Question about HP Photosmart M425 Digital Camera
Batteries were flat and then the camera did not shut down. On replaing the Batteries the camera does not work, no function is working. The power on light flashes then the camera eiter shuts down or simply does not do anyting. Thanks for your help. Josef
SOURCE: my camera won't work at all it just says batteries depleted even with new batteries
well wat u need to do is take the memery card out and take the batteries out 4 a little bit
Posted on Jul 09, 2007
  • 121 Answers
SOURCE: Battery depleted
Sounds like the battery might be defective/worn out. If it's AA batteries (a.k.a. R6) try with a pair of good-quality alkaline batteries to see if it works then. Cheap batteries often doesn't have enogh "umph" to power cameras.
Posted on Dec 20, 2007
  • 5 Answers
SOURCE: Lens error M425-12 (7f80) appears/ camera shuts down
if the blue light flashes 4 times Main power led to on/off switch is crushed and not enough power gets through.
you have disassemble the camera.
I would think first before tring this.
Remove 3 screws on bottom, 1 in battery compartment, and 1 at very top of usb flap (look good).
Now slide the side piece starting at the usb flap then apply pressure to top and away from unit.
now look for 1 silver and three black screws (facing back and front, look good).
See the big red wire leading to main on off switch if it crushed thats the problem.
I replaced it with a longer piece of wire.
Remember to replace battery door first if it fell off during process.
*TEST NOTE: You can place batteries in and place a penny across the bottom to test before you put it back together.
Posted on Jan 19, 2008
pontelemon
  • 538 Answers
SOURCE: camera keeps shutting down
Yes, that's sounds like a main board.
Posted on Mar 18, 2009
fotomohamed
  • 321 Answers
SOURCE: HP Photosmart 735 Camera lasts 2 minutes with fresh batteries
use NiMH batt.
Posted on Jun 18, 2009
Weird clicking, camera won't function.
How old are the batteries?
Try running them on the mains adaptor, if they work okay then it's possible the batteries are on their last legs.
Good luck.
May 31, 2012 | Canon VIXIA HV30 DV Camcorder
Camera shuts down when try to take picture
You can try using NIMh batteries instead of using of using the conventional. Most other cameras with similar problems have turned to function normally by using the above mentioned cameras.
Dec 15, 2011 | Sony Cyber-Shot DSC-F707 Digital Camera
My camedia Olympus c3000 won't turn on with brand new charged batteries.
TROUBLESHOOTING
OPERATING PROBLEMS
The camera does not work.
1 The power is OFF.
[ Set the Mode dial to turn on the power. (P. 36)
2 The batteries are loaded incorrectly.
[ Reload the batteries correctly. (P. 28)
3 The batteries are exhausted.
[Replace the batteries with new ones. (P. 28)
4 The batteries are temporarily unable to function.
[Keep the batteries warm while using the camera.
5 Power has shut off to conserve battery consumption.
[Operate the shutter button or the zoom lever.
6 It is connected to a personal computer.
[The camera will not operate while it is connected to a personal
computer.
Jul 14, 2010 | Cameras
I pulled the batteries out of the camera before it had completely shut down. now it doesn't work at all. What do I do
If you waited for a long time after removing the batteries then batteries may be complitely shut down. Waited batteries always do that. Use new ones. If the old batteries rechargable then you should charge them again.
Feb 24, 2010 | Kodak EasyShare Z740 Digital Camera
Last year I bought my mom a digital camera for christmas. It worked great for about 2-3 months. Since then it is speratic, it will turn on let you take a couple of pictures then shuts down all by itsels....
Hi! Most digital cameras require outrageous amounts of power to work properly. Be sure to use only high quality, hi power ni-mh rechargeable batteries. Check for Sanyo Eneloop or Duracell. Sometimes we think the camera is broken, but in most cases is only insufficient amout of power. If you can't find the before mentioned batteries, look for 2500mA NI-MH type rechargeable batteries and a proper charger. Good luck!
Nov 22, 2008 | HP Cameras
Flat batteries
a well known problem , this camera eats batteries there are high power (2950MaH) accus , those should be used with this camera even with 2700 MaH it is empty real quick
Mar 04, 2008 | Fuji FinePix S7000 Digital Camera
Sony DSC-S650 ( 7.2 MP and 3x zoom) - Not working
I have the same camera and have had the same problem. The first time I had to change batteries I could not find lithium batteries and ended up trying alkaline batteries. I was only able to take 1 or 2 pictures before they would die and the camera would shut down. When I switched back to lithium batteries, everything worked fine. I hope this helps.
Dec 30, 2007 | Sony Cyber-shot DSC-S600 Digital Camera
Brand new batteries and its tellin me to change them!
please check if the batteries u used before have leaked any oil inside the camera. this damages the metal strip that shorts and two batteries. if there is no damage then tat portion s safe.
the small battery inside battery compartment is for camera date. dont disturb it.
after changing new batteries tha camera works for few time and then shuts down means your camera CCD s consuming lot of power. use a camera adapter to confirm that the camera works in normal power atleast.
even after this. camera shuts off itself. take it to service centre soon.
Nov 25, 2007 | Canon PowerShot A520 Digital Camera
Mustek DV-3500 DV Digital Camcorder /keeps turning off
Be sure the batteries are not the rechargeable types.  I had this problem when I first got my camera about 4 years ago.  Also, try adjusting the quality settings for the functions.  For example, set the photo function at normal rather than fine.
Dec 14, 2006 | Mustek DV-3500 DV Digital Camcorder
HP Photosmart M425 Digital Camera Logo
Top HP Cameras Experts
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
