Question about SanDisk Memory Media
Phone restarts everytime i put the memory card into my phone it says memory card is inserted but the phone stops working altogether.
  • Anonymous Jan 05, 2008
    when i go 2 switch storage device my phone completley freezes and then restarts what can i do
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 175 Answers
May be your phone doesnot support the size of the memory card.
did you check the other cards?
if it does the same then format the card using card reader and then insert it.
Posted on Jan 06, 2008
Everytime i try to download music to my memory
try using a different USB port to put the Dynes reader into then insert the memory card in it once the dynes reader is detected by the machine, if still not being detected check the services window
in XP click start open the run window type services.msc in the list look foe Human Interface Device Access double click and change it to Automatic, then look for Plug and Play do the same set it to automatic, then look for Universal Plug and Play Device Host set it to automatic as well make sure that after you set each that you click apply then ok to make changes take effect, after you've done the automatic settings remove the dyne card reader restart the computer aftrer restarting then insert your mini memory card into the dyne reader then insert the dyne reader into a USB port on your computer, Hopefully this should work ^_^
Jun 04, 2010 | Dynex 5-in-1 USB 2.0 Mini Memory Card...
My nokia 3110c is switched off again &again work for 3 minutes only help me
If you have a memory cars remove it and restart your phone.It usually works.Now,back up your data in memory card and format it.Fill the memory card only to its half the space.Try working the phone after inserting the memory card.If the problem is still there, then,you have to stop using your memory card or reinstall phone firmware.
If you don't have a memory card then, delete all the messages( Inbox ,Sent item etc).Clear the phone memory(delete images,themes etc).You may backup these things before deleting.
Now restart the phone.
If the phone doesn't stay long enough to do these things then,connect to a computer and do it.
May 08, 2010 | Nokia 3110 Cellular Phone
Auto Restart when i insert my MICRO SD
It restarts in order to mount the card. No problem, just annoying!
Apr 12, 2010 | Nokia 3110 Cellular Phone
Hi i have lg kp260 and everytime i want to send a muzic on my pho
one way to do it is, copy the files to your memory card, insert your memory card to your computer and drag and drop files. if your computer doesn't have a memory card slot, consider borrowing usb memory card reader from a friend and start copying the files from your memory card to your pc.
if the files you are sending is of big capacity, there is a possibility that phone may restart due to low memory, while you are sending files, your phone memory becomes low, they are sharing memories page, it may be the cause. try sending a small capacity, like images, and check if it will off. if this happens, then, go to your nearest service center and have it check.
take care..
Feb 27, 2010 | LG KP260 Cell Phone
My phone says my memory card isnt inserted even though it is
It may have been damaged. If your card had a warranty try to get a new one. But if you put it into another device and it works, the card may have been a little dirty.
Jan 27, 2010 | Sony Ericsson w580i Cellular Phone
My nokia 3110c always restart when my memory is inserted.. how can i solve this problem? but if i didnt insert my memory my phone doesnt restart..
It is obvious that the memory card you inserted into your phone is bad (it has virus) and that's why the phone keeps restarting.
Try inserting another memory card and let's see what happens.
Take care.
Nov 20, 2009 | Cell Phones
Phone restart
have you try to replace your memory card?or try to have a back up of your files then format the memory then put it back to your phone.if it is still not ok,replace your memory card..
Oct 03, 2009 | Nokia 3110 Cellular Phone
My samsung SCH-R450 turns off and restarts again
Check your memory card alignment and if its properly seated. If its a loose contact, your phone will definitely restart.
Jul 30, 2009 | Samsung Cell Phones
My blackberry stopped working after i put a micro sd card in
I would be more concerned as to the source you chose for the music and pictures you loaded onto your micro sd card, as depending upon the KIND of music and pictures and the tendency of such sources as you chose to provide your system with viruses..........
Remove the SD card, immediately and get your phone scanned for viruses along with your PC given the fact that all are apparently infected.
Apr 26, 2009 | Nokia N95 Cellular Phone
-----phone is restarting everytime--------
better u reinstall ur mob software else download kaspersky anti virus software from net and scan ur card with the help of tat anti virus...if any virus available in it...delete tat and format it..else go to address bar of ur system and click the drop down list box and select ur memory card drive...then the window will open..from tat u delete all the folder anr format it...then used in ur mob it ll work
Aug 05, 2008 | Nokia 3110 Cellular Phone
Electronics - Others Logo
29 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Carlos Calvo
Level 1 Expert
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
