartridge, etc.
Sep 23, 2008 | HP LaserJet 3050 All-In-One Printer
ML1610 SAMSUNG PRINTER PROBLEM
The online/error light is always red, and I can't print. I turn the printer off, change the toner and the light is still red, what can I do
Sep 13, 2008 | Samsung ML 1610 Laser Printer
Remove and checl color cartridge
The problem most likely is with the electrical contact between the color cartridge and print carriage. Even if you've replaced the cartridge, if the contacts on the carriage are still dirty, it won't make a good connection with the new cartridge and the error message will still appear.
Fortunately, the HP web site has a solution posted at the following link:
Cleaning Cartridge and Print Carriage Contacts
Good luck.
Sep 04, 2008 | HP PSC 1610 All-In-One InkJet Printer
CARTRIDGE WONT ALIGN
The following error message appears on the LCD panel1.gif on top of the printer after you insert a cartridge: Press enter to align cartridges . You press Enter , but the error message does not go away. The printer will not print. Solution To bypass the cartridge alignment, do the following:
  1. Press and hold the Setup button.
  2. Press the Options button. The printer should be ready to print.
If the print quality is unacceptable after bypassing alignment, follow the steps below until the error is corrected.
Feb 13, 2008 | HP PSC 2210 All-In-One InkJet Printer
Samsung ML 1610 Laser Printer Logo
2,670 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
