Question about Intermatic T104M 208-277Volt 40-amp Timer Switch-Double Pole / Single Throw
Lost instructions book B&Q TE106 timer
Cannot work out how to set the current time.
SOURCE: i have a programmable timer
If its an intermatic timer then this link should take you right to your instructions http://www.intermatic.com/products/timers/mechanical%20time%20switches/24%20hour%20dial.aspx
Posted on Nov 12, 2010
SOURCE: i JUST NEED THE INSTRUCTIONS ON HOW TO PROGRAMME A B&Q TE106 TIME
I solved this problem myself by Googling B&Q TE103 timer and downloading the B&Q instruction manual for the TE103 which I have printed and also saved to my computer so this does not happen again.
Posted on Oct 09, 2009
Testimonial: "I am just the greatest as I managed to solve my problem myself without the help from anyone else"
SOURCE: Need to re-set time on Salter digital timer
If it's the same as ours (clock button top left, clear bottom left):
  1. press and hold clock until the clock starts to flash
  2. set time using h/m/s keys
  3. press clock again
Hope it works
Posted on Nov 01, 2009
  • 17 Answers
SOURCE: raindrip automatic water timer.
Instructions are on the website at http://www.raindrip.com/images/stories/pdfs/R673-digital-timer.pdf
Posted on Oct 08, 2010
SOURCE: Instructions to set Woods indoor timer 59377
Open following link to identify timer and download manual
http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
To set current time, press and hold clock button while pushing hour and minute buttons.
Then release clock button
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Feb 12, 2011
How do I set the clock? The included instructions for setting the clock do not work. I can set all the programmed on & off times, days of week, etc., everything except the friggin' clock. The cl
Give us the model number so we can see what you're talking about. Tell us what link you have tried, and how the instructions seem to be different.
Display showing no-op is sometimes associated with defective timer, bad battery. Resetting timer will clear memories and restore functionality in some cases.
http://waterheatertimer.org/How-to-troubleshoot-timers.html#digital
Attach photo of timer, or description of timer.
Add if this is new timer or if timer worked before, and what load the timer controls
Do you have correct instructions for timer ?... scan the manual into .pdf format. and then post the .pdf manual on your website .... then post link here to assist other folks with same problem.
Gene
Water Heater Timers Save Money
Dec 11, 2014 | Hardware & Accessories
Programmable Digital Timer Model TE106
Copy following link for possible TE106 timer manual:
http://waterheatertimer.org/pdf/Possible-manual-for-TE-106-timer.pdf
Add comment after trying instructions so we can get exact steps correct if necessary
Gene
Aug 11, 2013 | Hardware & Accessories
I have a Noam Indoor Mechanical HEAVY DUTY Timer that I lost manual for and can't figure out how to set the time On the back it shows 052-8823-0 Type: 16ULD/3A-1HR 15A, 125V-.60Hz It has a 3...
Timer plugs into outlet, and the clock dial spins around and words 'time-now' appear on dial.
Sounds like 24-Hour analog timer:
Time-now means 'the current time right now" for example 12:45
The dial can be manually rotated, and you set current time by rotating dial and lining up 12:45 with time-now triangle.
Open following link for instructions that illustrate how to set on-off segments, and get the timer to work.
http://waterheatertimer.org/How-to-set-timers.html
Open following link to see several similar timers, and each operates same way:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59419
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Sep 07, 2011 | Hardware & Accessories
Lost the guide book for setting the timer. please help me with directions to program time for lamp to come on and go off daily. Thanks My email address is ilewis@h2l.com (H2L.com....all lower case)
Check following link to make sure this is your timer:
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/digital%20timers/dt620cl.aspx
Manual for DT620
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/dt620cl.ashx
This is a plug-in timer with internal rechargeable battery.
If battery will not charge, then display doesn't show, and timer is no good.
If this is not your timer, then add a comment with detailed description of timer for more free help.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 04, 2011 | RTO Intermatic DT620CL 15 Amp Indoor...
I need to find instructions on how to reprogram an Intermatic indoor wall timer.
You posted under ST01C Intermatic battery operated timer.
If you have different timer, then add a comment.
Let's review ST01C timer for a moment.
Programming will stay inside timer memory indefinitely until timer no longer works.
Even if battery is removed, programs remain. Current time setting does not remain in memory.
If battery goes dead, then current time will disappear, but programs remain forever.
If previous programming was correct, you might only need to set current time,.
In that case, you do not want to 'reset' timer and clear memory.
If you want to clear old programming entirely, then you can 'reset' timer using following instructions.
Press and hold on-off button, and then use paper clip to push in reset button for 3 seconds.
Release reset button but keep holding on-off button until INIT displays momentarily.
Release on-off button.
If display does not show, then timer battery is bad, or timer is bad.
For instructions how to set current time, click link below.
In addition to current time, the link has ST01C manual and also has EZ to follow instructions and photos for setting on-off times (but not astro times)
http://waterheatertimer.org/ST01C-program.html
Instructions are different for astro dawn to dusk.
Add a comment at any time if you need free help with specific steps in the manual.
If you do not want to read the manual or open a link and read the steps or add a comment for further free help, then you can pay a fixya expert for phone support and that person will walk you through the steps while on the phone.
Keep in mind that ST01C timer has 1 year limited warranty, and your timer might be broken.
In that case you should try the free steps first.
Dec 16, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Set timer for the 7-day outdoor timer i.e. 5:00 pm on and 9:00 p.m. off Also set the clock ~ should it be left 'on' for the timer to work? Have lost the manual our programmer
Outdoor timers
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/digital%20timers.aspx
HB88RC timer
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/digital%20timers/hb88rc.aspx
HB88RC Manual:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/hb88rc%20-%20english.ashx
Timer takes AA battery installed from back
Instructions say: Set timer to AUTO using MODE button. This will let programs run.
To override current program, press MODE once for ON-or-OFF override.
Press MODE again to enter RDM or random mode. RDM shows on display.
Press MODE third time for AUTO. Usually, AUTO will show on display.
Dec 05, 2010 | Intermatic HB88RC - 7-Day Programmable...
I have a programmable timer model te106 (make unknown) with no instructions. any ideas how to get instuctions?
Nov 12, 2010 | Hardware & Accessories
I JUST NEED THE INSTRUCTIONS ON HOW TO PROGRAMME A B&Q TE106 TIME
Oct 08, 2009 | Intermatic T104M 208-277Volt 40-amp Timer...
Intermatic T104M 208-277Volt 40-amp Timer Switch-Double Pole / Single Throw Logo
1,991 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
