Question about HP Computers & Internet
I have HP 2000 laptop. when I switch the computer no dispaly aqppears. I hear a tone form the speaker only.
Try connecting an external monitor, if that does not work you must have a bad board
Posted on Sep 25, 2009
Why has the phone reversed, dial tone works only when phone is hung up why?
If I understand you correctly, when you leave the handset in the cradle and press a line, you can hear the dial tone. But, if you lift the handset and then select a line you don't hear anything through the headset. If this is correct, I suspect the handset is damaged, the cord is damaged, or if you're lucky, the clips may not be plugged all the way in on both sides. If you have another phone that is the same, you can switch handsets to test this theory.
Oct 19, 2014 | NEC 22b Hf Aspirephone-bk Stock No....
My laptop have inbuilt speakers but when i switch to volume control option it dispalys a message that no audio output device is installed and sound is also not coming
Check the Sound Drivers in device manager if the device is not installed you need to download the drivers from HP Web site by using the Product Number
If you can please specify the Product Number and Serial Number of the Laptop
Jul 14, 2012 | HP Compaq nc6320 Notebook
Where is the wireless switch
On the front edge of the laptop by the right speaker, there is a switch just left of the speaker. That is the wireless switch, to the left of that switch is another and that is the bluetooth radio switch. Below is a link to the service manual that goes over every aspect of your laptop.
http://tim.id.au/laptops/acer/travelmate%204220%202480%20aspire%205600.pdf
Jun 24, 2010 | Acer TravelMate 2480 Notebook
How do I turn off the ringer volume??
I found this at hp website.
Adjust the volume
Your HP all-in-one provides three levels for adjusting the ring and speaker volume.
The ring volume is the volume of the phone rings. The speaker volume is the level of
everything else, such as the dial tones, fax tones, and button press beeps. The default
setting is Soft.
1 Press Setup.
2 Press 4, and then press 6.
This selects Basic Fax Setup and then selects Ring and Beep Volume.
3 Press to select one of the options: Soft, Loud, or Off.
Note If you select Off, you will not hear a dial tone, fax tones, or incoming ring
tones.
4 Press OK.
Feb 22, 2010 | HP OfficeJet 6210 All-In-One InkJet...
I cannot hear sound out of my laptop computer speakers
Please check if you can hear the windows start up tone when you start your system. Then check for the sound drivers by going to run and then type devmgmt.msc This will take you to device manager. You can check the drivers there.
Oct 19, 2009 | Dell Inspiron 700m Notebook
No dispaly
check the lcd connector if ists solid then you may have breaks in the the signal cable see if you can find a replacment cable if not then its a replacement screen and that can be tough to track down
Aug 06, 2009 | HP Pavilion dv6000z Notebook
My HP Photosmart C5280 All-in-one Printer doesn't seem to be getting the signal from my Dell Inspiron E1705 laptop to print. Can't figure out what I'm doing wrong. Can you please help? Rudy
Can the printer accomplish a self test print?
Have you tried re-seating the USB or re-connecting the printer cable?
Have you tried moving the USB cable to another port on the computer to determine if it is communicating with the computer. When you un-plug, and re-plug you should get a disconnect tone if the laptop is speaker equiped? Do you get this tone?
Nov 19, 2008 | HP Office Equipment & Supplies
Unable to hear ring tone
turn up the volume with the ringtone volume controler while on a call
Aug 11, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Cobra 2000 gtl
cobra 2000
am carrier 4.4 volts will not ajust...ssb carrier will 3.5 volt will ajust but max out put is only 3.5 volts.losses all voltage at ssd carrier when switched to usd r lsb
Jul 03, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
Computers & Internet Logo
75 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
