Bios recovery my bios seems to have some problem specialy at the booting of the pc... you need to press F1 to proceed to windows...do you have some solution with this problem thx...
    Problem Solver:
  • 16 Answers
Hi
The bios is complaining something isnt right at boot up. Could be an attached device is broken or loose. Also check for a stuck key on your keyboard.
Posted on Sep 25, 2009
How to reset all settings to my lenovo a269i mobile thru pc
Is it a think pad ?
Power off your Thinkpad.
Press and hold the "F1" key and turn your Thinkpad on, still holding the "F1" key down.
Release the "F1" key when you hear repeating beeps. Wait for the "IBM BIOS Setup Utility" to load.
Select "Startup" using the arrow keys and press "Enter."
Select "Boot" or "Startup Sequence" and press "Enter."
Select "CD-ROM Drive."
Press the "F6" key repeatedly until "CD-ROM Drive" sits at the top of the list.
Insert your recovery CD into your Thinkpad's CD-ROM drive.
If you have multiple recovery CDs, insert the CD that has "Disc 1" on its label.
Press "F10" to save your changes and exit the BIOS Utility.
Select "Yes" and press "Enter" when the "Setup Confirmation" window appears.
Your laptop will restart. Wait for the Recovery Utility to load.
Select "Restore to Factory Specifications" to erase the contents of your hard drive and reinstall the Windows version and drivers that your Thinkpad originally came with.
Follow the Recovery Utility's onscreen instructions.
When prompted to insert another disc, do so according to the numerical labels on your recovery CDs (e.g., insert "Disc 2" after "Disc 1" and "Disc 3" after "Disc 2").
Your Thinkpad restarts when the restore process finishes. Power off your Thinkpad.
Hold down the "F1" key and power on your laptop to access the "IBM BIOS Setup Utility."
Press "F9."
Select "Setup Defaults" from the menu and press "Enter" so that your Thinkpad no longer boots from the CD-ROM drive.
Press "F10" and select "Yes" to confirm your changes.
Your Thinkpad will restart and load your newly installed operating system.
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-61432
ThinkVantage Technologies downloads
Feb 20, 2014 | Computers & Internet
How do I do a full system recovery or an emachines et 1161-01
most pc maker has an aditional partition called recovery...you can use it since the bios boot
press f1 for bios setup
pres f10 for recovery
press f12 for boot order all you need to do is select recovery
May 17, 2011 | eMachines ET1161-03 PC Desktop
I use a sony vaio vpceb 290x laptop and recently erased and wiped all data off it.naw my recovery disc is broken and i need to restore my pc back to its original factory seettings.pls help me,i am heavy...
If you have a recovery partition on the pc then you can use that. Hit the power button as soon as the vaio splash screen comes up look at the bottom of the screen if you see a recovery option then you have one. If you don't see one you can try tapping the f11 key right after you hit the power button to try and bring up the recovery partition if present. If neither get you to a recovery partition you can order a recovery disc from sony Or borrow an OS disc from a friend whether it be xp vista or 7 and then it will ask for a product key. It will be located on the bottom of you laptop. You would also have to download the drivers that make all your hardware work from sony's download page while on another pc connected to the internet. You can obtain the drivers by simple going to sony's homepage sony.com select service&support, then Drivers\Software from the menu at the top of the page. Select your model and download the drivers to a jump drive so that you can transfer them back to the vaio to install.
May 07, 2011 | Sony VAIO VPCEB290X PC Notebook
My desktop compaq presario s4300nx starts up , i can accses set up with f1 but cant start recovery with F10 however the F10 button works in setup, no good to me, ...i have recovery disks the pc just...
you will need a Windows boot disk / Windows install disk / WinXP disk to reboot the PC and install / or repair your OS
rescue disk will not boot your PC
to enable that you need to enter the BIOS, press F1, F2 or Del to enter BIOS , then you need to look for the BOOT seq in BIOS, change that to CD DVD drive as the 1st boot device, Save and Exit and insert the boot CD and restart
this should give you the solution
Dec 16, 2010 | HP Compaq Presario S4300NX (DF216A#ABA) PC...
Monitor went flashing. Won't boot. Says missing
You need to repair your windows system files.
for that insert windows disk or recovery disk into cd /dvd rom then when you power up the computer press F1 or F2 or del or ALT+F2 key to enter in bios then you can see bios configuration page then go to boot menu and set first boot device as cd/dvd rom then save settings and exit from bios .
then it boot with disk follow the procedure on screen then first choose recovery console then type in console "chkdsk /r" it fix and recovers error on harddrive.
Then restart computer then again boot and this time choose R for "Repair previous windows" then it repair it then you can use your windows again.
Let me know if you need further assistance.
Thanks for using FixYa.
Apr 02, 2010 | E-Machines W3107 (RBW3107) PC Desktop
How do I boot up with Recovery CD; what do I type when prompted?
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set frist boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"
Then type "y"
Then it fix error on hard drive.
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windwos " then it repairs old windows then it loads again old windows.
Jan 10, 2010 | Dell Vostro 200 PC Desktop
Packard bell pentium3 windows me
F1 is probably the key to enter the Bios setup utility. Press and hold the F1 key immediately after you start the machine. Go to the boot priority section, and set your CD-Rom as first boot device. Press f10 to save the settings and reboot with your recovery disk installed
Apr 29, 2009 | Packard Bell iMedia SL 9553 (P660401806)...
Need to set back to factory settings
There are a few ways you can do that, when you start up your pc at the top left corner it will say press f11 for recovery, it will only give you a few seconds to press it, if you press it you will be given options on how to start your recovery, or you can goto your start menu goto programs then scroll to system recovery, or you can restart your pc with the recovery disc that came with laptop to start system recovery.
Mar 30, 2009 | Gateway MT6840 Notebook
Only getting EMachines/Windows XP Logo when boot up T3882
you have not set the cdrom as first boot device in the bios (press F2 or Del on boot up to get in bios), choose cd as first boot device, save settings and restart the pc with your cd in the drive and then when prompted press enter
Aug 18, 2008 | E-Machines eMachines Desktop PC
Reformatting my computer
  • Using System Recovery CDs
  • Change the boot order in the BIOS:-
  • Turn off the computer:
  • Disconnect devices that are connected to USB, Fire wire, parallel and serial ports, except the keyboard, the mouse anb Internet Connection.
  • Turn on the computer.
  • When the color screen with the logo appears, press the F1 key on the keyboard until Entering SETUP is displayed. (You only have a few seconds to press the F1 key before the normal startup process continues.)
  • Wait until the BIOS setup program opens.
  • Press the right arrow key to select Boot.
  • Press the down arrow key to select Boot Device Priority, and then press Enter on the keyboard.
  • Change the first boot device to CD-ROM using one of these methods:
  • Press the down arrow key to select the CD-ROM item. Press the + (plus) key to move the CD-ROM item up until it is the first item in the list.
  • Press the down arrow key to highlight the First Boot Device selection. Press the + (plus) key until CD-ROM is the selection.
  • Start the recovery:-
  • Press the Eject button on the top CD-ROM drive, and wait for the tray to open. Insert the System Recovery CD #1 and close the tray.
  • Press the F10 key to save the changes and exit BIOS.
  • With Yes selected, press Enter.
  • The recovery window automatically starts; wait for the onscreen instructions to display, and then follow the instructions:-
  • Press R, and then press the F key again.
  • Click yes to perform the full system recovery.
  • Insert the remaining CDs when directed.
  • When the recovery program finishes, click Restart to restart the computer.
  • Before the computer restarts, the CD tray ejects. Remove the CD
  • Return the BIOS to the previous setting
  • When the color screen with the logo appears, press the F1 key on the keyboard until Entering SETUP is displayed. (You only have a few seconds to press the F1 key before the normal startup process continues.) Wait until the BIOS setup program opens.
  • Press F5 Key to Set Default Settings in BIOS.
  • Select yes and press Enter.
  • Complete the recovery
  • After the computer restarts, a series of startup screens appear. Complete Microsoft Windows setup as follows:
  • Complete the registration process, and then reconnect the devices that were disconnected earlier.
  • Reinstall software that did not originally come with the computer.
  • Write data files that were previously saved on the backup CD or diskette you made from the hard disk.
Jul 04, 2008 | Computers & Internet
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
