Question about LG Washing Machines
I have a lg mod no wd8074fhb the prolem is it is out of balance on the spin cycle
Could be the main bearing.
I believe.... that there is a spider like clasp that goes around the rear of the drum. This has a rod which comes out the back of the spider and is inserted into the main bearing. This bearing is like a circle of metal so that the rod slides into it and can spin.
If the machine is not spinning balanced properly then this rod/spider or bearing may be broken/worn. My repair man told me it would cost 120$ and 2-3 hours work. I'm going to look at it myself and see how hard it is to replace the bearing (which he said needs to be very accurately in centre.).. .
Posted on Sep 25, 2009
LG Tromm Steam Washer Cycle is complete and the stuff is so wet that they have to wrung by hand to even put they on a clothes line. Can washer be put on spin only? How?
call a technician as it indicates that the cycle from rinse, spin is not progressing to spin only
rinse,spin is a low speed spin to facilitate the rinse and to balance out the clothes ready for the fast speed spin cycle
Feb 25, 2017 | LG Washing Machines
Lg wd8074fhb will not rotate drum on was or rinse
LE=Load Error CE=Cycle Error
Unplug at socket for two hours will reset the Error Sensors. The sensors are there to prevent overheating of the motor and the possible risk of a fire.
Load Error is linked with too much weight in the drum. Cycle Error is limked with an uneven load.
If it happens again, unplug for two hours to reset the Error Sensors.
Hope this helps.
Nov 16, 2009 | LG Washing Machines
Washing machine shuts off before cycle is finished now it will not last one min. on before it shuts off...what to do?
We have a front-loading LG washer. Today, I took a look at it when it was beginning the spin cycle because it sounded a bit different. I noticed that it was beginning to spin and would stop because [I believe] it was detecting a strong off-balance. It would then try to spin in the opposite direction and the same happened. After two more attempts, it automatically shut off with no warning nor error. We set the washer to wash and spin again and I began to work on balancing it. After adjusting the feet and waiting for the spin cycle again, it continued successfully because of the reduced off-balance. I'm not sure if there are other reasons that would cause the washer to turn off. This is the only one I have come across so far.
Oct 22, 2009 | LG WM1812C Front Load Washer
Spin cycle - washer is shaking and jumping
Try to relevel the unit. Another suggestion is use the cycle for delicates (the spin cycle is slower). If it is still out of balance and shaking one of the dampers may have broke
Aug 17, 2009 | LG WM-2277HW Front Load Washer
LG Washing Machine stops spinning in mid cycle
IE:
• Water supply is not adequate in
area.
• Water supply taps are not
completely open.
• Water inlet hose is bent.
• The filter of the inlet hose clogged.
Solution:
Check another tap in the house.
Fully open tap.
Straighten hose.
Check the filter of the inlet hose.
UE:
• Load is too small.
• Load is out of balance.
• The appliance has an imbalance
detection and correction system. If
individual heavy articles are loaded
(bath mat, bath robe, etc.) and the
imbalance is too great, after several
attempts to restart the spin cycle the
machine will stop and the error code
will be displayed.
Solution:
Add 1 or 2 similar items to help
balance the load.
Rearrange load to allow proper
spinning.
UE:
Apr 27, 2009 | LG WM2487H Front Load Washer
Balancing
This type of thing should not be required. Front load washing machines (well, topload too i guess) will balance themselves out for the spin cycle unless the machine is grossly overloaded.
Good luck.
Apr 15, 2008 | LG WM-2277HW Front Load Washer
LG intellowasher (front-loading washing machine) is starting to squeak.
I suggest u buy another washing machine. This one's had it!
Jan 12, 2008 | Washing Machines
Washing Machines Logo
89 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
