Question about Sharp AR-275 Copier
I have error code h5-01 on my copier ar 275. how do i fix it?
  • 143 Answers
Check for jam paper in the fusing section.
(paper winding, etc.)
Check fusing unit installation
Clear the trouble with SIM 14.
To clear the trouble with SIM 14, enter the SIMULATION mode.
Enter # INTERRUPT C INTERRUPT, then hit 14 and the START key. Then hit either OK or START again.
Exit the SIM mode easiest by turning the machine off and back on again.
Posted on Sep 25, 2009
My sharp phohtocopy showing call for service F2-04 after opening the cover when booting please help me with the code to fix it
F2-04- Improper cartridge (destination error, life cycle error)
Identification error
model error
type error
destination error
data abnormality
Misc error
Jul 03, 2011 | Sharp AR-275 Copier
What does code u2-40 mean and how do i by pass it
Hello, You can download the manual here http://sharp.diplofix.com/forum-SHARP/AR-275
It looks like this error is a CRUM chip error, which could be caused by the type of toner cartridge you are using, and or the actual CRUM chip. The connector could be bad (check the connector for the toner cartridge) or when you replaced the toner cartridge; it may have bent the plate that it is mounted on and it needs to be straightened, realigned.
Oct 07, 2010 | Sharp AR-275 Copier
Copier was being moved, but when plugged back in it came up with the error code L6-10 how do I fix
sorry but change laser unit ,your problem will be solved.best regards.REZAZADEH
Feb 20, 2010 | Sharp AR-275 Copier
Error code L6-10 on sharp ar-275
try to reset or replace the polygon motor
Nov 17, 2009 | Sharp AR-275 Copier
H2 00 problem
Try to reset the error code by pressing these buttons :
[#] [interupt] [c] [interupt] [1] [4] [start/copy]
If the error code still exist check the thermistor and it's connection and reset again.
May 21, 2009 | Sharp AR-275 Copier
Sharp AR-275 Copier
Hello sir; there have no reset key for maintenence, whenevere PM light on you need to do PM service (such as replace drum developer, drum blade etc.)
May 19, 2009 | Sharp AR-275 Copier
Call for service U2-40, on a sharp AR275 printer
In AR 275 Sharp copier U2 40 is very common problem, U have to only reset the above error code as fallows
press # then intrrupt then c them intrrupt then display will show simulation mode then enter 16 then press ok key
pl ask for any difficulty
May 17, 2009 | Sharp AR-275 Copier
Sharp copier printer error: PostScrip printing not licensed for t
what is you OS? check you printer drivers. are they properly installed?, what is your connection between your PC to your printer?, AR 275 can be connected thru network, parallel port, and a USB... they have different printer drivers
Feb 01, 2009 | Sharp AR-275 Copier
Have error code e7-80 on a Sharp ARC260M copierwhich is 'ICU - SCN Communication Trouble'. Any one know what it means or how to fix it???
Usually E7 errors have to do with the scanner or the optics. You should get a hold of a technician to see what can be done to fix it.
Aug 05, 2008 | Sharp AR-275 Copier
Call service
Shows ASIC error. Unplugg the copier, wait 30 seconds and turn it back on again. See if the error appears. Does this error code happen when you turn it on or when you print something to it?
Aug 02, 2008 | Sharp AR-275 Copier
Sharp AR-275 Copier Logo
582 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
