Question about Acer Aspire 3680 Laptop
Acer aspire 3680 only runs on battery - won't hold charge from a/c adapter
  • 46 Answers
Go into the control panel and then power settings check wich power source is the default you can change it
Posted on Sep 25, 2009
I used it the night before it was fine i plugged in the charge and it wont turn on at all
laptop charger for acer aspire 3600 3680 series 3650 3610
www.amazon.com/LAPTOP-CHARGER-ACER-ASPI...
Amazon.com, Inc.Amazon.com: LAPTOP CHARGER FOR ACER ASPIRE 3600 3680 SERIES 3650 ...When I was looking for a charger cable for my laptop, i was not sure whether I ... it was really good and worked, it heats up a little bit but for now its working ...
When your acer aspire 5738 z laptop adapter is not working ...
docslide.us > Business
Aug 18, 2015 - When Your Acer Aspire 5738Z Laptop Adapter is Not WorkingA ...Quicker Charging of Laptop Battery with an Acer Aspire 3600 AC Adapter ...
batteries-store.pblogs.gr/.../when-your-acer-aspire-5738z-laptop-adapter-...
Jan 14, 2016 | Acer Aspire 3600 Laptop Charger...
Says plugged in not charging
Take out the battery and make sure you can turn on the laptop with just the AC Adaptor hooked up.
If you can then you know the AC Adaptor is good. Try another known good working battery in the laptop, if the battery charges then you know that the old battery is bad.
If the laptop doesn't charge with a know working battery or a new one then you know that the motherboard is bad.
Aug 19, 2009 | Acer ASPIRE 3680-2022 Notebook
I have a acer aspire 3680 that will not charge
The power cube is the problem..lets face it you had a 50/50 chance of getting to the root of the problem..so by replacing the battery that only leaves....
Don't Forget to rate the advice!!
http://www.aa1consulting.com
Jul 27, 2009 | Apevia HQRP Replacement Laptop AC Adapter...
Laptop stoped working
I have an Aspre 3680 as well, and a flashing adapter light is not a good sign, I suggest you get a multi meter and test for to make sure you are getting the 19 volts output that are required to run the laptop and charge the battery.
My goal is to provide you with a helpful fix ya solution, if you found this advice helpful please rate it as Fixya, thanks
Ken
Dec 09, 2008 | Acer Aspire 3680 Laptop
Battery
Nothing to worry about mostly all the laptops do this,
Sep 10, 2008 | Acer Aspire 3680 Laptop
Acer laptop 3620 battery will not charge
You may want to check the A/C port. Some the ports can come loose from the motherboard due to wear. Can you tell if the computer is getting a charge from the A/C adapter?
May 01, 2008 | Acer Aspire 3680 Laptop
My charger won't work so now my computer wont turn on
Unplug you ac adapter from the wall and plug a lamp in to verify that the wall plug is working correctly. Pick up the adapter to see if it feels warm. Most adapters will feel warmer than room temperature if they are working,
If the cords on your adapter can be unplugged from the adapter, reseat them. Try the ac adapter in another wall plug to see if it comes on. The adapter may have an LED on it that indicates whether or not it is on. If it doesn't, about the only way to check it is to use a multimeter to see if there is any voltage on the plug that goes into the back of the laptop. If something else will work in the original wall plug and the adapter won't work in another wall plug, you will need to obtain another ac adapter.
Once you've tried these things, let me know and we'll go from there.
Thanks!
Ron-
Nov 11, 2007 | Acer Aspire 3680 Laptop
Acer Aspire 3680 Laptop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
