Question about Goldstar MV-1501 Microwave Oven
Power is on, lights and front panel work, just no heat
Power is on, lights and everything on the display panel works. Problem is there is no heat.
  • 909 Answers
There are a few definite causes but if you would like to rectify problem without messing around, i wold replace magnatron: capacitor and HV diode.That will certainly sort the problem out.
Posted on Sep 25, 2009
Testimonial: "I believe you're right. Thanks for the quick response!"
Swan SM2050 microwave - everything works (light, turntable, LCD display) except it only sometimes heats and other times starts to heat but will then stop heating whilst everything else continues to...
you not going to like me now!!!! in two words,,,,,dump it,,,, your microwave is well past its best,,to fix it will cost more than its worth, and to be honest there getting cheaper by the day now?
Nov 28, 2010 | Microwave Ovens
Sharp Microwave diplay light not working
We regularly repair these display / control units nationwide by mail for $39.95 postpaid with a one year guarantee.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Jul 07, 2010 | Sharp Microwave Ovens
The buttons on the front stopped working, no display
It is still under warrantee if under a year. Contact your dealer who you bought it from-it should be repaired or replaced free of charge.
Oct 03, 2009 | Microwave Ovens
Everything works except the heating of food, etc.
When the magnitron fails it will do one of two things, it will give no microwave action to the centerplate or it increases in strenghth many times to where it is very hazardous. Yours appears to be the first case. I;'m assuming that you've checked the fuse on the board, seeing you were already back in there to check the harness to the magnitron.
Sep 07, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
All the lights and features work, but no heat. Will not cook.
9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section. Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay..... Q - The microwave display counts down and the inside light is on, but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
Jul 11, 2009 | Maytag MMV4205 Microwave Oven
Micro wave is not working
don't know about the red light, but (fancy this) I had the same problem with my microwave tonight. Everything but heat worked. Unplug it, plug it back in. Worked for my GE Spacemaker.
Jan 27, 2009 | Emerson Microwave Ovens
Kenmore Microwave Hood Combination: over the stove Model #721.80602500
Disclaimer: I'm a DIYer, not a technician.
Our GE over-the-range microwave stopped producing heat yesterday while warming part of the T-giving feast. Everything else (fan, control panel, light) works fine.
After disassembly and testing last night, I discovered a defective "secondary door switch." Your Kenmore uses a similar switch (~$19 on-line), and that might be the problem. But it also could be other things, such as a bad thermal cut-out.
If you know anyone who's handy with a multimeter, most of the basic diagnostics seem to be pretty straightforward.
Nov 23, 2007 | Kenmore 62622 Microwave Oven
No heating
there is a relay on front panel this sends voltage to mwave needs to be replaced or dryjointed open front panel and check for little boxes on front panel those are relays
Jul 28, 2007 | Whirlpool MH6141XK Microwave Oven
Goldstar MV-1501 Microwave Oven Logo
378 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
