Question about Jenn-Air JCD2290HES Side by Side Refrigerator
Freezer not freezing, everything is thawing.. only 3 yrs old, refrig part only 47 degrees
Freezer not working and now refrig part not very cold. sounds like water valve kicking on and off.. could be compressor sound.. sould runs a minute then stops..
  • 410 Answers
Sounds like your compressor is not starting up. unplug your refrig then remove the start relay from the side of the compressor. shake the relay if you hear alot of rattling around in the relay then most likely that is all thats wrong. if it doesnt rattle alot then possibly the compressor is locked up and is bad.
when you shake the relay if its broken internally usually little peices of ceramic will fall out of it. so shake it over a peice of paper to see if that happens/..
Posted on Dec 16, 2007
Items in refrig are freezing when they're not supposed to.
thermostat has failed i'd say..its not turning off at the requested temp.
Jul 24, 2010 | GE Profile PGSS5PJXSS Stainless Steel...
10 yr old, sits in a garage. Worked fine until a
is the fan operating,if so then check your damper vent door that throttles cold air from freezer to refrige compartment they can freeze shut and a hand held hair dryer will thaw them out,then adjust its control to make sure the door moves when control is adjusted
May 08, 2010 | Kenmore 72102 / 72104
I have a Hotpoint, model # Hsm25gfre sa, that is cooling and freezing unevenly. Everything onthe bottom half of the freezer is frozen and the top half is thawing. Also, the water in the ice maker is not...
Make sure that the freezer fan is working and circulating the cold air. Then check the damper assembly to make sure that cold air is being circulated into the refrigerator. And lastly make sure that the self defroster is working - if not the evaporator will freeze up, freezer temps go up, and ice maker will not work if freezer temps are 10 degrees or higher. A digital refrigerator thermometer will confirm freezer temps being high.
Aug 26, 2017 | Hotpoint HSM25GFRSA
Can this refrigerator be used in an unheated garage?
Yes, You can use most any refrigerator in an unheated area. Just be aware that if it is in a below freezing area for a long period of time that the cold may penetrate enough to get the refrigerator temperatures below freezing also.
Nov 18, 2009 | Refrigerators
Model FRS26ZRF, the freezer side is cooling down
It could be the defrost system? When you allowed to thaw, did you check the evaporator? It could be frozen? It will take longer to thaw. Is the evaporator fan working? It and the compressor will not, when the box is in defrost. Is your defrost working? Are your door gaskets sealing properly? Are your doors aligned properly? Some things to check. Good luck.
Jul 13, 2009 | Refrigerators
Freezer & freezer work fine. Water stops when refrige is set at 38 degrees. To keep water from freezing we have to set the refrige temp to 40 degrees, but find that temp not cold enough. Water can...
It may have auto-defrost or frost-free feature that is not operating. Also there is a drain tube that goes from the compartments to the bottom of the fridge where the evaporator pan is. The tube may be plugged.
Jul 02, 2009 | Samsung RS2556 Side by Side Refrigerator
Freezer isn't staying cold
What is the solution? What can we do to engage the refrig. again?
Mar 31, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
Kitchenaid built-in refrig 15 yrs old cold freezer, warm fridge
it.s the frezer that makes the refer cold.the evap fan in the frezer moves that chilled air to the refer.if that fan is slow or any blockage inthe air ways it slows that process.Also the frezer should be close to 0 degrees if theres a defrost prob that would make fresh food warmer
Dec 31, 2008 | Refrigerators
Hotpoint CTF15ELD top freezer refrigerator - freezer O.K. refrig too warm
hi thanks for the question you problem could be a no defrost problem remove the floor of the freezer 4 screws lift from back to front remove foam if its all frosted up you have a defrost problem a bad fan motor also can cause this it could also be stuck in ice if so use hair blower and thaw dry it real good re assemble and try again thanks the appliance doc
Sep 22, 2008 | Hotpoint HSS25GFP Side by Side...
Jenn-Air JCD2290HES Side by Side Refrigerator Logo
219 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
