LG GSA 4163B DVD±RW Dual Layer Burner
Problem for LG GSA 4163B DVD±RW Dual Layer Burner
Recently purchased a dell laptop,it will not let
By sharon_belle on Sep 25, 2009
recently purchased a dell laptop,it will not let me burn a dvd,i have reinstalled the disk, still nothing, burning software is roxio creator DE 10.2
Cheers, shabell9
sharon_belleville@yahoo.com.au
Solution #1
posted on Sep 25, 2009
Not Rated)
57 varieties
Rank: Guru
Rating: 88%, 538 votes
I had the same problem with a new DELL and an old DELL. As I presume that you are running Vista you will need to check to see if you have the following update installed on your system
KB972036
If so this will be the cause of the probelm as it changes the way that the system accepts devices ( a so called Microsoft feature) and will effectively not see many DVD burners, etc. You will ned to uninstall this update and reboot your system. If you still can't see the burner then you will need to reinstall the driverr for your particular DVD burner which should be on the CD /DVD that DELL supplied with your system. If not then you should be able to find a download from LG or DELL in your region.
Was this helpful?
Yes
No
Solution #2
Not Rated)
alenorm
Rank: Wiz
Rating: 85%, 171 votes
Are you using the correct CD? and the setting correct?if the laptop new it may be the driver conflicting...go to device manager and go and delete all the drivers that you do not know and reboot the computer after shutting it down and when starting the computer will scan for all installed drivers and reassin them again...let me know if that help and please do not forget to rate this service to be able to improve on it
Was this helpful?
Yes
No
Popular Solutions for LG GSA 4163B DVD±RW Dual
Questions and Unsolved Problems for LG GSA 4163B DVD±RW Dual
Do you recommend LG GSA 4163B DVD±RW Dual Layer Burner?
Answer
Answer
Is the eMachines LG GSA-4163B DVD±RW DL Burner compatible with the model T6212 desktop pc?... (More)
Answer
mY hl-dt-stdvdram gsa-t40ata when I go to panel control have a exclamation simbol an then said thata... (More)
Answer
unable to burn dvd9 with a duel layer disc in this drive
Answer
Windows cannot start this hardware device because its configuration information (in the registry) is... (More)
Answer
hl-dt-st dvdram gsa-t40n ata device for medion (my driver of dvd station is gone) this is the driver... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For LG GSA 4163B DVD±RW Dual...:
Top CD and DVD Burner Experts
Rank: Guru Guru
Solutions: 14911
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more CD and DVD Burner Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
