I have a PVR satellite receiver model Kaon KSC-N660H2, having problems with the picture quality running it through the hdmi cable. Lots of colour distortion and red lines. Is it the cable or the machine???? This machine is only a couple of months old. Thanks Karen
  • 4 Answers
SOURCE: Picture problem
Your problem might be a simple signal issue. Make sure with your cable provider that you have adequate signal coming into the cable box to convert the signal though all those components, especially the DVI-HDMI converter. The DVI SHOULD be configured to run video only. try bypassing the audio signal with an RCA component cable. This should take the audio load off of the DVI port and re-route it through the RCA jacks, thereby supporting a better video signal. If this doesn't work, then it might be an equipment issue. The 6200 was originally designed to run on RCA component cables. Hold out till after July 1st for new CableCARD ready HD devices.
Posted on Jun 27, 2007
SOURCE: Black/Green Distortion - Picture Quality - Wharfedale
This is no solution but a point in a probable direction.
A tech guy told me ALL the LCDs they have seen in their repair shop have "swollen" capacitors, this is due to voltage instability. Lowering the internal voltage regulator and replacing the swollen capacitors (which eliminate noise) apparently restores the LCD to new working quality. Without actually "seeing" my problem the tech said that should repair it. I have not tried this yet but eventually will begin that way.
Posted on Jun 08, 2008
bernardlunda
  • 318 Answers
SOURCE: Hello!
i can suggest that you try
if your tv has AV in &out pots, a multi spriter can be bought in order to have many input with one output.
it you want to have RF be conveted to AV converter can be bought.
dont forget to crosspatch IN toOUT, OUT to IN of differant sets
Posted on Mar 30, 2009
mlapres
  • 757 Answers
SOURCE: MY picture blinks every 10 seconds
Try making sure that the receiver has any video scale upconverting disabled. A lot of TVs also have upconverting to a native resolution higher than the input signal but 2 devices doing that procesing simultaneously can cause a device conflict. I think.
Posted on Jun 18, 2009
SOURCE: pvr is locked on 1 channel as if it is frozen.
hard disk is nackered - had same problem. if you take power cable out of hard disk it will work as just freeview box. tried replacing my hardrive but it does not like drive and freezes again - software problem or format?
Posted on Jun 21, 2009
I have sound from satelite box through bose 321 but no picture on tv
First, you need to run the coax cable from your satellite dish to the "cable in" input on the back of your satellite receiver, not the Bose. If your satellite receiver has an HDMI OUT, and if the Bose has an HDMI IN,run hdmi OUT from the rec. to the Bose IN, then keep your HDMI connection from the Bose OUT to the TV IN as is. Make sure you've selected the correct input on the TV menu. As it is right now, you're not delivering any video signal at all to the TV!! -only audio(red and white). There are a couple other ways, but they won't give you the same quality. I assume this is HD, right? If you CAN do it this way (i.e. if you have enough HDMI ins and outs), it's the best possible hookup and you won't need the composite (red, white and yellow) at all. By the way, it's the yellow connector that carries the video signal; the red and white are audio left and right. If you can't hook it up all HDMI, disconnect the "separate cable" (I'm not sure what that is or what kind of cable or what it's for)and plug in the yellow connector into video IN on the Bose.
Feb 08, 2015 | Bose Av321 Series Ii Media Center For 321...
TV picture not clear
First we need to know a little more details about the kind of TV you have, the kind of service (Cable, Satellite or off Air).
Comparing showroom to your home is also something we need to know. Was the showroom using Cable or Satellite. Satellite will always have a better picture quality wise.
If you are using composite input for the signal path between TV and source this would not produce a High Dif picture Composite = Yellow for video, red and white for audio. If you are using Component source that will produce a HD signal cable is RED/BLUE and Green with different audio.
The best quality is using an HDMI cable, this is all in one cable and the sources is the best. One last thing, if you are using the RF *cable as source it will not give you a quality signal.
Apr 22, 2014 | Intellian i9P US HD System with 85cm Dish...
Give me properly installation of stand alone dvr with computer all window how sport the dvr send me properly anstallation of standalone dvr
Take one co-axial cable, and connect the "input" port to your cable-company's wall-port.
Look at the connectors on the back of your TV. You could have:
* coaxial input (lowest video-quality)
* S-Video input (better video-quality)
* component input - three cables for video, two cables for audio (better video-quality)
* HDMI input (highest video-quality)
Look at the connectors on the "output" side of the PVR. You could have:
* coaxial output (lowest video-quality)
* S-Video output (better video-quality)
* component output - three cables for video, two cables for audio (better video-quality)
* HDMI output (highest video-quality)
Connect the "outputs" to the "inputs", using appropriate cables.
Turn the PVR on. Turn the TV on.
Use the "source" button on the TV's remote-control to select from the various inputs
(Coax, S-Video, Component, HDMI1, HDMI2).
If your TV has 'PIP' ("Picture-In-Picture") capability, connect more than one output to a second input, so that both tuners inside your TV will receive a signal.
Feb 03, 2011 | Computers & Internet
I have a Sony playstation 3 that I use as my dvd player and run it through my yamaha via an HDMI cable. I also connect the Yamaha output to the TV through an HDMI cable. Until recently the playstation...
Look in the manual for which version of HDMI. If it's 1.2a, they had a problem with the boards and were repairing them. Contact Yamaha @ 1-800-292-2982 Hope this helps
Jun 11, 2010 | Yamaha RX-V863 Receiver
Sound drop with Shaw pvr box with hdmi. How do
This is a very common problem with no real solution. If your TV can be programmed to accept separate audio from HDMI video on the same input, you can feed the audio through standard RCA cables. Unfortunately most TV's do not allow this. Alternatively run them into a stereo receiver. Buying high end HDMI cables will not help. Most people I know with this issue have bit the bullet & just used component video instead. The difference in quality is minimal.
Apr 25, 2010 | Arris DCT6200 DTV Receiver
I have a new Sony Bravia KDL-26L-5000 with Directv and the image is pixelated. Can I do anything?
Make sure you have subscribed to a HDTV service with your television provider.
Also, make sure that all of the devices that are connected to your television are HD devices, connected with a HDMI cable, not a coaxial or RCA jack.
HDTVs aren't magical TVs : everything from the source to the television, including your home theater and PVR, if any, must be HD-compatible in order for the picture on your screen to be in high definition.
On BRAVIA screens, I know that, when you select an input, it will briefly show the definition of the source in the corner of the screen. You must make sure it's 1080p. If it's anything other than 1080p, your picture is not in HD.
I remember that my grandparents had a similar problem. It turns out their BRAVIA television was displaying a low quality picture (480i), even though they had subscribed to a HDTV service, just because their satellite receiver was not configured correctly.
So maybe the solution is simply to make sure that each of your devices is configured to display only the highest resolution available (usually 1080p) in order to enjoy the best picture quality. Do not trust "automatic" quality settings, because they tend to select lower quality settings (such as 720p, which is not True HD), when they might be able to display true high definition pictures (1080p).
Jun 11, 2009 | Televison & Video
Connecting PVR and satellite receiver
make sure you have a connection from one of your scart sockets (assuming you are using scart) on your sat to your pvr and then a connection (scart/hdmi?) to your tv from the pvr.
if you have a second scart or better still hdmi on your sat then plug that into tv
set top box scart output to tv
you do not say which tv model number you have so I dont know what input sockets you have but I will assume a couple of scart inputs and maybe a hdmi in (if hd version of tv) these days that would be considered a minimum amout of inputs so the setup suggestion above should be fine with that
Jul 22, 2008 | Philips DVDR3450H DVD Recorder/HDD...
I have a sony bravia kdl-26m4000
Cable boxes have notoriously flaky HDMI outputs. I have seen No pic and no sound with their HDMI outputs as well as a host of other problems. You can try getting the cable box replaced; unfortunately I have seen multiple cable box replacements not fix the problem. The best solution is to leave the component cables connected; you're not losing hardly any resolution/picture quality by using the component instead of the HDMI. Solution #2: switch to a satellite provider. I rarely see HDMI problems with satellite boxes
May 28, 2008 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
Video signal drops out
Well, I have a solution and a question. First, why do you have S-Video hooked up from the sat receiver? is it a non- HD unit? Does it have component out? if so use it. Next; your receiver, as awesome as it is,it is 3 model years old and the HDMI firmware that was used in 2005-06 was version 1.1 which unfortunately for all of us was a "failed" format when using DSS,Cable, or FIOS. The problem was passing the DHCP copyright protection format from one source thru another to a third. Sounds complicated, I know, but that's what the issue is. The Good news is; the human eye cannot tell the difference between 720p and 1080p on any TV set 50" or smaller, and that is a fact. and the 2600 would only convert from s-video to 1080i which is equal to 540p. So, to make a long story short and understandable, if you use a good quality component cable to your TV set (Monster, Phoenix Gold, Apatchure, etc) your picture quality will not suffer and there is no reason to be upset at your receiver since it was firmware provided by HDMI not Yamaha and was a problem on every receiver made with 1.1 firmware. So here's what you do Hook up your Sat receiver component (if you have it) S-vid if you have to, and any other sources that are going to pass video thru your receiver either s-vid,component, or standard vid. The only exception would be a blu-ray DVD. I would run HDMI direct to your TV, then run digital coaxial for audio to the DVD Digital audio input of your receiver. You have an awesome receiver that has lots of cool features and a bullet-proof electronics! enjoy it! Hope this helps. If you have any more questions, post a comment and I will help some more.
Jan 07, 2007 | Yamaha RX-V2600 Receiver
Televison & Video Logo
132 people viewed this question
Top Televison & Video Experts
