Question about Hobart N50 Stand Mixer
Hi please advise how I can replace the broken agitator shaft of a N50 hobart mixer! I try to take out the planetary after removing the taper pin but it seems that's not the right way to reach the shaft gear! In any case I hope that to procede will not be necessary to dessamble the gear box starting from the motor side!!! Waiting your step by step advice. Thanks
  • c_domini Sep 25, 2009
    thanks alenort... your one was a great solution!
    the new trouble is that looking those pictures really made me scared!!
  • 615 Answers
This is a very difficult task to do as it may be addressing a legal issue especially that Hobart are very protective of their products and how the public get self-help…I can do better than step by step instructions and avoid Hobart chasers…I can give you a link to a photos of the unit taken apart and I am sure that may help you. Let me know and please do not forget to rate my service to be able to continue providing service and improve on it…God bless
The link: http://forum.kitchenaid.com/forums/topic.asp?TOPIC_ID=15979.
Posted on Sep 25, 2009
  • sunifar Oct 25, 2011
    Can you please activate the link "http://forum.kitchenaid.com/forums/topic.asp?TOPIC_ID=15979.".I also have the same issue to replace the shaft.Please help.
Hobart N50 noises
The frequency is the same in all gears.
disconnect the power and invert the mixer and remove the planetary after driving out the taper pin, then you can access the transmission. It may be a rotor shaft bearing in the motor or no grease on the worm gears.
Nice touch with the video.
If you need parts:
Jan 04, 2014 | Hobart N50 Stand Mixer
BBeater scraping back bottom of bowl
Is the planetary still off before the taper pin is in place?
It's a shot in the dark but if everything lines up, I can think of two possibilities:
1. The taper pin in backwards, and
2. The shaft hole in the planetary is out of round.
Mar 20, 2017 | Hobart N50 Stand Mixer
I've broken the agitator shaft pin on my Hobart A200T. I can find replacement pins online, but the local Hobart tech. is MIA. How do you remove the pin? How do you secure the replacement in the...
Drive it out with a punch and hammer. It's best to take the planetary off the machine so you can support the shaft. If not it puts a lot of unnecessary stress on the bearings and other parts.
Jul 08, 2011 | Hobart A200 Stand Mixer
Hi somenone may describe how I can procede step
after you removed the tapered pin on the plant. you should be able to get it off the mixer main shaft @this point, there is nothing else holding it to the main shaft
Sep 25, 2009 | Hobart N50 Stand Mixer
Hobart N-50 Mixer beater attachment spins but has no resistance
Sounds like the shear pin on the planetary shaft has sheared off. Has the mixer been subjected to a heavy load. Remove the planetary and see if the shear pin is intact otherwise you may have to open up the transmission.
Ron
Jun 04, 2009 | Hobart N50 Stand Mixer
Hobart A200T - agitator shaft replacement
Lefty, It's called a tapered pin. It can be removed by using a punch which is a bit smaller than the pin. This tapered pin can only be driven out from one side. Put a bit of WD-40 or some other penetrating oil in the pin area then figure out which end of the pin is smallest. Gently tap it out with the punch and a hammer, only use as much force as necessary. Only replace the shaft if it's badly damaged. You may be able to get at it by removing the four screws on the attachment hub. Remove the hub and see if you can get at it from there. If you can't, you should be able to get at it from the top. If you do replace it, you might consider replacing the shaft bearing and the bearing on the planetary shaft. If you find this solution helpfull, please rate it. Good luck. ricardok45
Nov 27, 2008 | Hobart A200 Stand Mixer
How to completely dismantle a Hobart N50 or KitchenAid Model G
If you only want to service the unit and not open the case, you can add grease through the gear shifter plate opening once you remove it. if you have a grease gun with a flex nozzle that's a bonus.
If not it is a messy job. Keep lots of paper towels at hand and use a narrow spatula to get the grease inside. Get as much in as you possibly can.
To remove planetary, with pin removed, spray a bit of wd-40 or other penetrating oil into where the pin came out of let it penetrate for a few minutes. Plan-A Take two screwdrivers and gently try to pry the planetary away from the body of the mixer. Plan-B Add a bit more lubricant to the shaft pin area and install a beater, then try prying with one screwdriver while putting downward pressure on the beater, alternate prying on both sides of planetary. Excessive force at the planetary top can/will crack it as it is a molded piece of metal. If you found this solution helpfull, please rate it. Good luck.
ricardok45
Nov 19, 2008 | Hobart N50 Stand Mixer
Hobart N50 / KitchenAid Model G: how do i remove planetary?
you need to remove all the back screws then if it doesnt come tap it with arubber mallet it may be seized on
N-50 rebuild help
Remove the shiny drip ring on the planetary, use a small screwdriver and gently pry it off. Remove the "Tapered pin" that holds the planetary on the shaft, gently use a punch and a hammer to do this. This pin can only be tapped out in one direction. Pull downward on the planetary assembly until it comes free. Examine the small gear and bearing for excessive wear, examine the ring gear that remains in the mixer body for wear. Clean and re-grease these gears if they look OK. These gears are in operation in any gear and as such, receive the most wear. When re-assembling the planetary re-install the tapered pin the way it came out. The previous solution will address the transmission gearing. Replace parts as necessary. Good luck. Please rate this solution if it helps you. ricardok45
Oct 10, 2008 | Hobart N50 Stand Mixer
Hobart N50 Tripped
The reset button is to protect over amping the motor. The N-50 is not a very strong unit, (commercially), but you won't break a gear. If you overload the unit, you'll either trip the overload (reset button), or you will break the taper pin that attaches the planetary to the center shaft.
If you're looking for a small commercial unit, and you're in the US, look into the 10 qt Precision Mixer.
Apr 04, 2008 | Hobart N50 Stand Mixer
Hobart N50 Stand Mixer Logo
79 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
