Question about Sharp 32C-240 32" TV
Tv picture going off - Sharp 32C-240 32" TV
  • Lavell Turner
    Lavell Turner May 11, 2010
    Does the television turn off completely or does the video goes and come when it wants to? Do you still have sound when the picture goes out? If you still have sound but the picture goes intermittently then you have bad solder connections around the Flyback transformer on the power supply. Having a technician come and resolder the power section and deflection circuits will solve this problem.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Posted on Apr 15, 2010
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
TV loses picture
Sounds like your picture tube or bulb is going out. It depends on what kind of tv ( rp, lcd, plasma) it could also be a component issue.
Nov 22, 2013 | Televison & Video
Picture to big
Try going into picture setting and reduce the zoom angle or if it's whilst you are watching Sky TV go into System Settings, Picture Settings and change the Aspect Ratio (ie. From 4:3 to 16:9 or visa versa)
Gadget
Feb 21, 2012 | Sansui 19 in. LCD TV
Picture has too much blue, and picture is dark
Go to your TV MENU (you can find the button on the remote or on the TV itself)
Go to PICTURE SETTINGS- here you will find color settings and brightness settings
Go to COLOR SETTINGS and just adjust the bars until the picture on the screen is the right color.
Go back and click on BRIGHTNESS- here you can adjust the bar to make it brighter and easier to see your picture.
Save your settings and exit the tv menu.
May 23, 2011 | Televison & Video
NO SOUND GOOD PICTURE TV IS ONLY 5 MONTHS OLD
Unplug,replug the tv back about an hour later.Go into the tv menu,go to SOUND,go down to reset it to back to factory setting.The sound now should return,not,than ur tv the Tuner board have problems,call for warrenty serviced.
Jun 28, 2010 | Toshiba REGZA 47HL167 TV
Have flat panel hdtv monitor 1080i samsung no picture or sound
Tv has no picture or sound; will go out while watching. The picture will go into a line and sound and picture will go out; shortly after that tv will turn off. Did this last nite and I did not turn back on until this morning, it worked no problem. On for couple of hours and now it's out again. What could be problem and how do I fix myself
Feb 27, 2010 | Televison & Video
Phillips magnavox 50" projection TV shows a light picture
it sounds like the tv is going out. you might call a repairman before it does so you dont lose the tv.
Jan 27, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Problems with the picture mode on my samsung 46''
Your TV is in DEMO-STORE MODE.
Go to menu, find Plug & Play option, start it, and when asked, select Home Mode, than Enter and than just Exit.
Enjoy Your TV!
Jan 09, 2009 | Samsung LN46A550 LCD TV
Tv pictures suddenly goes dark blue
the tube could be going out. Do you have a warranty on that?
Nov 01, 2008 | Televison & Video
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Sharp 32C-240 32" TV Logo
74 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
