Question about ViewSonic N2750w 27 in. HD-Ready LCD Television
TV just turns itself off
I have a five month old set that has started to turn itself off with no apparent consistency (it could be an hour after i turned it on or ten minutes or three hours) I wonder about the sleep function but the inconsistent nature is baffling.
  • 3 more comments
  • Anonymous Jan 03, 2008
    I have the exact same problem. My tv will turn itself on and off at its own will. Sometimes it gets to the point where I can't even keep the tv on for more than 10 seconds. I've tried a memory recall on it but to no avail.
  • cl0netr0oper Nov 08, 2008
    I have the exact same problem. This just started 3 days ago. It happened last year too, but somehow it worked 1 day after, now its back :-(
  • anim526 Nov 10, 2008
    The volume level goes to the maximum, the menu appears randomly and the set cuts off also at random.
  • Anonymous Jan 13, 2009
    I have the same problem. The tv turns off and on for no apparent reason. I checked the power cord and even switched the outlet, but same problem. Any ideas on how to fix this or the cause of the problem is appreciated.
  • Anonymous Apr 08, 2009
    We got the same problem. The TV turn itself on in the middle of the night at random. It also started to turn off in the middle of the day. We had it repaired in Sept.08 for turning itself off at random. I guess whatever they did lasted hardly 6 months..... But now the turning ON in the middle of the night is real problem when we try to sleep!
    Sergeant:
  • 395 Answers
Does this happen at night or dark days when lights are on? if so you might be using CFL lights which interer with IR info to the set. it can cause other problems such as random cannel change or no remote responce.
Posted on Jan 17, 2008
Why Intermitant Power Loss
Its probably a Power Supply failure replacing it will mostly fix your problem
Jun 20, 2014 | LG 42LD550 42 in. TV
Wharfedale TV power problems
the problem occurs in ur main board...check all tge resistor in board...the faulty resistor will; allow high voltage to the main board and affect it
Oct 31, 2008 | Televison & Video
My LG Plasma 42PC1DV turns on but freezes, the picture is frozen but the sound stays on...the it takes a long time for it to turn off. when you turn it back on the picture goes fro about 3 seconds and does...
hi wendy, I have the same model tv and it has been doing exactly the same problem you have ever since buying it (2007 - 08) and every time it does freeze it seems to be on channel 9. The only way i overcome this problem is to turn the tv off at the wall for atleast an hour and turn it back on and it seems to re-set itself or should i say the built in set top box re-sets itself and it works fine for a few months and bang it does it again. Apparently there is a LG software update but only technicians can install this. Anyway thats my story! :)
Aug 11, 2010 | LG Televison & Video
Sylvania LD320SSX turns off by itself.
your powersupply is dying in the set.. have it checked..
Apr 10, 2010 | Sylvania LD320SSX LCD TV
Cant turn off att lg vu 920
CHANGE YOUR KEY PAD AND REFRESH YOUR CELL PHONE SOFTWARE
Oct 06, 2009 | LG Vu CU920 Cellular Phone
My mitsubishi tv model ws55908 will just turn itself off after I have been watching it. It could be as soon as 1 or two hours or 4. it does not happen all the time I can go a month without it happening...
This TV has a self diagnosis feature. When the set fails, push "menu" and "input": buttons at the same time and hold them in for more than 5 seconds. Watch the front panel light. It will blink two numbers five times. Get back to me with the numbers.
Apr 15, 2009 | Mitsubishi WS-65908 TV
Samsung dlp HL56A65 turns off and on by itself
It looks power board problem.
You need to get service from Samsung.
Mar 04, 2009 | Samsung DLP HL-P5663W 56" TV
Tv cliking wont power up
The tic tic sound is a device called safety switch that keeps turning your TV off because an internal fault, such as a defective component or a wrong voltage is detected.
When is like that we say the tv is in protected mode.
Start unplugging TV power cord for one or two hours (it is called hard reset), this will drain power from tv and seset internal circuit, and sometimes can clear the error message, if the fault was only temporary.
If the problem does not go, probably some component inside the tv is faulty and may need to be replaced.
If the tv is one month old, it should be covered by warranty, call the phone number listed on the TV owner manual.
Sep 19, 2008 | Televison & Video
Toshiba 46H84 turning off by itself AND all BLUE screen with Black Dot in Center
Try to replug everything in the TV. Before you turn it on. make sure all plugs in the TV to the wall is plug in tight. When you turn your TV on hold the power button down to see if it resets
Feb 28, 2017 | Toshiba 46H84 46" Rear Projection...
ViewSonic N2750w 27 in. HD-Ready LCD Television Logo
342 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
