Belkin router I have a Belkin router, it works fine as a wired hub to my computers , but does not broadcast wirelessly. It seems to be recognized and shows a good signal, but doesn;t cannot connect to the internet
  • onlylar Dec 22, 2007
    Thankyou for taking the time to work out my problem. For now I have just bought a netgear switch and running wired. Soon I will address the wireless problem with the suggestions you sent. Again , thankyou.........onlylar
  • Anonymous Jan 09, 2008
    Out of the blue,we cannot access the internet nor can my son connect with his xbox360. Computer says everything is connected,modem is like a christmas tree,co is router,ISP say connectivity is 99.99% but we still cant connect. My son thinks he needs to increase the MTU on the router model F5d6230-3 to at least 1365 but doesnt know how,can you help?
  • 556 Answers
A couple of items to check -- these will not fix the issue but may isolate the problem.
Turn all machines on before the test and do not turn off until after
On at least one wired computer that is working and maybe all wireless computers I want you to do the following
Click Start then All Programs then Accessories then Command Prompt
In the window that opens type
ipconfig /all
press enter then record all of the following for each adapter
  • adapter
  • IP address
  • Subnet Mask
  • Default Gateway
  • one or more DNS addresses
The back in the window enter the following command using the default gateway from the wired connection (your router address)
ping (default gateway)
you will either get 4 timeouts -- the connection fails or 4 messages with elapsed times generally measured in ms or milliseconds.
What you are looking for in the above
Good entries base
x.y.x match each other if subnet mask is right
u should be unique for the network
Wired IP address x.y.z.u not may be 192.168.0.u
SubNet Mask ?.?.?.? assuming
Default Gateway x.y.z.? not may be
DNS addresses ?.?.?.? not
where at least one is not zero.
Then wireless entries should be
SubNet Mask same as wired
Default Gateway same as wired
DNS addresses same as wired
If these are wrong there is a configuration error either in the router or wireless adapters depending on how you want your network setup.
each connected adapter wired and each wireless should also
successfully ping the default gateway or router address
If the ipconfig is right and the wired config has successful pings, then every wireless adapter that fails has a wireless config issue.
If you are willing to work through this let me know and reply with information in a comment to this issue.
You may also want to address wireless security
See this response and let me know what you want to do.
Wireless security
Posted on Dec 16, 2007
I installed a Belkin broadcast router and my computer won't hook up to internet. My other computers (like the one I'm relaying this message) does fine. Downloaded D-link 520 drivers to a...
Go to my computer control panel network connections and see if the setup for networking is correct DHCP should work most of the time. Check the device manager and see if your nic is properly recognized. If not you might need to install drivers for the card.
mycomputer - control panel
mycomputer - view system information - hardware - device manager
Also, sign onto your router and see if the router recognizes the computer.
It should tell you how to do this in the routers manual.
May 09, 2011 | D-Link DWL-520 Wireless PCI Wi-Fi...
No wireless internet - problem with belkin router
From one of the "wired" computers, connect to the router's built-in web-server, and run the "Wireless Networking Setup Wizard", in order to configure your wireless network, choosing an 'SSID' and a "password" for your network.
Dec 28, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
I have a belkin G router that my computer will not recognize for some reason. It recognizes every other network in the neighborhood except mine. There is no security or password set, and my wifes computer...
Check whether the SSID broadcast is enabled on the router.
If it is already enabled then try changing the wireless channel on the router.
for this you will need to open the set up page of the router.
Click Here for more info about networking
Oct 13, 2009 | Belkin (F5D8231-4) Wireless Router...
I have a macbook pro and I am having problem connecting wirelessly to a Belkin Wireless Router N. None of my roommates have problem connecting and I can connect wirelessly everywhere else on campus but not...
Most hotspots are using b/g protocol for the widest compatibility with other hardware. Your macbook pro may not be able to connect tot he Belkin router if it's only broadcasting the N protocol. First verify which protocol the Belkin router is using. If it's broadcasting N, try changing it to use b/g and see if you can connect. I seem to recall that the earlier macbooks needed an update to be N compatible.
Sep 21, 2009 | Belkin (F5D8231-4) Wireless Router...
Belkin Wireless 5-Port Hub (F5L009) Problem
If you set the allowed IP address in the security section of the router then you must fix your computer IP to with a subnet mask of the default gateway should still be and when you get in delete the security locking out all but the one address. Good Luck
Sep 03, 2009 | Belkin Wireless USB Hub
Belkin Wireless G Plus MIMO router - connectivity problem
  • this problem can be ISP releted they may have some issues on the ADSL line connection
Aug 10, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Wireless is working but computer won't connect to the internet
Remove the power cord from the router. Wait 30 seconds. Reconnect the cord. Like rebooting a balky computer.
You may also have other routers nearby on the same broadcast channel.
Occasionally cordless 2.4ghz phones may jam the wireless channels.
Chose another channel from the router setup.
Aug 06, 2009 | Belkin (F5D8231-4) Wireless Router...
Belkin Wireless Router F5D8633-4 does not connect to the internet
Try first to connect to the internet using wired connection. If it connects, try to connect on wireless make sure the router is broadcasting signal.
Mar 16, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Computers & Internet Logo
736 people viewed this question
David Payne
David Payne
