Question about Hitachi 53UDX10B 53" Rear Projection Television
Red double I am seeing red on both side of pic...the letters look double with a red ligne on the outside...migic does not help....what do i do hitachi 53' 6 years old, started yesterday when i moved the set
  • rnkoko Dec 18, 2007
    what is "IC"?
  • rnkoko Dec 22, 2007
    I need to remove the board that hold part stk392-110 and replace it with stk394-160....how do i do that...that board is attach to the next one ...do i have to take the entire tray out to be able to do the soldering?
    Genius:
  • 1,694 Answers
Bad solder connects in convergence circuit...a solid fix is to
replace STK392-110 convergence IC's with upgrade STK394-160
Part # CZ 01341... you need two.....or buy kit # X480295 ( one )
Look for any damaged resistors near IC's.............T.
Posted on Dec 18, 2007
  • Vista Electronics Dec 18, 2007
    An IC is an Integrated circuit....a part by design that has
    many functions going on inside of it..........T.
  • Vista Electronics Dec 23, 2007
    Please get a technician to help you....damage may result if you proceed without skilled pro help or service manual instructions..
    Some chassis require entire tray to be pulled, some others can
    remove one circuit board.......Also, B+ resistors must be inspected for burn or increase in value.............T.
My red wont line up left to right , picture is good in the middle of the screen but not on the sides
The R,G,B colors alignment wouldn't line.That mean ur tv have a problems known as a convergence problems,it dead.The tv convergence board require the 2 STK convergence ICS and some or all it resisrors to be replaced,to solved the convergence problems.The shop will cost $300-350 for parts and labors.
Jul 06, 2010 | Hitachi 46F500 46" Rear Projection...
My tv shows double picture any letters on screen at bottom show twice in red and in white the red lettering is arced above the white
Replace both of your STK ICs STK392-110s Mats has them 1-800-628-1118 They are big blk IC with part number on them.
Jun 01, 2010 | Hitachi 53FDX20B 53" Rear Projection...
My hitachi 50v500 has double letters/numbers... picture doesnt seem to be alligned properly? Everything has a matching shadow just to the left.
I am answering this because I know this set and do not like the answers you have received.
If you see a slight "ghost" to the left or right of lettering--it can be corrected with the remote--there is a exact way to do this--I have done it before and have instructions based on a service bulletin from Hitachi.
Confirm you have the ghosting to right or left of letters and I would be happy to post the instructions to correct that--all of it is done with the Hitachi remote that came with the set.
If you decide to do it I will give you the instructions and help you do it.
I have helped 4 other people here with the exact same set and problem.
Understand that not all people here know what they are talking about-I am sorry you got a poor answer, but I know this set well.
You want to fix it for free? I can help you.
Keep in mind I am in California and possible time differences.
Regards, SD TECH
Jan 01, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
Seeing doubles
there is an adjustment called convergence.the convergence setup generates a crosshatch.you need to adjust the red deflection.this is a common thing when the t.v gets moved.the crosshatch or convergence button is mostly on the front control panel.consult the manual for where it is.
May 22, 2009 | Hitachi 61SDX01B 61" Rear Projection...
TV..everything works...but screen goes red...I smack it, it goes back to normal, but then back to red.
it soinds like a convergence problem, i would try haveing someone take a look at it
May 20, 2009 | Hitachi 65F59 65" HDTV
DOUBLE LETTERING/RED
Good Day, TYREKCURRY;
Your TV is ONLY 7 years old, it's only half way through it's life. It will cost about $550.00 depending area. Repair Convergence Circuit FOR .5k or buy new TV for 1.2 k? I would get TV fixed. The HIT is a great TV. Get an estimate from a Factory Authorized Service Center B-4 repair> Good Luck, big IRISH.
Sep 01, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Red streaks
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 06, 2007 | Hitachi 53UWX10B 53" Rear Projection...
Problem in Hitachi 53UWX10BA
The convergence ic's, and related components that could'be affected need to be replaced cost to repair 250.00 2hrs job max with alignment this depending on the tech. If you need more help let me know
Jun 14, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Picture is yellow and green
Your missing the red drive on the set. Its most likly the picture tube. Its a possibility that the red drive circuit could be not working so the best thing to do is take off the gree picture tube socket and put the green board on the red tube. Of course do all this when the set is unplugged. if you have no tv experience. its not a good idea to be messing around inside of these sets.
Sep 02, 2006 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
42 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
