Question about Buffalo Technology 250GB MINISTATION TURBO USB 2.0 5400 RPM PORTABLE HDD 250 GB Hard Drive
When i connect my buffalo mini station turbo usb to computer then only gren light is on ;don't show my mini station drive in my computer
mrsjill
  • 41 Answers
SOURCE: Laptop does not recognize my Drive Station,
I will help you diagnose.
Lets check the easy stuff first.
1. First- Just switch to a different usb port.
Try?
2. Try using a different cable.
Try?
3. go to my computer, properties, hardware, devices, scroll down- delete usbs-
unplug your harddrive from your computer -after having turned it off of course.
leave off for eight seconds
Plug hard drive back in
Try?
4. Try restore computer to a time the Hard Drive Worked?
Try?
Diagnosis Crashed Drive
Posted on Mar 26, 2009
Damilare
  • 358 Answers
SOURCE: Buffalo USB drive is not located by Mac Powerbook when connected
You can try this out:
After powering up your system, and you have plugged the flash drive, then Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your flash drive, and right click on it. then select "Change Drive letter and Paths", and give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
This should make your Flash Drive to be detected automatically.
Hope this helps you out.
Posted on Jul 21, 2009
AldRezaine
  • 995 Answers
SOURCE: I have a 250GB Buffalo Turbo USB Hardrive. Until
Try to insert it to the other usb ports and see if it works fine. If it doesn't, then probably there is a problem with it. But try to insert other usb devices in the usb ports of your computer, if it does'nt recognize also then the problem is in your usb ports.
Posted on Oct 30, 2009
  • 128 Answers
SOURCE: My buffalo portable drive 250g is not working!
it bcause of virues try it in another pc or laptop
Posted on Jun 02, 2010
  • 10406 Answers
SOURCE: When i connect Buffalo Mini
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files.
For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge guarantee".
Posted on Nov 11, 2010
I have a buffalo mini station 500GB hard disk. its giving me only 10-40 kbps coping speed in every system and maximum time it shows 0B/s (takes forever) and i have to cancel it and start coping again . it...
A the drive is usb 2.0. The usb buss is limited by the number of connections on that buss. Disconnect everything but the drive from the usb ports.
How old is your computer?
Apr 04, 2014 | Buffalo Technology Computers & Internet
Need to format my portable HD (Buffalo 3.5 500GB Mini-station) before using as External HDD for my TV (LG 42LA6200)?
BUFFALO TOOLS Buffalo Tools is a feature-rich suite of optional software included on many Buffalo Drive-Station and Mini Station storage products. Any or all of the following components of Buffalo Tools may be installed on Windows PCs.
Buffalo's Backup Utility is an easy-to-use and fully featured backup software for Windows PCs and can be used to back up one or multiple computers with a single Buffalo external hard drive.ECO Manager is an energy efficiency tool used to conserve energy and reduce battery consumption by regulating the power usage of the hard drive, cutting power to the drive during extended periods of inactivity.RAMDISK is a simple utility that allows you to create a RAM disk on your Windows PC which creates a small, but extremely fast environment to work on files in.SecureLock software for Windows provides complete control of the data encryption on your Buffalo external hard drive, providing password protection and software data encryption.
Only basic external hard drive functionality is supported with this operating system; some included utilities may not work. The HDD default format is NTFS; to work with Mac, reformat the HDD using Mac Disk Utility.
I would plug it into a windows 7 or Vista and the computer's USB. The computer should recognize it. Click start then computer and find the icon for your drive and right click your Icon. In the drop-down window look for 'format' and that should help you format your drive. is a feature-rich suite of optional software included on many Buffalo Drive-Station and Mini Station storage products. Any or all of the following components of Buffalo Tools may be installed on Windows PCs.Buffalo's Backup Utility is an easy-to-use and fully featured backup software for Windows PCs and can be used to back up one or multiple computers with a single Buffalo external hard drive.ECO Manager is an energy efficiency tool used to conserve energy and reduce battery consumption by regulating the power usage of the hard drive, cutting power to the drive during extended periods of inactivity.RAMDISK is a simple utility that allows you to create a RAM disk on your Windows PC which creates a small, but extremely fast environment to work on files in.SecureLock software for Windows provides complete control of the data encryption on your Buffalo external hard drive, providing password protection and software data encryption.
Oct 21, 2013 | LG 42" 6200 Series LED HDTV - 42LA6200
Buffalo Ministation not flashing or recognized
Im having the same problem sound like your cable is not working or you need a new case because the pins are broken.
Jul 22, 2013 | Buffalo Technology 320GB MINISTATION TURBO...
When i connect Buffalo Mini Station HD-PF500U2/BK-AP to my laptop, the green signal blinks with beep sound and thereafter, the device is not detected. How can i solve this problem. I have important...
* the USB cable
* the power-adapter
Nov 11, 2010 | Buffalo Technology 320GB MINISTATION TURBO...
When I connect my buffalo driver the yellow light flashes and I am unable to locate the external drive on my computer.. HELP!!!!
Try to plug your External Drive to other usb port or to other computer, or change the cable.
let me know the result.
dm
Mar 21, 2010 | Buffalo Technology 250GB MINISTATION TURBO...
Cannot access data in my buffalo ministation orange light showing,after it fell down
Try accessing it in another USB port or computer. If still not, it may unfortunately be damaged. You may be able to get it replaced under warranty.
Jul 07, 2009 | Buffalo Technology 320GB MINISTATION TURBO...
Buffalo Technology 250GB MINISTATION TURBO USB 2.0 5400 RPM PORTABLE HDD 250 GB Hard Drive Logo
254 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
Ali Reza
Level 1 Expert
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
