Question about Electronics - Others
My mini sd card is in raw format and my computer can't read it - how do i change it back to fat file system ?
    President:
  • 803 Answers
  1. Place the mini-SD card within the mini-to-SD card adapter. Make sure the tab on the mini-SD is facing the upper side of the adapter. Slide it in slowly, being careful not to damage the pins.
  2. Slide the adapter in an SD slot on your computer. If you do not have an SD slot, place the adapter in a USB card reader, and plug that into a USB slot on your computer. Give the computer time to read the card.
  3. Open "My Computer" (usually located in your start menu) and navigate to your mini-SD card. It will usually be recognized as a drive such as "E:" or "H:."
  4. Right-click on the drive and select the "Format" option. A menu window will open.
  5. Make sure that the drive size is set correctly, and that it is set to the file system you wish to use (usually FAT32 on an SD card). If you don't know what file system you should use, just leave it at the default setting.
  6. Enter a volume label, which is the name for the drive, then press start. This process should only take a few minutes.
WARNING
  • Do not use the "Quick Format" option unless you have just recently formatted the mini-SD card. "Quick Format" doesn't completely erase all data and is not effective unless used after a full format.
  • When you format your mini-SD card, all of the data on it will be erased. Make sure to back up your files on the card before formatting
Posted on Sep 25, 2009
  • Kasey Fleming
    Kasey Fleming Sep 25, 2009
    1) Put the mini SD card into a USB card reader and plug it into your computer.
    It will show up as an external hard disk.
    Right click on the icon. Then select format. or select properties then format.
    2) Put SD card into your phone. Go and find the external memory function. Choose options and select format.
    Here is another solution
Cange file system RAW in FAT
SD cards take on a multitude of formats.
For a card that needs to work on operating systems such as Windows 98, ME or XP Home Edition, it must be converted to a File Allocation Table (FAT) format.
Also, some devices, such as a GPS unit or MP3 player, may require a FAT-formatted card.
Insert the SD card into your computer's card reader.
Click Start, then "My Computer."
Right click on the drive representing your SD card and click "Format."
Choose the memory capacity that fits what the SD card's capacity is.
If the exact option isn't available, get as close as possible.
Choose "exFAT" from the "File system" option.
Click "OK" and confirm you want to format the drive.
Hope this helps.
Nov 20, 2012 | Computers & Internet
My memory card is not opening
Your card may not be formatted -or- it is and it;s a proprietary format. If you want to format it, here is the instructions (for Windows):
Put your card into your computer (some have a slot or else use a card reader). Right click on that drive after it appears in My Computer and select Format; set the File System drop-down to NTFS (better file storage space) or FAT32 (more compatibility in older operating systems) and click Start.
Dec 21, 2011 | Kingston 2GB Secure Digital Memory Card
32gb SD card is showing 0 bytes used space and 0 bytes free space
Try formatting the card and be sure the locking switch is in the off position.
Sep 14, 2011 | Transcend (589307) Media
The sd card is not working and saying card error
Go in the camera options and format the card. If your camera does not have this option or it can't complete the format it means that :
Your card might not be formatted with the correct File System. Move your SD Card to a computer with card reader and Format with FAT32 File System the move it to camera. If the camera gives the same error, format the SD card with the NTFS file system the try again in your camera. If the SD card still don't work try FAT Fyle System.
Nov 10, 2010 | Canon Elura 90 Mini DV Digital Camcorder
Pen drive is not openning asking formatt & not
Try to format it using the method describe below:
May be it will help
Go Start>Setting>Control Panel>
Or Start>Control Panel>
Then open> Administrative Tools>Computer Management>
Then select In the left Column Click disk management
Then locate your pen drive and try to format with fat file system
Also you can try to remove the partition and create new one
ok...
Regards
Uttam
Jan 16, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My mini sd card is in raw format - how do i change it back to fat
Below is a link to an SD Formatter provided by sdcard.org. I have used it in the past and it has worked well.
http://www.sdcard.org/consumers/formatter/
Sep 21, 2009 | Electronics - Others
How to convert RAW to FAT, FAT32
I'm facing big problem. Hdd was in RAW format and I want to convert in fat32.
Apr 12, 2009 | Computers & Internet
Using wmp to sync to mini sd card for a moto ve240 mp3 player
the device has to format the card. at this time the phone will create folders for music, videos, images, and what not. now when you insert the card into your computer you will open the card and copy the files to the music folder. this will allow access to the files from the handset visual platform.
Good Luck and please rate this solution!! :D
Mar 19, 2009 | Motorola Cell Phones
Micro sd card not reading songs
Yes, Brother there is one probability that your sd is formatted in fat-32 file system. For that i would like to say phone can only read FAT not FAT-32. Go to my computer, select sd drive properties and format it with FAT file system. Then load the files and you will be able to see it in your phone. If it works don't forget to vote here. For any proble contact me patel352003@gmail.com or patel352003@yahoo.co.in
Jan 07, 2008 | Samsung UpStage SPH-m620 Cellular Phone
Sd card formatting
Does SD card work in PC? HP R707 will not work with SD card larger than 2GB.
Oct 22, 2007 | HP Photosmart R707 Digital Camera
Electronics - Others Logo
1,253 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
