Question about Kodak EasyShare Z710 Digital Camera
Will not power up with new batteries before this it would power off at random
    President:
  • 1,653 Answers
The first thing to do is check the battery contacts inside the camaeras battery compartment. Make sure they are not dirty or corroded and clean them if necessary. I have seen this problem with other models of the EasyShare wher users have used normal then rechargeable batteries that have effectively squashed the battery contacts so when then went back to using normal batteries they did not fit correctly.
Posted on Sep 25, 2009
NEW HP Spectre 13T-3000, 13.3" Touch will not run with the battery and shuts down randomly
you can use the unit without the battery. Remove the battery, plug in the charger/power supply and turn on the unit and wait for the result. if the problem persist?..... maybe the fault is in CPU fan. check the fan...overheating the processor. Cleaning the heat sync and reapplying silicon compound on CPU's can cure the problem.
Sep 02, 2014 | Computers & Internet
What would cause my apple iphone 4 keeps randomly powering off
Bad battery or contact from battery to phone.
May 27, 2014 | Apple iPhone 3G
Ford focus random power loss
Did you ever fix the problem I have a 2005 focus and its doing the same thing
Feb 01, 2013 | 2005 Ford Focus
I have Acer Aspire 3680-2022 notebook. I still have power instability after buying a new a/c adapter & new battery. When a/c plugged in, battery can randomly & rapidly drop...I get a lot of...
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Jun 03, 2011 | Acer ASPIRE 3680-2022 Notebook
My alarm is beeping randomly after going off randomly. How can I Stop it by any means necesary!
If this is battery powered, you may have a weak battery. If you have installed new batteries, be sure you use a good quality brand name. The cheaper dollar, value brands will create many problems as you describe. On the other hand you may have a bad ground that will intermittenly keep this unit from going into a set up mode for your protection. Be sure the battery is snug in its holder. If any of this info fails, by all means replace this unit. Your safety is of high priority! Thanks for asking and show all hands of support!
Apr 04, 2011 | Kidde 1275 Hardwire Smoke Alarm with Hush...
My LCD display just randomly stopped working.
replace the battery and check out firat with brand new battery.many a times it battery problem.if still the same problem its due to lcd ic faulty on the mini circuit board.that has to replaced by a service center.
Apr 03, 2009 | Olympus Stylus 850SW Digital Camera
Cell Phone randomly powers off
most cell phones have lithium batteries that only have a certain life span. It may be worth your while to buy a new battery for the phone
Nov 21, 2008 | Sanyo Katana SCP-6600 Cellular Phone
Battery charging
Does the machine boot and work just on AC?
If it does then you may have a bad battery - Does the old battery charge?
If it does not work on AC then try another AC adapter - even the generic universal kits should be enough to test it.
hopefully that's all thats wrong. let us know.
Dec 27, 2007 | HP Pavilion dv4000 Notebook
Kodak EasyShare Z710 Digital Camera Logo
78 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
