Question about Philips PM3S Remote Control
Remote grey
    President:
  • 2,712 Answers
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. -You can rate this solution with one of four votes, if you feel your issue is resolved (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 19, 2008
  • Swilin Sampson
    Swilin Sampson Jun 01, 2008
    This thread has gone 7 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
    IrishDruid
Screen keeps going black then grey and white lines start to come across the screen.
This is not the fault with remote control. It is with your TV itself. Contact any service technician.
Gopakumar Gopalan Google
Mar 24, 2014 | Televison & Video
I dont know what each colour means to conect to my new cd player
yellow is 12v power
red is accessory
black is ground
blue/white amp remote
blue antenna remote
white fr left+
white/black fr left -
grey fr right +
grey/black fr right -
green rear left +
green/black rear left -
purple rear right +
purple/black rear right -
hope this has helped thumbs up pls
Aug 11, 2010 | Car Audio & Video
I need to replace the battery on a Genie GICT-390 garage door opener. How do I open the case?
If its a lighter grey colored intellicode remote: There should be a small slot on the side of the remote. Use a coin such as a dime or a penny, stick it in the slot and twist. The remote should split in half and you'll see the coin-shaped battery. After you replace the battery, you can snap the 2 pieces of the remote back together.
If its a dark grey/black intellicode remote: The back cover should partially flip open to reveal the battery. This remote takes a 12volt N-size battery.
If its a keypad remote you are referring to: The bottom half of the keypad's face should slide straight down to reveal the battery (you should see and arrow and some thumb grips). All Genie keypads take 9volt batteries. Source(s): I am a genie technician
Oct 24, 2009 | Genie Company IntelliCode GICT390-1BL...
Change battery in GICT390 3 button remote
Oct 10, 2009 | Genie Company IntelliCode GICT390-1BL...
Sylvania LC320SLX - No Comcast Code
IF YOU HAVE THE DARK GREY REMOTE FROM COMCAST, IT WILL NOT WORK. SWITCH YOUR DARK GREY REMOTE FOR A LIGHT GREY REMOTE AT COMCAST OFFICE.
Jul 28, 2009 | Sylvania LC320SS8 32 in. LCD Television
I need a wiring diagram for this stereo
FOR 16-PIN HARNESS
Pin Number Wire Color Function 1 White Left Front (+) 2 Green Left Rear (+) 3 Violet Right Rear (+) 4 Grey Right Front (+) 5 Blue/White Amplifier Remote 6 Blue Antenna Remote 7 Red Accessory 12 Volts 8 Black Ground 9 White/Black Left Front (-) 10 Green/Black Left Rear (-) 11 Violet/Black Right Rear (-) 12 Grey/Black Right Front (-) 13 Sky Blue Telephone Mute 14 Orange/White Illumination 15 Not Used Not Used 16 Yellow Constant 12 Volts
FOR 9-PIN HARNESS
Pin Number Wire Color Function 1 Not Used Not Used 2 Black Ground 3 Grey Right Positive 4 Grey/Black Right Negative 5 Blue/White Amplifier Remote 6 Red 12 Volt Switched 7 Yellow 12 Volt Constant 8 White Left Positive 9 White/Black Left Negative
MAY THIS HELP YOU
Jul 04, 2009 | Sony CDX-GT210 CD Player
Haier HL26R COMCAST REMOTE CODE
what kind of comcast remote do you have please describe, black and silver, dta, and especially important what color is the OK/select button grey or red. If the Ok/select button is red the codes are 11034, 10768, if the ok select button is grey there are no codes, however you can use the search option listed below
step 1 press the tv button located at the top of the remote
step 2 press and hold the setup button located on the upper right of the remote until the tv button blinks red 2 times.
step 3 enter code 991 the tv button will blink 2 times again
step 4 alternate pressing the grey Power button then the tv button located at the top of the remote ( the tv will turn off when it finds the correct code)
step 5 press the Setup button when the tv turns off and the tv button will blink 2 times confirming the code is locked in
FYI this process can take quite some time but there is no direct code listing for the non dvr remotes.
Good Luck
Jun 20, 2009 | Haier HTF20R21 20" TV
Mitsubishi 1080 series// grey box appears when playing dvds
first you may need to get the original remote control (290P123010)
also I think the problem can be with the closed caption too
Apr 04, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Disassemble DirecTV remote?
There are a total of SIX screws. You have already found two in the battery compartment. There are four more under the GREY panel on the front of the remote. That grey panel pries out; there are two tabs on the lower sides and one on the top, above the > button, that hold it in. Should not be hard to get it out to reveal the four screws. Take them all out, and the remove easily pries apart for service access.
Feb 05, 2009 | Directv RC23 Remote Control
I cant figure out the rear speaker color codes on my 1996 pioneer deh-p725 car cd player, could someone help me?
red---------ignition
orange----constant
black------ground
blue--------remote
green------drvrs front
grn/black--drivrs front neg
grn/red------drivers rear pos
blk/grn-------drivers rear neg
grey pass front pos
grey/blk---pass front neg
grey/red---pass rear pos
blk/grey---pass rear neg
Gary
Jan 25, 2009 | Car Audio & Video
Philips PM3S Remote Control Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
