Question about Borland Turbo C++ 4.5 Full Version for PC
How can i program flames in borland c++ using string ?
Borland c++4.5 can not open sdio.h for windows7
stdio.h is a C header file
#include <iostream> //C++ for standard input output
or you can use
#include <cstdlib> // C standard library might work
Sep 11, 2012 | Borland Turbo C++ 3.0 Full Version...
Write a program that accept a number and output its equivalent in word
Use the value that will be printed by the keyboar.
After you enter the value.
You have to cast the type you have used as integer or float into string or character type.
So here the type casting of the datatype will be used.
Oct 10, 2011 | Borland Turbo C++ 4.5 Full Version for PC
I am not able to installing turboc++4.5 in the windows seven based os dell laptop,pls suggest me which version i require?
You must doewnload 64 bit versions borland c++. It works on win 7 fine. Download appropriate program for your os. Thanks for using FixYa.
Sep 11, 2011 | Borland Turbo C++ 4.5 Full Version for PC
How to uninstall Borland Turbo C++ 4.5 for Windows ?
Go to Control Panel->Add/Remove Programs and search for Borland Turbo C++. Then click on remove.
Mar 24, 2011 | Borland Turbo C++ 4.5 Full Version for PC
How to install borland turbo c 3.0 in windows 7?
borland turbo c version 3.0 is not compatible with windows 7 i myself have faced the problem try using borland c++ version 4.5 its works fine
vote me click thumbs
Feb 16, 2011 | Borland Turbo C++ 4.5 Full Version for PC
From where i can download borland c ??
You can download the free versions from Borland but why would you want to. Do a Search on the Internet:
Free C++ Compilers
From the list locate Quincy2002, and look at some of the DOS based compilers. Much easier to use and in my opinion better overall performance.
Jun 27, 2010 | Borland Turbo C++ 4.5 Full Version for PC
Where i can get software for C Programing language and what is the software name...........?
STEP 1 : Download the Borland Compiler
https://downloads.embarcadero.com/item/24778
STEP2 : Run the setup program
By default, it should install everything to C:\Borland\BCC55
STEP 3 : Add the /bin directory to the system PATH
>C:\Borland\BCC55\bin\bcc32 OR >c32
After the setup program is run (step 2), a whole bunch of executable programs are placed in a new directory : C:\Borland\BCC55\Bin. This step makes it possible for the Operating System (Windows) to find these new executables by name. If you don't do this, then you will need to specify the full path to bcc32 every time you use it.
To do this on Windows XP
Bring up the Environmental Variables :
•Right Click "My Computer" ( Depending on how your system is set-up, "My Computer" is either on your Desktop or in your Start Menu )
•Select "Properties"
•Activate the "Advanced" Tab
•Click the "Environmental Variables" Button
Append ";C:\Borland\BCC44\bin" to the PATH variable (figure 3-2)
•Select the PATH variable under User Variables
Note: The PATH variable may appear under both System Variables and User Variables. This How-To changes the User Variable.
•Click the EDIT button below the list
•In the "Edit User Variable" box that pops up, move the cursor to the end of the Variable Value field
•Add a semi-colon ";" to the end of the current value
Note: If the value is empty, then you do not need to add a semi-colon
•Add the path "C:\Borland\BCC55\bin" after the semi-colon
•"OK" your way out of the dialogs
STEP 4 : Set up some configuration files
you should create a configuration file for the bcc32 program that tells it where to find its libraries and include files.
•The file should be named bcc32.cfg
•It should be placed in the same bin directory where bcc32.exe is located
(C:\Borland\BCC55\Bin)
•The contents of the file are the command line options for bcc32 stating the location of include files and libraries:
-I"C:\Borland\BCC55\Include"
-L"C:\Borland\BCC55\Lib"
Regards,
Soul_srch007
Dec 06, 2009 | Microsoft Windows XP Professional
Borland Turbo C++ 4.5 Full Version for PC Logo
192 people viewed this question
Top Borland Computers & Internet Experts
Tony
Yoav Shilon
Yoav Shilon
Are you a Borland Computer and Internet Expert? Answer questions, earn points and help others
