Question about ' II' DIY Car Alarm Vehicle Anti-theft Alarm
To reset an Abus 155/30 combination lock , how do you reset an Abus combination lock ,I have lost the destructions
How do I set an abus 1460 combination lock
Your lock is here Linda, but no instructions
https://www.abus.com/eng/Mobile-Security/Bike-Safety-and-Security/Locks/Steel-O-Flex/Steel-O-Flex-Raydo-Pro-1460
there are a number of videos showing how in the main link. This one is good;
https://youtu.be/ZyPmi1o_o1M
This one has the key built in
https://youtu.be/m32HP5E8Ak8
Go to Bing homepage
Jul 21, 2016 | Abus Raydo 1460 Lighted Combo
Have a abus comb lock its locked i put in the four numbers which are correct but it wont open only just bough it shop put in the combination
Take it back to the shop. They will provide the correct combination or reset the combination; or will owen you a new lock or refund (if you did not actually forget the combination). Abus makes good locks.
Mar 14, 2015 | Locks & Locksmithing
How to set combonation on Airbus Bordo Granite lock
Go on line to the manufactures web site and seek a new manual download from the support division.
May 10, 2014 | Abus Cycling
How to set lock combination
The device came with a manual to help you do the setup procedures. Review the pages and follow the instructions accordingly. If you do, the combination can be achieved.
May 10, 2014 | Abus Bordo Granit X Plus Foldable Lock:...
Reset combination abus 160/50
The answer can be found at http://www.lockwiki.com/index.php/ABUS_160: "The shackle can only be opened when the correct code is dialed and this is required in order to reset the code. With the correct code dialed in the user pulls out the shackle, turns the key on the right-hand side of the lock 90 degrees clockwise and sets the new code on the dials. The new code is in effect once the key is turned back to the vertical position."
Dec 09, 2012 | Locks & Locksmithing
Thought I knew the 4 number combination, now locked inside. I do have the key. However, safe not opening. What is the exact procudure for combo?
Without wishing to state the obvious, I feel that I must do so. A safe is called a safe for a very good reason. If it was easy to get inside without the correct key or combination then by definition it would be unsafe.
If you have lost the combination and the key doesn't work then you can either try every combination until you get lucky or you must consider calling out a locksmith who will usually open the safe destructively (often by drilling out the lock) or even by using an angle grinder on the hinges.
Sep 17, 2010 | Office Equipment & Supplies
' II' DIY Car Alarm Vehicle Anti-theft Alarm Logo
911 people viewed this question
Top Eagle Vehicle Parts & Accessories Experts
xxxxxx xxx
Rigger
richard foulk
Are you an Eagle Vehicle Part and Accessory Expert? Answer questions, earn points and help others
