Question about Microsoft Xbox 360 Console
Cannot get AV on my Matsui 1407s
Hi
How do I get a Matsui 1407s TV into AV mode, It does not have an AV button either on the remote or the TV itself. Replies to viksagar1@yahoo.co.uk please.
  • 27 Answers
Some TV's have a componant button which usally means AV
Posted on Sep 26, 2009
Cannot get AV Mode
There is a TV/VIDEO button on frond panel of the tv. When you press each time this button then you will able to access different video inputs. if the button is inactive the probably the micro switch for TV/VIDEO button may be faulty. also check the same with the remote. If its doesn't help then try to reset the tv to factory default setting. For that you need the remote. Keep in mind that when you reset the tv to factory default setting all the memorized parameters will erased(like channel memory, personal preference setting etc ). For reseting the tv to factory default do the following
1.Turn on the TV.
2.While holding down the RESET button on the
remote control, press the POWER button on the TV front panel.
The TV will turn itself off, then back on again. Release the
RESET button
Ajin
Jan 23, 2013 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Just found original remote control for my matsui tv after trying to use a "universal remote control" to work it. tv requires a 4 digit pin code that i don't know! help.
HI,
Please let e know the make and model no.of your remote.
Also let me know the make and model no. of your TV
I'll let you know the code.
Sep 30, 2008 | Televison & Video
My matsui tv 28WNO5(A) will not turn on from standby
Try pressing the small reset button on the back, it works, and you will not loose any stored information which caused the unit to go in the stand by mode.
or
Have you tried turning it off for an hour and then turning it back on. This happens to me quite often and leaving it off for a while ususally allows it to come back on. Also have you tried to press the TV/AV button on the remote as sometimes it switches to TV mode when its on standby and then standby won't work as its on TV mode and needs to go back on to AV mode. Basically just press the AV button on the digibox remote and then try standby.
or
if the batteries are removed and left for about 20 minutes before being replaced again, everything works as it should.
or
if any of the above suggestions does not work then you have to open the unit and on the main board of the tv there is a thin mini tube light like component called fuse you will have to replace that fuse .the fuse is very very cheap and you can easily get it at any electronics shop.and if still the unit does not work then there is a major fault in the power supply board and should be taken to the service center for diagnosing the fault that it is repairable or not.but i hope the above information provided will definately help you to solve your problem.
Oct 04, 2008 | Sony KV-32XBR85 TV
Go to av mode without remote in toshiba 27d46 tv
Here is a manual for that tv. Page 27 says to push the tv/video button but that is on the remote. Do you have a tv/video button on the tv itself? If so, push it until it cycles through to the video input you want
http://www.manualowl.com/m/Toshiba/27D46/Manual/33233
Jul 28, 2012 | Toshiba 27D46 27" TV
Tips to operate without remote
You might try hitting the MENU button on the tv itself to see if you are able to select input / source that way. Some TVs also have the Aux Inputs selected by scrolling through the channels until you come to the aux inputs.
Jun 22, 2010 | Prima C2012 TV
I have a Matsui portable TV for which the remote controller does not work. How do I retune the TV
you need to check the buttons on the tv itself and see if you have a menue button or a imput button then go from their to return to whatever mode you are set up to watch tv
May 17, 2010 | Panasonic Televison & Video
Lost the remote. How do I switch TV/AV to play video?
If there is a mode button, otherwise if there are not other buttons on the set itself, try tuning channels with autoprogram or channel add/edit and see if there is an INPUT or AV channel.
Otherwise you can get universal or origonal remote online.
Oct 27, 2009 | Orion STV2763 27" TV
Change from TV mode to AV mode for a Hitachi C28W4110SN
There should be buttons somewhere on the TV itself to switch input modes. Look around where the power button is located and see if there is a menu button you can access. Then use channel up/down and volume up/down to scroll thru modes to find input
Hope this helps
TankMurdock
Apr 27, 2009 | Hitachi 61SDX01B 61" Rear Projection...
Universal remote works for basics but won't change input
Rich,
good day , what button can you see infront of your TV screen?
Not familiar with this model but if you'll manage to locate a button marked as "TV/AV" or "AV" press this button until it the display switch to A/V mode (audio/video). Or if this is a really old model, from Tuner mode or channel model. set the channel station to 1 then press the " - channel " button and see if it will change from tuner mode to A/V mode
cheers,
mark
Jan 31, 2009 | Toshiba 32A33 32" TV
My matsui tv volume is stuck halfway and dont no how to turn it up higher the remote is a matsui 21vin
the tv is in hotel mode which limits the sound try holding the I button on the remote and switch on the tv.
Oct 09, 2008 | Televison & Video
Microsoft Xbox 360 Console Logo
487 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
