Question about Kodak EASYSHARE M1063 Digital Camera
Kodak 10.3 camera lance wont fully extend when
Kodak 10.3 camera lence wont fully extend when switching it on thus camera wont activate immediately switches off
  • 101 Answers
Here are the steps:
1. Make sure you will install a new or fully charged
battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from
your camera, then wipe the battery contacts with a soft,
clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
If issue persists, call 1.800.235.6325 for repair.
Thanks.
Neerak21
Posted on Sep 25, 2009
M863 lens extends and then immediately retracts
Kodak Easyshare cameras use Li ion batteries, as recommended by the manufacturer, which have higher voltages but not necessarily higher amp hours per battery pack.
When I first bought my 14.1 megapixel camera from Kodak, I tried various batteries, including Alkaline, Ni MH, and they didn't work very long before needing replacement or recharging.
This is because the voltage isn't enough on other batteries.
I do not understand why they make it this way, because it fooled me a lot. I thought that since it had a AA format that it would be alright to use AA batteries of any type in the camera. But, this is not so, in my experience.
Good luck getting your camera to work with new Li Ion Batteries.
Note: if the Li Ion batteries do not work, then there is something wrong internally with your camera.
Contact kodak.com to see if it is economically repairable.
Thanks for asking a question on Fixya.com.
Jul 24, 2010 | Kodak EasyShare M863 Digital Camera
Kodak M320 switches on the immediately off. The lens extends and then retracts immediately. It is fully charged.
the capacitor in this is failing it looks like this :
This is what ontrols the flash and the rest of the camera, when these die so does the camera but these can be taken out and a new one put in, i would take it to a camera shop and have them do it for you. otherwise you just going to need to chalk it up for a new camera.
Thanks and please rate my honest answer.
Jun 15, 2010 | Kodak EasyShare M320 Digital Camera
EasyShare Z885 Digital Camera: unable to power up camera. lens remains fully exte...
If the lens makes a partial movement when you attempt to power up, it is probably dirt/sand that has jammed up your lens in the extended position. First use a vacuum to remove dirt between the lens gap. Next, be very careful, but when you power up, as the lens tries to retract apply a little force to help the lens, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera
May 17, 2010 | Kodak EasyShare Z885 Digital Camera
Hello all, i have the kodak v1233 and it turns on but immediatley off and the lens will not pop out. i guess dur to the immediate turn off. can anyone help ? thanks :)
hi,
its a lance eror so keep servise well your lance , if you are a technition then try at home otherewise please contact authorised person , if you want to know more
don't wory its a lance problem, its beeing most probably so keep it up
Aug 31, 2009 | Kodak Easyshare V1233 12.1MP Digital...
Lance alignment is disturbed
hi,if you are a tecnition then open yor camera and remove the lence assembly,then remove the motor and clean the lence unit properly ,and check that smothness between lence beralls, it must be rolling smothly ,and roll the moter by using adapter of 5 volts ,roll motor both side ,after that fix it properly ,now you can check it by put suply on motor and see what has be done,if lence responce smothly in and out then fix it with camera,and see the magic
Aug 25, 2009 | Nikon COOLPIX L10 Digital Camera
Camera will not stay on
I have basically the same problem. I sent it in for repairs. It came back and I followed the instructions they came be. BUT IT STILL WONT WORK. it's worse then before, the logo wont even come anymore ! :(
Jul 18, 2009 | Kodak EASYSHARE M1063 Digital Camera
Camera won't stay on
I may be able to help with your Kodak EasyShare Z740 that turns itself off.
It may be a 'lens extending' problem, or it might be fixed with a combination of button presses to reset it while turning it on.
Try these steps to fix your camera.
I hope that helps.
_____________________________________________
Kodak EasyShare Z740 Turns Off Fix
Kodak EasyShare Z740 Manual Download
May 11, 2009 | Kodak EasyShare Z740 Digital Camera
Camera lense wont close
I had a problem this week when i tried to close my camera and the lence would not close but the camers would
I took the batterys out, then a couple of days later when i replaced the batteries and switched the camera on the lence closed properly, so i guess my solution was to remove the batteries and see what happens it did the trick.
Maria
Jun 22, 2008 | Kodak Cameras
Kodak EasyShare V1003 Digital-Turns off and Lence projected
its the hanging of ur cam's software..it can b solved by the technicians itself..so don dave ur hand in solving it..it may b due virus from ur memeory card..so rush to the service center..don get the product spoiled more..it wont cost u much for repiaring also..
ne thing els do tell me..n plz plz do rate me..
cya
Apr 24, 2008 | Kodak EasyShare V1003 Digital Camera
Kodak EASYSHARE M1063 Digital Camera Logo
199 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
