Question about Electrical Supplies
Following the purchase of a new home I want to install a new light in one room. The new light fitting has the basic connection terminals for Active, neutral and earth. The existing light on the ceiling has an additional wire connected, i.e. active, neutral, earth and one other. How do I connect the new light
  • 1 more comment
  • EECS May 11, 2010
    WHat it the extra wire connected to? Generally, you only need three wires and you have identified them correctly. I have seen 220 V AC systems with 4 wires - 2 hot wires, one neutral, and one ground. I dont know where you are writing from so I dont know your power system voltage.
  • mikeb103 May 11, 2010
    Is the additional wire originating from the fixture or the box in the ceiling? and if it's from the box in the ceiling, which of the existing fixture wires is it currenty tied into?
  • sparktgo
    sparktgo May 11, 2010
    how are the wires connected at the light? The earth only goes to one place. If there are two wires together at present at one side of the light and one on the other then keep it this way when swapping over your light
    Problem Solver:
  • 9 Answers
Please remember to turn the power off when you are doing this. the extra cable is probably a looped or joined cable. put it in a connector or solder it with tape and leave it behind the light fitting or in the terminal block. connect the same cables up in the active, neutral and earth. like for like. make certain the power is off when you do this.
Posted on Nov 14, 2009
"Hi I'm planning to install aftermarket stereo system on 2004 Nissan Maxima 3.5 SL ..Kenwood KDCX997 eXcelon ..Hifonics ZRX600.4 Car Amplifier for kicker 6.5 ..Hifonics BRX160.2 Brutus  for 2 8" inch...
If you have enough room on the outside edge of your battery's post to fit the ring terminal from your new fuse holder, and an additional 7mm nut, then just do that. If there's no way for it to fit, you can purchase an aftermarket battery terminal that has a separate post for mounting aftermarket accessories to. That would be the second option since it would require more money and effort. Below is a link for a few different battery terminals that should be able to use for your car. I haven't looked under the hood of 2004 Maxima since probably 2003 or 2004, but I hope this helps.
2004 nissan maxima battery terminals Google Search
Jun 24, 2017 | Car Audio & Video
Does the installation of a home security system cost much?
Installation of home security system depends on the company you choose. It is usually reasonable and some companies don't even charge for it.
Sep 30, 2013 | GE Iti Simon Burglar Alarm Home Security...
I HAVE AN OLDER MODEL KENMORE DRYER MODEL NUMBER 86872800 AND A NEWER HOME HOME WITH 4 CONNECTORS DRYER HAS ROOM FOR THREE HOW DO I CONNECT NEW CORD
You have to replace the dryer's 3-prong cord to 4-prong. Get yourself a 4-prong cord then on the terminal block at the rear of the dryer, connect the wires of the 4-prong cord to where the same wire colors (red, black, and white) of the 3-prong cord connects to. The only modification needs to be done is on the green/yellow stripe wire that connects from the white wire terminal to the dryer's cabinet. Remove this wire (green/yellow stripe) from the white wire terminal then connect it to the same wire color (green/yellow stripe) of the 4-prong cord and you are done. The new wire configuration would then be red, black, and white on the terminal block and green/yellow stripe wire on the cabinet.
Jun 16, 2011 | Dryers
I turned on my home theater sc-ht670, and the display shows "hello", "init ", "please" and finally "wait" and nothing happens and be left with the word...
Basic steps to check if the problem lies with the home theatre system or not.
1. First thought might be to conclude that your poor audio quality is caused by your speakers, before you immediately race out to purchase a new home theater surround sound speaker package, check the basic things first.
2. The problem might not be in the speakers, but in the amplifier or the connections from the amplifier. Checking and ensuring that the speakers are correctly connected on both ends is the first step.
3. After the connections pass examination, the next step is to check if the problem lies with the amplifier or audio speaker. Some of the lower end home theater systems come with low powered amps. Most often they do not supply sufficient power to speakers to produce the quality audio you desire. This may show up particularly if the room is large when the sound doesn't fill up the room.
4. To determine if it is indeed the amplifiers then hook up your speakers to a stereo; this generally will have a more powerful amp. If the speaker quality improves then the problem probably lies in your home theater amplifier.
If you cannot distinguish any difference, then your speakers could possibly be at fault.
5. Poor cable installation and audio speaker cable are another possible cause for consideration. Cheap workmanship can lower audio quality and home theater packages often come equipped with inexpensive poor quality cables.
6. If you experience problems with your theater system, it is always best to assume the problem lies in the connections between components first and then suspect the components themselves.
7. To ensure a great sound experience ensures that everything is properly connected, your amp is of sufficient power, and the cables are of high quality. If a person makes use of these basic easy precautions a significant amount of frustration can be eliminated. If your home theater sound isn't where you need it to be, use those hints as a blueprint as you analyze your system. If it really is time to look for new components, consider those directives as you make your next purchase.
Note : Check to see if the color is bad across all input sources. If so, make sure you have your Televisions' color settings set to your preferences. If everything looks good except, say, your DVD player, and it is connected to your TV via Component Video Connections (which is composed of three cables - Red, Green, and Blue), make sure they are matched up correctly with the Component (Red, Green, and Blue) connections on your TV. This is a common mistake as it is sometimes hard to distinguish the Green and Blue connectors if the lighting in the connection area is dim.
Mar 21, 2011 | Panasonic SC-HT670 System
I have just installed a Maytag built-in double oven to replace my old one (still working.) I shut off circuit breaker and reconnected wiring. The Control Panel and indicators on the digital readout all...
How many active terminals are there at the main terminal block in the new oven. Is this a single or 2 phase supply. Have you connected the active supply to all active terminals. If only half of the oven is working it sounds like it could be a problem at the terminal block. If so, you need to put a loop or bridge wire to the 2nd active terminal.
If all this was done correctly when connected the only other thing it could be is the electronic clock needs to be set to manual mode for the oven to work correctly.
Feb 26, 2011 | Maytag CWE5800A Electric Double Oven
Horn only works some time === right rear taillight same thing.
Hello Sir
It seem that you are facing some loose connection problems. Do check the following possibilities:
Make sure that all the fuses and relays are properly installed and intact. (Fuse box is located under the hood or underneath the steering wheel room).
Make sure that the positive terminal of the battery is properly installed and didnt have any carbon.
The connections to the horn and tail light are properly connected. (There might be some loose connections).
If all of these techniques does'nt works, you need to change the horn relay or the horn.
Regards,
Waqar.
Nov 15, 2009 | 1999 Chevrolet S-10 Pickup
Got a 3 prong stove but new pigtail has 4 is the green neurtal to
The following link explains how to convert from a 3-prong appliance cord to a 4-prong:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
The main difference is how the ground and neutral are terminated. In a 3-wire configuration, ground and neutral are connected together at the terminal block. In a 4-wire configuration these two wires are independent of each and are NOT to be connected together. The neutral wire will be terminated at the terminal block, while ground is connected to the ground lug on the appliance cabinet.
NOTE: New contruction homes after the year 2000 all have 4-wire configurations and you are required to have a 4-prong cord. However, if the home is older and still has a 3-prong oullet you can continue to use a 3-prong cord. You can still purchase them at any hardware store.
If you have any questions, please let me know. I hope this helps you.
Oct 12, 2009 | Stoves 1000DFDLm Gas Kitchen Range
I have a broadband DSL modem/router in my home office. I also have 2 CAT5e ports there. I want to feed the Internet signal from the router (one of the ports on the back) through a CAT5e point up to my...
Hi Joe,
How are you connecting to the port in the back of your router? if you have crimped a male plug on to some UTP cable then this may be the problem. UTP cable has a solid condutor and needs a different male crimp plug than UTP patch cable, which has stranded conductors.
I suggest you connect the UTP cable between the office and the loft to an RJ45 wall or surface socket in the office, use a terminating tool designed for the make and type of outlet you use, i.e. if using an ADC socket use the ADC termination tool. The sockets are designed for solid cable and have a colour code for you to follow. Then use a factory terminated patch cord between this socket and the router port.
I assume you have terminated the cable from the office onto one of the patch panel ports and want to use a patch cord to patch from this incoming socket to the sockets that are terminated onto the cables going to your other rooms. If you have access to a laptop connect this directly into the router port and ensure you have an internet connection, then plug the patch cord connecting the loft port into the router and take the laptop into the loft and ensure you have a connection at the incoming port on the patch panel. If you get the connnection there then use a factory patch cord to patch to a room you would like a connection in and then take the laptop to that outlet and ensure you have a connection.
If you want to run outlets in multiple rooms without re-patching every time then you will need to have an active switch in your loft and connect the port from the office to this and then patch out of the switch ports to the various room outlets.
Hope this helps.
Cheers, Jason
Apr 27, 2009 | 10 10 Computer Patch panel
Philips Home Theater Speaker Wire (can it be cut?)
Sure you can, Joel.
Put the speakers wherever they will go, and cut the wire from the speaker to whatever length you need to reach your wall terminals. Leave some slack so you can move the speakers if needed. Strip off whatever length of insulation you need to make the terminal connection. Note that the speaker wire will have some kind of polarity marking. There will be a colored stripe or other mark on the insulation, or the conductors themselves may be different colors (usually one wire is copper, and the other tinned so it's silver colored). It doesn't matter which you use for positive as long as you're consistent and use the same one for each speaker.
At the other end where the prewiring comes out for your home-theater system, splice the connector ends you cut off onto the installed wires, following the same polarity. I recommend using an appropriate size insulated **** splice to make the connection. The crimper and splices can be found at auto parts stores, Radio Shack or most hardware stores. It's quick, reliable and makes sure there are no bare wires to short out.
Plug the speakers into the system and you should be good to go. Whip up some popcorn and enjoy the show!
Jan 28, 2009 | Philips HTS-3565 Theater System
Replacing a Williamson (White Rogers) Termostat
rh is power for cooling terminal and rh is power for heating terminal connect red wire to rc or rh and there should be a jumper between rc and rh if not install one all other wires are color coded correctly. now the blue wire is not used.
Jan 05, 2009 | Honeywell Electronic Programmable...
Electrical Supplies Logo
71 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
