Question about Microsoft Xbox 360 Console
I have my X box plugged in correctly to the tv as it has worked previously and it turns on and off and i can hear the sound but no picture. I changed the cord that connects it with the tv to a new one but still no picture. sound is fine though
    Genius:
  • 1,093 Answers
This problem is actually fairly common and it is not your TV or the AV cable.
The reason that it happens is because the scaler chip at the back overheats and shuts down.
You can send it back to get it fixed or fix it yourself and get back to your games
Posted on Sep 25, 2009
    Genius:
  • 1,112 Answers
What kind of television is it?
What type of connection are u using?
Have you tried the XBox with another set?
to make sure its not the xBox.
Restore sound on my Tv, suddenly lost.
  1. Check if the mute button on the cable box/TV/VCR is activated. If so, turn off the mute feature
  2. Verify the volume on the cable box/TV/VCR is not turned all the way down, either by adjusting the volume level on the equipment itself or with the remote control
  3. Check if the TV has an earphone or headphone jack. If so, make sure there are no earphones or headphones plugged into it
  4. Check if the Cable Box/TV/VCR has a SAP/MTS switch (Secondary Audio Program / Multichannel Television Sound). If so, make sure it is set to the proper setting. Consult your TV/VCR manufacturer's user manual for information for your specific TV/VCR. Click here for information on changing this setting on a Cable Box
  5. Check behind ALL TV and equipment (Cable box, TV, VCR, DVD, stereo receivers, etc) and the coax cable at the wall outlet for any loose or damaged connectors
  6. Make sure all equipment and connections are hooked up correctly for the video and audio based on the type of connections being utilized
Mar 10, 2015 | SEG 19 in. TV
No tv picture
Start by making sure that all of the set-top box cables and cords are firmly connected and that the set-top box is turned on. Also, check to see that the TV is set on the correct channel and that the DVD player is not on.
If the power light is flashing, it could be a problem with the voltage of that the capacitors are malfunctioning. In this case, it's best to contact a professional for help.
If you hear a chirping sound, that is the shutdown circuit activating, indicating a problem with the power supply.
For more tips and tricks, check out No picture on TV for troubleshooting steps and solutions. I hope this helps!
Sep 27, 2012 | Sanyo Televison & Video
I accidently pressed the channel button on my remote instead of the volume button. I now have no picture or sound. I tried returning to the previous channel but it keeps saying " channel not...
Not familiar with your model, but the problem sounds generic. I am guessing your set is hooked to a cable tv box, and that is where you need to change channels. I also guess that when you changed channels on your TV you probably moved from channel 3 to either channel 2 or 4 and the cable tv box is not sending to those channels so you lose picture and sound. Now, more guessing, you try to put the channel back to 3 on your TV, but still nothing happens. OK, if close so far, there are a couple of things to try. First, be really sure you are actually going back to the same channel you started with. Assuming you don't actually have the signal coming in on an auxiliary line-in and that you had it coming in on a channel, you may need to reset the presets on the television so that it recognizes the one important channel the cable tv box is sending out -- just follow your television menu to select or set channels. There is one more possible easy problem ... I have seen this one happen, after getting the channel correct and reset, if it still doesn't work, you mght need to turn the set off and wait one minute, then turn it back on WHILE the cable box is ON. This can cause the set to RE-Latch onto the cable box signal. It really doesn't sound like something is truly broken or needs replacement, sounds more like a user error. If your set is still under warranty, just call the Panasonic hotline (find it in Google, and they may be able to walk you through exact instructions for your model). Hope this helps.
Aug 29, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
TV sound but no picture
Can you tell me which Cable box you are using?Which model/region?
The possibility is that the HDCP handshake could not have happend correctly and hence the issue. Try to connect to different HDMI input of TV from Cable box. If possible change the resolution of cable box and check video
Nov 01, 2009 | Philips 50PFP5332D 50 in. Plasma...
My xbox has no red rings, but its not broadcasting to my t.v. I turned it on last night and it flickerd as if a loosed connection. turned it off and now nothing on the t.v or sound and no red lights
You should have audio, and not picture.
if its the G.P.U. video feed error
Ok swap the A/V cable for new .
turn on the box and turn up the volume on
the tv . now pull out the red or white plug slowley
till your diconected you should hear a buzzing
sound coming from your tv as you pull the plug
out . If not then the tv is on the wrong video in put
change the tv to video 1, 2 ,3,... till you hear and see
the picture.
Rob
Oct 15, 2009 | Microsoft Xbox 360 Console
Hello, I have an RCA Truflat tv that I bought
If you can hear sound and the sound coems from your TV, try changing the volume with teh TV remote control. Your TV isn't off it is still on. Just the video board or portion is cutting out. this could be a ton of things, I would try changing out the power strip or plugging the tv into the wall directly to make sure it has enough power. other then that you can try a home brew solution like putting a fan next to your tv to cool the component that seems to be overheating and shutting down your picture.
Aug 25, 2009 | RCA Televison & Video
Mitsubishi VS-50603 Wont Turn on
The power supply will need to be changed. The capacitors inside the power supply are not sending the correct amount of power to tv and will need to be changed.
May 13, 2009 | Mitsubishi VS-50603 50" Rear Projection...
Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
May 29, 2008 | Televison & Video
Picture on TV stuck on one picture
Ok fixed it. Just unplugged the box and plugged it back in and it works fine.
Apr 05, 2008 | Directv Plus DVR DTV Receiver / 100-Hours...
How to connect surround sound system, at the moment its connected through cable, each time we use the dvd player we have take them out of the cable box then into the dvd player, we have a LG 42PC55 tv.
In order of picture and sound quality -- from best to worst:
1. The best way to connect, assuming your TV and A/V Receiver and/or Cable Box have the jacks, is to use a HDMI cable ( this cable is for both sound and video).
2. Use Component Video out to input (3 RCA plugs, Red, Blue & Green) along with RCA Audio out to input (2 RCA plugs for stereo - 1 for mono).
3. Use S-Video out to input (1 din plug) along with RCA Audio out to input (2 RCA plugs for stereo - 1 for mono).
4. Use Video out to input (1 RCA plug, yellow) along with RCA Audio out to input (2 RCA plugs for stereo - 1 for mono).
Be sure to select the correct inputs on your TV and Audio/Video receiver when you are watching TV. For example if you have connected your TV to HDMI 1 and DVD to HDMI 2, you will not see or hear anything if you don't select the correct input on your TV and A/V receiver for the input you want to see and hear.
Detailed connection instructions will be found in your owners' manuals.
Hope this helped you. :)
Mar 30, 2008 | Televison & Video
Microsoft Xbox 360 Console Logo
61 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
