Question about Acer Aspire 3680 Laptop
How long on the internet would i get for 3GB - Acer Aspire 3680 Laptop
  • 615 Answers
Well let’s do it in another way I am doing my PhD and do lots of research and download lots of materials but not movies and I do use between 2 and 3GB a month. Let me know and please do not forget to rate my service to be able to continue providing service and improve on it…God bless
Posted on Sep 25, 2009
Testimonial: "many thanks for your help. very helpful indeed."
Is 2GB DDR2 PC2-6400 800MHz compatible with ASUS P5GC-MX/1333 if not what is the fastest and correct Ram I can fit;
From ASUS Site:
https://www.asus.com/us/Motherboards/P5GCMX1333/specifications/
2 x DIMM, max. 4GB, DDR2 667/533 MHz, non-ECC, un-buffered memory
Dual channel memory architecture
**When installing total memory of 4GB capacity or more, WindowsR 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended.
Apr 01, 2017 | ASUS Computers & Internet
Tip
Mamimum RAM for User @ 3GB using boot.ini switch on 4GB Physical RAM
The DOS will always take a percentage of the physical RAM on the motherboard leaving the rest for the User. By default the Windows Operating System will use 50% of the physical RAM installed on the motherboard leaving the user the remaining 50% this can be changed using a switch in the boot.ini file
The /3GB was originally meant to be used in systems that have 3GB or more of RAM something that is no longer quite as rare as it used to be Windows XP SP3 will support upto 4GB although on a 32bit (x86) version of Windows will acually see 3.25gb that is the limitation.
However, even if you don't have 3 GB or more of memory, you can still use the /3GB switch. the switch can have any value between 2048 (2 GB) and 3072 (3 GB) megabytes. It needs to be expressed in decimal notation.
The /3GB switch applies to 32-bit systems only (x86).
Example with Windows XP SP3 Home Edition with the recovery console installed this gives you the option of default 50-50% split or the 3GB switch 75-25% split.
The /noexecute parameter enables, disables, and configures Data Execution Prevention (DEP), a set of hardware and software technologies designed to prevent harmful code from running in protected memory locations using the optin switch enables DEP only for operating system components, including the Windows kernel and drivers. Administrators can enable DEP on selected executable files by using the Application Compatibility Toolkit (ACT).
The /burnmemory parameter specifies the amount of memory, in megabytes, that Windows cannot use in this example, /burnmemory=128 will reduce the physical RAM memory that is available to Windows by 128 MB.
[boot loader]
timeout=10
default=multi(0)disk(0)rdisk(0)partition(1)WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)WINDOWS="Microsoft Windows XP Home Edition 3GB Switch" /noexecute=optin /3GB /fastdetect
multi(0)disk(0)rdisk(0)partition(1)WINDOWS="Microsoft Windows XP Home Edition " /noexecute=optin /burnmemory=128 /fastdetect
C:CMDCONSBOOTSECT.DAT="Microsoft Windows Recovery Console" /cmdcons
Check out the noexecute and the 3GB switch plus all available boot.ini switches HERE
I suggest that you use AnalogX MaxMem it is a realtime physical memory management program that automatically ensures that you always have as much physical memory available as possible used with the 3GB switch you should never have memory issues ever again.
on Mar 14, 2010 | Microsoft Windows XP Home Edition for PC
When i play igi2 my computer become off & restarts again, my computer is a Pentium4 3gb processor, 1gb memory . what is the problem?
For games, you must always have latest drivers.
Maybe you have some viruses, download free antivirus program from internet and scan your computer.
try this out - http://www.avast.com/free-antivirus-download
Jul 30, 2011 | Computers & Internet
I bought a new Western Digital Caviar Blue 1TB SATA 3.5" Desktop Hard Drive 6Gb/s It dosent work for me, I can see it in the CMOS Setup under Sata 1. My MSI K9N8PGM2 motherboard only support...
you need hard drive formatter this is in disk manager, windows 7 press windows key and then X go to disc manager, in the menu you will find your hard drive and make sure its the right one. and click on format drive, on the folder of the drive.
Jul 08, 2017 | Western Digital Caviar Blue 1TB SATA 3.5"...
Want to add ddr3 memory to my p5qc board
Hello
The motherboard supports DDR3 1333/1066/800 MHz or DDR2 memory 1066/800/667 MHz to meet the higher bandwidth requirements of the latest operation system, 3D graphics, multimedia, and Internet applications. The dual-channel DDR3/DDR2 architecture doubles the bandwidth of your system memory to boost system performance, eliminating bottlenecks with peak bandwidths of up to 19.2 GB/s.
DDR2 1066MHz DIMMs work only on the black slots for one DIMM per channel
2 x DIMM, Max. 8 GB, DDR3 1333/1066/800 Non-ECC,Un-buffered Memory 4 x DIMM, max. 16GB, DDR2 1066 / 800 / 667 MHz, Non-ECC, Un-buffered memory Dual channel memory architecture When installing total memory of 4GB capacity or more, Windows® 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended DDR2 1066MHz DIMMs work only on the black slots for one DIMM per channel. Ensure to install the DDR2 1066MHz DIMMs ONLY on the BLACK slots! Refer to www.asus.com or this user manual for the Memory QVL(Qualified Vendors Lists). When installing total memory of 4GB capacity or more, Windows® 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended.
Hope this helps
Jan 19, 2011 | ASUS P5QC Motherboard - Intel P45, Socket...
Cant find a motherbord manual to hookup power swtich for new case
Search on the Internet for your motherboard manufacturer's support section - Manuals can usually be downloaded for free, which will help you out.
Sep 07, 2009 | Acer Aspire M5100 AM5100-U5313A AMD...
MSI VR321 WITH 3GB
Kind of like with hard drives the amount shown is never the exactly full amount cause when it comes to hard drive space some of it is taken up for creating the partition.
When it comes to memory some of it is taken up for the system to run, boot up, etc. So as long as its close then everything is fine.
Jun 17, 2009 | Computers & Internet
Interent-Wireless
You can get wireless internet as long as you connect to a wireless router/Access point. If you have Internet, you would need to get a wireless router in order to use your internet wirelessly.
Apr 16, 2009 | Acer Aspire M3100 Refurbished Desktop PC -...
Acer Aspire 3680 Laptop Logo
52 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
