Question about Welding Tools
My mig will not engage when i press trigger on my sterling mig the wire starts to come out but does not arc replaced one of the components but still the same i know it is not the earth cause when i push button down inside of the machine it welds ok.
  • kinrossc Oct 07, 2009
    the wire feed is working no problem but when wire hits the steel it does not arc the earth is fine there is a connector box inside the welder when i push the button it earths its like the power to engage the connector box is not there for some reason.
  • paul wright May 11, 2010
    Sounds like the wire feed control pcb is not pulling in the main contactor relay. is it a seperate wire feed unit with an interconnecting cable to the rectifier?
  • 71 Answers
Check your ground mabe its not getting enough ground
Posted on Nov 07, 2009
Phase three on cv or cc have current going to mig wire, wire is live without hitten gun trigger. mega arc is hooked up to a Hobart suitcase
May need to take gun apart and see if trigger is sticking or replace lead.
we use Miller at work. The feeder has a switch that makes the trigger turn off and on with quick pull of trigger so you don't have to hold it entire time.
check wiring to make sure it's wired right so your not bypassing the trigger switch.
hope it helps.
Nov 02, 2015 | Hobart Welding Tools
MY CLARKE WELD 235 TEN TURBO ARC WELDER HAS SUDENLY STARTED BLOWING FUSES WHEN IT ARCS UP ANY IDEA
More then likely you have a shorted component (positive or hot wire to ground). Verify that the gun/trigger assembly is in good shape and has no broken wires that are touching the ground or case (may have to disassemble). Thats the easiest thing to check, everything else is inside the unit and will take more sophisticated knowledge and equipment to diagnose.
Oct 12, 2011 | Clarke Power Products Clarke 130EN...
Mig welder started to arc out on its own. You dont touch the trigger and when you put the wire to the grounded table it blinds the **** out of you. Could use some tips on repair. Thanx. Shane.
Try replacing the feed tip as this is an insulator that keeps the wire from touching the tip as it feeds out. These tips need replacing often as they also provide a friction free surface for the feed wire.
Apr 10, 2011 | Welding Tools
Have a century 125 gl mig welder 110v and it arc's with out pulling the trigger
Need to ckeck the gun switch trigger the terminals? See if there are grounding out.
Jan 17, 2011 | Miller MATIC 140 MIG WELDING PKG w/cart...
I have a craftman mig 110v mig welder arc problem
Check to make sure the contact is not touching the nozzle of the mig welder. This would definitely short it out!
Apr 14, 2010 | Lincoln Welding Tools
My little 110 mig welder is arcing without trigger pulled
i believe that the trigger only send out the wire and does not control the arc the tip should be live as long as the welder is on
Feb 28, 2010 | Lincoln Welding Tools
Solar welder 2175 wire keeps feeding wont stop doesnot arc until trigger is pulled
Look on the front pannel. thier should be a "latching Switch" indicated by "4 X 2" little arrowes. The 4 is " pull the triger -- the release the arc continues, the "2" is pull the trigger and the arc startes release the trigger the arc stops simplesssssssss
Ken
Dec 14, 2009 | Welding Tools
Welding Tools Logo
48 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
