Question about Ruud Handler Air Conditioner
Heater work when switch to fan on but doesnt work when swithed to auto but the ac works on auto or on, conufused please help
  • 1 more comment
  • tuff1083 Dec 19, 2007
    it does make he but its as you said only after the delay relay clicks. It blow heat until it hits the temp and then just continues to blow air no more heat. yes there is a jumper wire from the rc to rh
  • tuff1083 Dec 20, 2007
    ok ill try that thank you and that could solve the problem even when fan is switched to auto.
  • madloser Apr 23, 2008
    mine is only a heater model#UGUC-09EA about 25 years old and my unit heats great but when it reaches temp the fan continous to run and must be unpluged to turn off thermo is fine,
  • 288 Answers
When switched to on does it make heat or is ir just the fan blowing? Take the first cover off the thermostat and see if there is a jumper wire from RC to RH. If not you need to add one. Also, the heat doesn't come on instantly like the A/C, it takes a couple of minutes for the pilot to lite, the burners to come on and then the time/temp delay relay will click on the fan motor, this may take a few minutes.
Posted on Dec 19, 2007
  • Rob Luna
    Rob Luna Dec 20, 2007
    If you are getting burners and then fan, then when it makes the set temperature set on the thermostat, all is working properly. The fan will continue to blow after the burners go out because of the time/remp. delay relay. If the burners are cutting out before the desired temp. is reached, then it is either the aforementioned relay or the safety roll out switch. An easy way to check them is to by-pass them i.e.; connect the wires together, see if it changes anything. Also some thermal discs (the safety switch) will have a re-set tab on it.
  • Rob Luna
    YES, the fan needs to be switched to auto, if not, on some models it will by-pass the other functions of the system altogether.
Ac/heater fan doesn't work
According to my wiring diagram, the blue and white wire from the blower motor gets power from the key switch. The fan switch and resistor grounds the motor.
No blower fuse is listed.
Feb 03, 2013 | 1988 Honda Accord 4 Door
Ac fan motor doesnt work on low speeds only on
I will assume the heater fan also doesn't work on low. You will need to replace the fan speed selector switch
Jul 26, 2010 | 2006 Isuzu i-280
95 chevy truck AC/heater fan does not work on high lower speeds do work
Had same problem with my 96 Yucon. I replaced the blower swith and all is well. My switch showed signs of overheating. Part of it was somewhat melted. I was able to get the connections apart and put in the new switch and it now is A-OK>
Hope this helps
Jul 10, 2009 | Heating & Cooling
2000 grand prix fan speed
i have been having that same exact problem with my 2002 grand prix for over a year now, and when my ac is on the lower setting the it doesnt work plus the headlights and lights on my dash go out. On Max everything works. i changed the blower resistor(about $35), still doesnt work. i changed all relays and fuses related to the ac, still doesnt work. i changed out the actual ac control switch in the dash, still doesnt work. i have changed everything but the blower motor and have asked every mechanic and auto parts retailer i come across and no one knows the answer. The best answer i got is that it is probably a wiring problem like a short somewhere.
May 28, 2009 | 2000 Pontiac Grand Prix
1998 olds 88 dash heater vacuum
on the right side of steering colum there is a plug. there is a wire that gets warm and loses connection. check by moving plug. my heater and ac would not work and caused the vacume swith to stay open.
Jan 18, 2009 | Oldsmobile Regency Cars & Trucks
Heat/AC doesnt work
is the switch on dash in one piece as on these cars the bottom of the switch breaks ,you push switch to turn on a/c and turn it for the fan left is re circulate right is fan with fresh air in as well
Jan 08, 2009 | 1999 Ford Escort
Faulty AC swith vw polo 2005
Hi Bronkhhl ? Sounds like your heater motor resistor ir wiring is faulty . Regarsd VW Audi tech
Jan 06, 2009 | 2001 Volkswagen Beetle
Question on a day and night gas forced air heater
it very well sounds like your fan switch , does your fan work at all, like in ac mode on by turning the fan on/auto switch on the thermostat to ON. If the fan does come on its the more and likely the limit switch. if it doesnt come on it could be the motor or the run capacitor. the limit switch has a dial on it that as it heats up it spins clicking on at a desired set temp ussually about 120 to 150 degrees F. turning on the fan if the fan doen't come in the the next setting clicks off the gas valve turning off the burners ussually set at about 220 degrees F. now if the fan is working when the heater is satisfied there is a setting at about 90 deegrees F. that shuts the fan off hope this helps
Jan 05, 2009 | Honeywell L4064B2236 Fan/Limit Control...
Heating & Cooling Logo
56 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
