Question about Zoom Wireless-G 4410 (44100000) 802.11g/b
System crashes and re-starts
Exact same thing I am reading in the comments. Zoom USB adapter, computer shuts down then restarts, pull out the adapter everything fine. Should I just simply get another adapter or is there a way to fix the probelm?
  • 284 Answers
Can you boot the machine with this device already connected and not have a problem?
I have seen some USB devices cause this problem when you connect or disconnect them.. It causes some kind of voltage surge on the USB bus which makes the system panic and switch off.
My phone sync cable used to do the same thing. I rang tech support and described it as an inherent problem for some usb devices
Posted on Sep 25, 2009
  • 4,281 Answers
N oyou not need to purchase new 1 /
But just make sure that your usb devcie is not conflicting with any other driver or device.
For that uninstall your zoom adapter usb driver then reisnstall.
Also some usb adapter give some memory space so if you have memory space on your zoom adapter then scan it for viruses or format it.
Then it works fine.
Let me know if you need more assistanse.
Thanks.
Hello i am using a tu2-et100 with windows vista....and ever since ive started using it my computer has failed to fully load webpages, and videos online. On some websites my computer shuts down....leaving...
The issue is that the hardware driver for the USB is causing your system to crash. Try finding an update from Trendware- however your best bet is if you have a desktop, purchase a network card that goes internal, and if laptop- use an express card. USB network adapters historically have been *VERY* unstable- and the issues with your system definitely point at the driver for the adapter.
Oct 11, 2010 | Trendware TRENDnet TU2 ET100 network...
I have an Acer Aspire 6530 running Windows Vista and today it started shutting off at random. When it shuts off the bottom 2/3 of the screen has blue stripes across it, and on the blue is text I cannot...
Good question.
Does the computer feel hot when it shuts off?
Does it always happen at the same exact time?
Can you try booting the computer into Safe Mode? (What Happens?)
First thing I'd try is uninstalling the video adapter driver under device manager and restart the computer.
Let me know what happens!
May 20, 2010 | Acer Aspire 6530-5143 Notebook PC
My computer crashed, so I wiped it clean and started over. I down loaded the software but did not pull the card out first. Then I uninstalled the software, shut the computer down, removed the card, turned...
if your problem is your computer crashes due to wireless adapter card.. try turning off your pc and remove the card, then boot your pc.. and see if it still crashes
Oct 19, 2009 | Cnet CNWL-311 802.11b (CNWLC-311) Wireless...
Windows Vista crashes when I connect my Linksys wusb54g wireless adapter. It worked fine for about 3 months, then started crashing, now I can't have it connected, or it crashes instantly.
This is a software conflict of the linksys device to your system, so to correct this remove first the software from your computer and then after that restart the computer and then connect the adapter on different usb port , if still having the same problem i will suggest that you have the device replace.....
Oct 09, 2009 | Linksys WUSB54GC 802.11g/b Wireless...
My computer won't read my Sandisk memory card adapter thing.
Did you try to insert it and restart your computer while it's still in?
If not you can even try shutting it down and inserting it. Then start it up and see if it recognizes a new device.
Jul 10, 2009 | SanDisk 2GB microSD Memory Card
Wireless adapter for compaq presario f500 not working.
RESTART YOUR COMPUTER, ON REBOOT, CLICK F10 WHEN YOUR CHANGE BOOT OPTIONS SCREEN COMES UP. YOU MUST PRESS F10 QUICKLY OR IT WILL LOAD WINDOWS AND YOU WILL HAVE TO RESTART AGAIN. ONCE YOU GET INTO THE BIOS SETUP UTILITY GO TO SYSTEM CONFIGURATION, SCROLL DOWN TO BOOT OPTIONS CLICK ENTER. GO DOWN TO INTERNAL NETWORK ADAPTER BOOT AND ENABLE IT. GO TO EXIT AND SAVE.
Apr 04, 2009 | HP Compaq Presario F500 F700 and G6000...
Can't re-install 2Wire USB Wireless adapter
If you are on windows vista it could be your driver. You can go into safe mode on the computer with F8 while the computer is starting up, then go to the control panel and device manager. Plug the adapter in and remove the driver for it. Download a new driver at http://support.2wire.com/index.php?page=download and install it.
Mar 30, 2009 | 2wire HomePortal 100W (1000-400026-000)...
Computer starts, attempts to load display, crashes, restarts.
You should do a system restore. It may have happened because of a system update, if your set up to receive them automatically.
Feb 22, 2009 | HP Pavilion dv6605us Notebook
Computer immediately restarts every time the Zoom wireless device is recognized
try updating your windows OS..some components might need to be installed. Check also the website of zoom if they have a updated driver that may fix the issue.
You might also want to check some softwares/driver that may conflict zoom.
Oct 25, 2007 | Zoom Wireless-G 4410 (44100000) 802.11g/b
Zoom Wireless-G 4410 (44100000) 802.11g/b Logo
201 people viewed this question
Top Zoom Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
