Question about Amana Dryers
Our amana gas dryer. runs for about 20 mins and shuts off. try to resart and there is busing noisefrom the controls on top. if sets for 45mins. it will start again. until it gets hot. and then wont work.
    President:
  • 632 Answers
The problem is in the gas valve coils. They sit on the top of the gas valves. When these coils are energized open the gas valves and allowing the gas to burn. If one or more coil malfunctions, the dryer shuts off. It is usually difficult to properly test the coils and replacement is the best solution.
Posted on Sep 25, 2009
I have dryer lgr3624eq1 when you push the start button it makes aloud humming sound and wont start but if you wait 2 hour it will start but it will shut off before the full time
We're sorry to learn of your experience. We recommend service for a proper diagnosis. If further assistance is needed, please email us at Whirlpool_Reviews@Whirlpool.com at your earliest convenience with the website you reached out to us on (fixya), brief description of your concern, your name, address, a phone number and best time to reach you along with your model and serial number.
Jan 17, 2018 | Whirlpool LGR3624JQ Gas Dryer
Dryer flame keeps going out
replace the gas valve coils on the top of the gas valve,they get weak and can no longer hold the valve open,then they cool and repeat the same condition,they may appear warm after shutting off,remove 2 screws off bracket holding them on and unplug each coils harness and replace coils,there are plastic pins for getting them in the right position,so its hard to reverse them
Jul 23, 2012 | Amana NGD7200TW Gas Dryer
Dryer starts, runs 10 min. flame shuts off, ignitor comes on again, but gas value does not open. i have replaced the flame sensor, but still will not open gas value.
What's happening is them solenoids are getting hot and when they get hot they fail if they are a bit aged. Replace em and party on.
May 13, 2011 | Amana ALG866SB Gas Dryer
Amana NDG2335AW Gas Dryer runs but doesn't heat
Check the spark ignitor when firtst starting the dryer up. It should click within the first 15 seconds to light the pilot up
May 31, 2010 | Amana NDG2335AW Gas Dryer
My Frigidaire electric dryer GLER341AS2. The
Does it shut down completely? If it does, and the timer ceases turning, your problem may be a blocked vent pipe or Lint buildup.Your high limit switch is designed to kill power to your heater coils and sometimes the motor in case of overheat.
Mar 09, 2010 | Frigidaire GLER341A Electric Dryer
Dryer heat turns off after about 5 min- dyer will remain running but no heat
HI, After the heat shuts down, do you hear a click like it is trying to heat again but then get no flame. The most some problem is the coils on the gas valve go bad and will not reopen after they have heated up.
Remove the cap on the front lower left panel. After dryer has ran and heat shuts down, watch and se if the ignitor glows again (you will hear a click) and the ignitor shuts off before a flame. If this happens, change the coils on th gas valve.
Here is instruction: Normal 0 UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the two black coils on the gas valve. When you remove the three wire coil, make sure the sleeve inside it gets put back on the post the coils slides onto.
If I can assist you further, please let me know.
Thanks
Vic
Jun 01, 2009 | Dryers
I HAVE A AMANA DRYER MODEL # LE8217W2 THEY DRYER WILL TRY TO START AND TURN OVER LIKE A COUPLE OF TIMES AND WILL HEAT BUT SHUTS RIGHT BACK OFF--BELT IS FINE ELEMENTS HEATS? WHAT WOULD BE NEXT TO CHECK?
sounds as if the motor is overheating, shutting off and not restarting for 10-20 min??? if thats the casse sounds as if yooull need a new motor assemly
Dec 03, 2008 | Amana NDE2330AY Electric Dryer
Kenmore 110 gas clothes dryer heats for 20 min then needs to rest for 20 mins before heating again
Cause 1Thermal Fuse
The thermal fuse is a safety device designed to protect the dryer from overheating. The fuse is located on the blower housing or at the dryer's heat source such as the heating element on electric dryers or at the burner on gas models. The fuse should be closed for continuity meaning it has a continuous electrical path through it when good. If overheated the fuse will have no continuity meaning the electrical path is broken and the fuse has blown. A multimeter can be used to test it for continuity. Be aware that a blown thermal fuse is an indication of a restricted exhaust vent from the dryer to the outside. Always check the dryer venting when replacing a blown thermal fuse.
Parts Cause 2Gas Valve Solenoid
Gas dryers have two or more gas valve solenoid coils. The gas valve solenoids open the gas valve ports to allow gas to flow into the burner assembly. If a gas valve solenoid fails, the dryer won't heat. To determine if one or more of the gas valve solenoids has failed, check the igniter. If the igniter glows and goes out but does not ignite the gas, the gas valve solenoid is defective. If one or more of the gas valve coils are defective, we recommend that you replace them as a set.
Parts Cause 3Igniter
The igniter uses heat to ignite the gas in the burner assembly. If the igniter is not working, the gas will not ignite, preventing the dryer from heating. To determine if the igniter has burned out, use a multimeter to test the igniter for continuity. If the igniter does not have continuity, replace it.
Feb 16, 2018 | Dryers
3 yr old amana gas dryer not working
i would replace the coils mounted ontop of the burner valve. they're overheaating nad not opening the valve after heated.
279834 twenty bucks. comes as a set replace both coils!!
Mar 10, 2008 | Dryers
Kitchenaid prestige dryer model keys677EQ1
I have a KItchenAid Presitge Electric Dryer; Model #YKEYS677EQO. It just shut off. I tried resarting it but all I get is a humming noise. This humming noise only lasts for about a couple of seconds then I get nothing. The barrel can be turned manually.
Dec 15, 2007 | Dryers
Dryers Logo
71 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
