Question about Samsung Digimax A50 Digital Camera
Battery problem I have bought a range of chargeable, alkaline batteries but they don't seem to last very long. My battery indicator does not work properly even when I put new batteries.
SOURCE: displays "low battery" always
I had exactly this problem and found the solution - I was using the wrong type of batteries.
You might be doing the same so what you need to do is check to see what mAh the batteries you're using. I was using Energizer rechargables with 1300mAh when the camera stopped working and switched to 2500mAh rechargables (on the advice of a friend) as a last desperate attempt to get it to work and it solved my problem. I got 2500mAh Energizer rechargables and would advise the same but you should go for batteries with at least 2100mAh.
I hope this helps some people :)
Posted on Jun 12, 2008
SOURCE: Battery dies quickly
use rechargable batteries
Posted on Mar 03, 2009
SOURCE: My Samsung Digimax 420 keeps saying low battery!
Check that you are using the correct type of batteries and that they are rechageable as i found i had a similer problem when using just normal non recargeable
Posted on Mar 08, 2009
  • 70 Answers
SOURCE: Camera shows low Battery and goes off even if u insert a new one
are you using NiMh rechargeable batteries?
If yes, check that they are fully charged. If that doesn't do the trick, sounds like it might be a power circuit issue. Samsung is in Secaucus, NJ
or SamsungUSA on the web
Posted on Apr 15, 2009
TomSolomon
  • 50 Answers
SOURCE: Low Battery Light Even with Brand New Lithium Batteries
If indeed the batteries are brand new and without a doubt charged,
then you definitely have a hardware problem in the camera.
You're probably going to have to give it in to be serviced.
Hope I helped!
Tom
Posted on Jun 20, 2009
Hi, unable to power ON wi th new Alkaline batteries LED Indicators does not light up
Although all alkaline batteries are nominally the same voltage, many of the cheaper ones do not deliver sufficient power for a digital camera. try using the most powerful NiMH re-chargeable batteries you can find - works out cheaper in the long run, and also far less likely to leak if left in the camera.
Apr 11, 2016 | Cameras
How do you recharge the battery casio m850
if it doesn't have a jack for a charger or a charger stand to sit it in then it will not be re-chargeable as such
you will have to remove the battery and check if it is an alkaline battery ( not re-chargeable ) or a rechargeable battery in which case you will need a battery charger for that type of battery
If that is the case get spares and have a fully charged one on hand to just swap over while the other is charging
Sep 13, 2015 | Casio Cameras
Cobra cxt195 won't charge
There is nothing wrong with your battery or your radio. you bought it a walmart at the lowest price available. this means you get what you pay for i.e. no frills the indicator flashing means it is connected to a power source and is charging / Maintaining the battery. it will only come on again when the battery is below 1/8th of the battery life and flash to let you know it needs to be charged again. there is no battery level indicator. these will work just fine but dont expect the 1-16 mile range they advertize unless you have full charge alkaline batteries and a direct line of sight to the one you are talking to.
Dec 12, 2013 | Radio Communications
I got the kodak easy share 143 model camera coming brand new off of ebay yesterday,,,but it keeps saying my batteries are half drained, then dead after a couple of photos. Then if they're dead it...
Alkaline batteries just don't have the power for more than a few pictures in today's power hungry digital cameras. Some batteries may also have reached their shelf life at the store, and though brand-new right out of the package may even have problems just powering startup of the camera. The one's that came with your camera are just to show you that the camera works, but as you've discovered, they'll only last for a few pictures. Digital cameras that use AA's for the most part should only be used with modern rechargeable batteries. If you read the camera's instruction manual concerning batteries, you should see the same recommendation.
Modern rechargeable batteries have over 5 times the power density of alkaline batteries (that's right, they last up to 5 times longer than an alkaline battery. And you can recharge them over and over!). Keep in mind rechargeable batteries will save you much money in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may be angry with yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
Jun 26, 2011 | Kodak Cameras
I've been using Olympus 550 UZ camera for over a year now. I am facing problem with the life of battery though. Tried Energizer and Duracel batteries. 10-15photos and the battery is drained down. Is there...
Switch from alkaline batteries to pre-charged Nickel Metal-hydride (NiMH).
My best experience is with these batteries:
#1. RayoVac (pre-charged)
#2. Kodak (pre-charged)
#3 Energizer (rechargeable)
Find them at WalMart or online
"pre-charged" are new technology rechargeable batteries. They are GREAT! They outlast alkaline at least 15 times per charge.
Sep 28, 2009 | Olympus SP-550 UZ Digital Camera
I keep getting a battery depleted message
I don't know but that would be wierd if this was Paula Meadows from McAlester
Sep 08, 2009 | Pentax K100D Digital Camera
Battery life
The rechargeables are only meant to last a couple years maximum (pretty good that you got three out of them). Also rechargeable NiMH's have approximately 5 times the power of standard alkaline batteries. Alkaline batteries should only be used in emergencies in digital cameras as they will only last for a short while before they are drained (as you've discovered).
The obvious solution is that it's time to consider purchasing a new set of rechargeable NiMH batteries. Look on the package for a power rating of at least 2,500 mah. Avoid batteries that do not list the power rating as they are generally inferior batteries.
Jul 20, 2009 | Canon PowerShot A710 IS Digital Camera
Canon PowerShot A630 power problem: NiMH batteries no longer work
I dont agree, I have tried several different batterie types and the batteries are draining almost instantly with the camera and they are not actually being drained. I think the camera itself is at the end of its life...as I have used rechargeable batteries for the last few years and now they wont even show as being charged on the camera. It stinks Im in your same spot now...no batteries are lasting even the brand new lithium ones...it has nothing to do with the battery "juice" but something with the canon supply power not recognizing/recieving the juice. Im not a canon expert, but I think the problem is more than the battery here Steve and im confused at the solution as well.
Apr 02, 2009 | Canon PowerShot A630 Digital Camera
Kodak Z812 shuts off automatically
It is a high-powered camera, also knows as a GREAT camera. Use CRV-3 lithium duracell batteries. I have the same camera and the same "problem", but when I use that battery it lasts forever.
Dec 03, 2008 | Kodak EasyShare Z812 IS Digital Camera
Change batteries message pops up with new batteries
Chargeable batteries usually last for a year or two. Alkaline batteries should only be expected to last for around a dozen shots (as such, NEVER rely on alkaline batteries). Recommend buying another set of NiMH rechargeables. Make sure you get 2500 mah or better power rating (look on the package).
Jun 23, 2008 | Canon PowerShot A85 Digital Camera
Cameras Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
