Question about Kyocera Mita Office Equipment & Supplies
When i replace a new drum, there is no copying out.what will i do? kindly share with me the test command of KM-2035. hoping for your help!!!! I am ariel, filipino
  • 541 Answers
Are the pages blank? or does it not have paper exit? you need to remove the new unit you installed and check that all paper and packing tabs are removed. reinstall if you found onne to remove. if you did not find one to remove install old drum and see if it works. your new drum could be bad.
Posted on Sep 26, 2009
E32 error in kyocera
The toner container is not installed on the copier.
Mar 01, 2016 | Kyocera Mita 2 Pack Km 2020 2035 2050...
Error code c6
heater problem reast 10871087 after selct 163
Aug 07, 2014 | Kyocera Mita 2 Pack Km 2020 2035 2050...
KM-2560 COPIER HAD JAM IN DRUM UNIT NOW GETTING 1/2 COPIES
1.Open front cover with power
2.ON press set
3.read display.
4.choose change drum and yes/ok
5.close cover
6.will reset bias voltage aka light copies, to suit new drum
Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For Techsupport Printer
Mar 07, 2014 | Office Equipment & Supplies
Mery clear for kyocera 2035
How to service mode of copier kyocera km-2035
Jan 16, 2011 | Kyocera KM-1505 Copier
I m facing toner sign in af 2035 i have replace td sensor i/o board , power supply, but after machine start in first or second copy toner sign is generated. what should i do now ?a
you have to change the ID sensor machine is not getting the bare drum and patch voltage based on this ID voltages your toner supply depends -thanks
Dec 28, 2010 | Ricoh Aficio 2035 Copier
Kyocera Mita 2050 there are streaks of toner appearing on the pages printed.
If you send a print job or print a report from the copier and there is no streaks then the problem is most likely the thin **** glass to the left of the large glass. It just needs to be claened.
If the streaks are happening when printing and copying then the problem is most likely your drum unit (MK-410) or possibly the fixing unit (FU-410), the fixing unit is the one that gets hot.
As the drum gets old it can cause print/copy issues and the cleaning blade that cleans the drum gets to the point it doesn't clean the drum properly causing streaks.
The heat roller has a teflon coating on it and as the roller gets older the teflon starts to come off and can effect prints/copies.
The drum unit should be replaced every 150,000 pages and the fixing unit every 300,000 pages on the KM-2050.
I hope this is helpful,
Shawn
Nov 15, 2010 | Kyocera Mita KM-2050 Printer
Light copy on KM 4035, KM 2035 even the spare parts inside was new.
if copies and printouts are the same then do the following... if only copies then change your scanner lamp
make sure you are using kyocera toner... empty developing unit and run sim mode 131.... make sure that you have changed the transfer assy.... thats the black roller on the door... also play with sim mode 101....
May 14, 2009 | Kyocera Mita KM-4035 Printer
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
